Tools
Spudger4.9
Introduction
Go to step 1 ↓The display on the Google Pixelbook is secured with strong adhesive and requires some careful prying to separate it from the case. Using heat from a hairdryer, or an iOpener, may help soften the adhesive for easier removal.
Use the iFixit opening tools or a metal spudger to pry the rubber covers off the back of your Pixelbook.
Peel the linings off completely until the back of the Pixelbook looks bare.
Use an iSclack, or suction cup, to lift up the corner of the display from the case.
Tool used on this step:Tweezers$4.99
Use a pair of tweezers to grab the clip on the display connector and swing it over to the other side of the socket.
Pull on the clip to disconnect the display.
Remove the display.
12 other people completed this guide.
9 Guide Comments
Where would you find a replacement display?
