Google Pixel XL Rear Facing Camera Replacement
    1. Google Pixel XL Rear Facing Camera Replacement, SIM Card Tray: step 1, image 1 of 3 Google Pixel XL Rear Facing Camera Replacement, SIM Card Tray: step 1, image 2 of 3 Google Pixel XL Rear Facing Camera Replacement, SIM Card Tray: step 1, image 3 of 3
      • Insert a SIM eject tool, SIM eject bit, or a paperclip into the small hole on the left edge of the phone, near the top.
      • Press to eject the tray.
      Ask FixBot
    1. Google Pixel XL Rear Facing Camera Replacement, Display Assembly: step 2, image 1 of 3 Google Pixel XL Rear Facing Camera Replacement, Display Assembly: step 2, image 2 of 3 Google Pixel XL Rear Facing Camera Replacement, Display Assembly: step 2, image 3 of 3
      • Heat an iOpener and apply it to the top edge of the display for two minutes.
      • A hair dryer, heat gun, or hot plate may also be used, but be careful not to overheat the phone—the display and internal battery are both susceptible to heat damage.
      • Take note of the following regions before you begin prying:
      • Thin adhesive lined against the display panel
      • Thick adhesive
      • The OLED display panel, which is very prone to damage
      • The display cable, which can be damaged during prying
      Ask FixBot
    2. Google Pixel XL Rear Facing Camera Replacement: step 3, image 1 of 3 Google Pixel XL Rear Facing Camera Replacement: step 3, image 2 of 3 Google Pixel XL Rear Facing Camera Replacement: step 3, image 3 of 3
      • Once the edge is warm to the touch, apply a suction cup close to the edge.
      • Lift on the suction cup, and insert an opening pick into the gap.
      • Do not insert the pick more than 13 mm (0.5 inches), or you will damage the display assembly.
      • If you have trouble creating a gap, reheat the edge and try again.
      • You can also try to use a playing card instead of an opening pick to help make the initial entry.
      Ask FixBot
    3. Google Pixel XL Rear Facing Camera Replacement: step 4, image 1 of 3 Google Pixel XL Rear Facing Camera Replacement: step 4, image 2 of 3 Google Pixel XL Rear Facing Camera Replacement: step 4, image 3 of 3
      • Slide the opening clip across the top edge to slice through the adhesive.
      • Be sure not to cut deeper than 13 mm (0.5 inches) or you will damage the display.
      • There's a mesh covering the earpiece speaker on the top edge of the screen. If you don’t have a replacement mesh, take care not to damage or lose this component.
      • Leave an opening pick in the edge to prevent the adhesive from resealing.
      Ask FixBot
    4. Google Pixel XL Rear Facing Camera Replacement: step 5, image 1 of 3 Google Pixel XL Rear Facing Camera Replacement: step 5, image 2 of 3 Google Pixel XL Rear Facing Camera Replacement: step 5, image 3 of 3
      • Heat an iOpener and apply it to the right edge of the phone for two minutes.
      • Insert an opening pick near the top edge of the phone, where you have already sliced the adhesive.
      • Slowly guide the pick around the right corner.
      • Carefully slide the pick down the right edge of the phone to slice through the adhesive.
      • Do not insert the pick more than 1 mm (1/32") along the edge, or you will damage the display assembly.
      • Repeat the step for the left edge of the phone.
      Ask FixBot
    5. Google Pixel XL Rear Facing Camera Replacement: step 6, image 1 of 2 Google Pixel XL Rear Facing Camera Replacement: step 6, image 2 of 2
      • Heat the bottom edge with an iOpener for two minutes.
      • Insert a pick near the right edge where you have already loosened the adhesive.
      • Carefully guide the pick around the corner.
      • Slide the pick along the bottom edge to slice through the adhesive.
      • Do not slice deeper than 8.5 mm (1/3") or you will damage the display cable.
