Google Pixel Watch Vibration Motor Replacement
Views: 1.6K
View statistics:
Past 24 Hours:
2
Past 7 Days:
13
Past 30 Days:
75
All Time:
1,586
Comments: 1
1 comment on steps.
Completed: 0
Favorites: 0
Time Required: 30 - 45 minutes
Difficulty: Moderate
Introduction
Go to step 1 ↓
Use this guide to remove or replace the vibration motor in your Google Pixel Watch.
For your safety, discharge the battery below 25% before disassembling your device. This reduces the risk of fire if the battery is accidentally damaged during the repair. If your battery is swollen, take appropriate precautions.
You’ll need replacement adhesive to reattach the screen when reassembling the device.
Retaining water resistance after the repair will depend on how precisely the adhesive is reapplied, but your device will lose its IP (Ingress Protection) rating.
Note: This guide was written using a GBZ4S LTE model. If you have the non-LTE version, you can still use this guide—but there might be slight visual discrepancies.
Tools
    1. Google Pixel Watch Vibration Motor Replacement, Remove the watch band: step 1, image 1 of 3 Google Pixel Watch Vibration Motor Replacement, Remove the watch band: step 1, image 2 of 3 Google Pixel Watch Vibration Motor Replacement, Remove the watch band: step 1, image 3 of 3
      • Before starting repairs, turn off your watch and take it off the charger.
      • Remove the watch band by pressing the band release button and sliding the band over the button while pulling it away from the watch.
      • Repeat for the other watch band.
      Ask FixBot
    2. Google Pixel Watch Vibration Motor Replacement, Loosen the screen adhesive: step 2, image 1 of 1
      • Heat an iOpener and apply it to the screen for about two minutes to soften the adhesive securing the screen.
      • A hair dryer, heat gun, or hot plate may also be used, but be careful not to overheat the watch—the screen and internal battery are both susceptible to heat damage.
      Ask FixBot
    3. Google Pixel Watch Vibration Motor Replacement, Insert an iFlex: step 3, image 1 of 2 Google Pixel Watch Vibration Motor Replacement, Insert an iFlex: step 3, image 2 of 2
      Tool used on this step:
      iFlex Opening Tool
      $11.99
      Buy
      • The thin seam between the frame and screen requires a thin metal tool—take your time and work carefully to avoid scraping or gouging the watch body or glass.
      • Insert an iFlex into the thin gap between the screen and frame, left of the digital crown.
      Ask FixBot
    4. Google Pixel Watch Vibration Motor Replacement, Slice the screen adhesive: step 4, image 1 of 3 Google Pixel Watch Vibration Motor Replacement, Slice the screen adhesive: step 4, image 2 of 3 Google Pixel Watch Vibration Motor Replacement, Slice the screen adhesive: step 4, image 3 of 3
      • When slicing the screen adhesive, insert the iFlex no deeper than 3 mm to prevent damaging internal components.
      • Slide the iFlex around the entire perimeter of the watch to slice all of the screen adhesive.
      Ask FixBot
    5. Google Pixel Watch Vibration Motor Replacement, Pry up the screen: step 5, image 1 of 2 Google Pixel Watch Vibration Motor Replacement, Pry up the screen: step 5, image 2 of 2
      • Remove the iFlex and reinsert it under the screen, to the right of the speaker grille.
      • Twist the iFlex to pry the screen up.
      • Don't try to fully remove the screen just yet, as it‘s still connected to the watch assembly by a delicate cable.
      Ask FixBot
    6. Google Pixel Watch Vibration Motor Replacement, Swing open the screen: step 6, image 1 of 3 Google Pixel Watch Vibration Motor Replacement, Swing open the screen: step 6, image 2 of 3 Google Pixel Watch Vibration Motor Replacement, Swing open the screen: step 6, image 3 of 3
      • Be careful not to strain the screen assembly cable when you open the display.
      • Swing the screen open to an upright position.