      Ask FixBot
    6. Google Pixel XL Rear Facing Camera Replacement: step 7, image 1 of 1
      • Once you have sliced around the perimeter of the phone, carefully lift the display assembly up slightly by the right corners.
      • Do not attempt to remove the display assembly. It is still attached by a flex cable.
      • Use an opening pick to slice through any remaining adhesive.
      Ask FixBot
    7. Google Pixel XL Rear Facing Camera Replacement: step 8, image 1 of 3 Google Pixel XL Rear Facing Camera Replacement: step 8, image 2 of 3 Google Pixel XL Rear Facing Camera Replacement: step 8, image 3 of 3
      • Lift the display assembly from the top end and swing it around such that it rests upside down on the frame.
      • Be careful not to strain the flex cable when you swing the assembly around.
      Ask FixBot
    8. Google Pixel XL Rear Facing Camera Replacement: step 9, image 1 of 2 Google Pixel XL Rear Facing Camera Replacement: step 9, image 2 of 2
      Tool used on this step:
      Magnetic Project Mat
      $19.95
      Buy
      • Remove the two 4 mm T5 screws securing the display cable bracket.
      • Remove the display cable bracket.
      Ask FixBot
    9. Google Pixel XL Rear Facing Camera Replacement: step 10, image 1 of 2 Google Pixel XL Rear Facing Camera Replacement: step 10, image 2 of 2
      • Use the point of a spudger to pry up and disconnect the display cable from its connector.
      • To re-attach press connectors like this one, carefully align and press down on one side until it clicks into place, then repeat on the other side. Do not press down on the middle. If the connector is misaligned, the pins can bend, causing permanent damage.
      Ask FixBot
    10. Google Pixel XL Rear Facing Camera Replacement: step 11, image 1 of 3 Google Pixel XL Rear Facing Camera Replacement: step 11, image 2 of 3 Google Pixel XL Rear Facing Camera Replacement: step 11, image 3 of 3
      Buy
      • Remove the display assembly.
      • For comprehensive instructions on how to reinstall the Pixel XL display, follow this guide.
      • If your replacement display did not come with a speaker grille, use tweezers to gently peel the adhesive grille from your old display, and transfer it to the replacement.
      • Before installing a new display, be sure to remove all traces of adhesive from the frame. Use a spudger or an opening tool to scrape it off, and use high-concentration isopropyl alcohol to remove any residue.
      • If you are reinstalling the same display assembly, be sure to remove all adhesive residue from the panel and the frame before applying new adhesive.
      • Be sure to turn on your phone and test your repair before installing new adhesive and resealing the phone.
      • During the boot-up process after reassembly, the screen will go through a calibration sequence. Do not touch the screen during this process, as it could result in improper touch calibration and create touch issues.
      Ask FixBot
    1. Google Pixel XL Rear Facing Camera Replacement, Google Pixel XL Opening Procedure: step 12, image 1 of 1
      • Remove the following screws that secure the midframe to the back:
      • Seven black 4 mm T5 screws
      • Two silver 3 mm T5 screws
      Ask FixBot
    2. Google Pixel XL Rear Facing Camera Replacement: step 13, image 1 of 1
      • The midframe is held tightly in place by plastic clips which push into the edge of the back case.
      Ask FixBot
    3. Google Pixel XL Rear Facing Camera Replacement: step 14, image 1 of 3 Google Pixel XL Rear Facing Camera Replacement: step 14, image 2 of 3 Google Pixel XL Rear Facing Camera Replacement: step 14, image 3 of 3
      • Find the small notch in the bottom left corner of the frame and insert an opening pick.
      • Slide the opening pick along the bottom edge of the phone towards the bottom right corner and leave it there.
      Ask FixBot
    4. Google Pixel XL Rear Facing Camera Replacement: step 15, image 1 of 3 Google Pixel XL Rear Facing Camera Replacement: step 15, image 2 of 3 Google Pixel XL Rear Facing Camera Replacement: step 15, image 3 of 3
      • Insert a separate opening pick into the right edge of the phone, near the bottom.
      • Slowly push the pick upwards along the seam until the first clip pops free.
      • Due to the tight tolerances, this may be difficult, requiring a substantial amount of force. If you are having trouble, try inserting and sliding a playing card.
      • Once you've released the clip, leave the opening pick in place to prevent the midframe from resealing.
      Ask FixBot
    5. Google Pixel XL Rear Facing Camera Replacement: step 16, image 1 of 2 Google Pixel XL Rear Facing Camera Replacement: step 16, image 2 of 2
      • Insert an opening pick into the right edge of the phone and slide it upwards towards the top right clip.
      • You do not need to insert the pick more than 2 mm into the edge. If you insert the pick all the way in, you may risk damaging flex cables.
      • Slowly slide the pick past the clip to disengage it from the frame.
      • At this point, the right edge of the midframe should be free from the case. If it isn't, slide an opening clip up and down along the right edge.
      Ask FixBot
    6. Google Pixel XL Rear Facing Camera Replacement: step 17, image 1 of 3 Google Pixel XL Rear Facing Camera Replacement: step 17, image 2 of 3 Google Pixel XL Rear Facing Camera Replacement: step 17, image 3 of 3
      • Grasp the right edge of the midframe by the corners and slowly hinge the edge up.
      • When the left edge feels loose, stop hinging and lift the midframe upwards.
      • Remove the midframe.
      • To reinstall the midframe, align it to the case, then squeeze around the perimeter until all the clips snap back into position. When properly done, the midframe should lie flat.
      Ask FixBot
    1. Google Pixel XL Rear Facing Camera Replacement, Motherboard: step 18, image 1 of 3 Google Pixel XL Rear Facing Camera Replacement, Motherboard: step 18, image 2 of 3 Google Pixel XL Rear Facing Camera Replacement, Motherboard: step 18, image 3 of 3
      • Use the point of a spudger to pry up and disconnect the battery connector.
      • Bend the battery flex cable slightly so that it will not accidentally touch the motherboard.
      Ask FixBot
    2. Google Pixel XL Rear Facing Camera Replacement: step 19, image 1 of 2 Google Pixel XL Rear Facing Camera Replacement: step 19, image 2 of 2
      • Use the point of a spudger to pry up and disconnect the button strip connector.
      • If the button strip's metal clip falls out during the repair, align the clip and push it back into its groove.
      Ask FixBot
    3. Google Pixel XL Rear Facing Camera Replacement: step 20, image 1 of 2 Google Pixel XL Rear Facing Camera Replacement: step 20, image 2 of 2
      Buy
      • Use tweezers to peel up the tape at the top of the interconnect cable.
      Ask FixBot
    4. Google Pixel XL Rear Facing Camera Replacement: step 21, image 1 of 2 Google Pixel XL Rear Facing Camera Replacement: step 21, image 2 of 2
      • Use the point of a spudger to pry up and disconnect the interconnect cable from the motherboard.
      Ask FixBot
    5. Google Pixel XL Rear Facing Camera Replacement: step 22, image 1 of 3 Google Pixel XL Rear Facing Camera Replacement: step 22, image 2 of 3 Google Pixel XL Rear Facing Camera Replacement: step 22, image 3 of 3
      • Use the point of a spudger to disconnect the black antenna cable from the motherboard, near the front facing camera module.
      • Route the antenna cable out of its retaining clip.
      Ask FixBot
    6. Google Pixel XL Rear Facing Camera Replacement: step 23, image 1 of 2 Google Pixel XL Rear Facing Camera Replacement: step 23, image 2 of 2
      • Use the point of a spudger to pry up and disconnect the white antenna cable from the motherboard, near the rear facing camera module.
      Ask FixBot
    7. Google Pixel XL Rear Facing Camera Replacement: step 24, image 1 of 1
      • Remove the two 3 mm T5 screws securing the motherboard to the frame.
      • During reinstallation, be sure that both camera modules and the headphone jack module are seated properly in their sockets before screwing down the motherboard.
      Ask FixBot
    8. Google Pixel XL Rear Facing Camera Replacement: step 25, image 1 of 3 Google Pixel XL Rear Facing Camera Replacement: step 25, image 2 of 3 Google Pixel XL Rear Facing Camera Replacement: step 25, image 3 of 3
      • Use the point of a spudger to pry up and loosen the front facing camera module from its socket.
      Ask FixBot
    9. Google Pixel XL Rear Facing Camera Replacement: step 26, image 1 of 2 Google Pixel XL Rear Facing Camera Replacement: step 26, image 2 of 2
      • Insert the point of a spudger into the headphone jack port and pry upwards to loosen the port from its socket.
      Ask FixBot
    10. Google Pixel XL Rear Facing Camera Replacement: step 27, image 1 of 2 Google Pixel XL Rear Facing Camera Replacement: step 27, image 2 of 2
      • Be sure that you have ejected the SIM card tray before performing this step.
      • Use the flat end of a spudger to pry the bottom edge of the motherboard up slightly, loosening it from its recess.
      • Do not try to remove the motherboard yet. It is still connected by a flex cable.
      Ask FixBot
    11. Google Pixel XL Rear Facing Camera Replacement: step 28, image 1 of 2 Google Pixel XL Rear Facing Camera Replacement: step 28, image 2 of 2
      • Locate the fingerprint sensor cable attached to the underside of the motherboard, near the bottom edge.
      • Use the point of a spudger to pry and release the fingerprint sensor cable from its socket.
      • Peel the cable away from the motherboard.
      Ask FixBot
    12. Google Pixel XL Rear Facing Camera Replacement: step 29, image 1 of 2 Google Pixel XL Rear Facing Camera Replacement: step 29, image 2 of 2
      Ask FixBot
    1. Google Pixel XL Rear Facing Camera Replacement, Rear Facing Camera: step 30, image 1 of 2 Google Pixel XL Rear Facing Camera Replacement, Rear Facing Camera: step 30, image 2 of 2
      • Flip the motherboard such that the underside is facing up.
      • Use the point of a spudger to pry up and disconnect the rear facing camera connector from its socket.
      Ask FixBot
    2. Google Pixel XL Rear Facing Camera Replacement: step 31, image 1 of 3 Google Pixel XL Rear Facing Camera Replacement: step 31, image 2 of 3 Google Pixel XL Rear Facing Camera Replacement: step 31, image 3 of 3
      • Flip the motherboard such that the backside is facing down.
      • Pivot the camera module out of its recess and slowly pull it out, lifting the adhesive tape in the process.
      • Remove the rear camera module.
      Ask FixBot
Repair didn’t go as planned? Check out our Google Pixel XL Answers community for troubleshooting help.
6 other people completed this guide.
Arthur Shi
351,060 Reputation
938 Guides authored
5 Guide Comments
Where can I get the replacement camera
Caleb - Reply Share
https://www.witrigs.com/oem-rear-camera-...
This is one of other only places I could find to get a replacement camera module.
Eric Tackaberry - Reply Share
iFixit sells the replacement part here. It looks like new camera modules are out of stock, but used and fully tested ones are still in stock as of May 15, 2018.
Google Pixel/Pixel XL Rear Camera
Erik Swan - Reply Share
A helpful tip: before you re-assemble the phone, shine a bright light through the back glass and check that there is no dust or debris on the inside of the back glass or the camera lens.
Also, this may be obvious to some, but you will need replacement adhesive for the display in order to re-attach it to the phone. I didn’t even think about this until I had already started the repair and taken the display off.
Do you think that if I put a Pixel 3 camera in there, it would still work?
Have any of you tried to up the storage capacity on one of these things?
Jeremy Sing - Reply Share
Past 24 Hours: 3
Past 7 Days: 26
Past 30 Days: 100
All Time: 6,822
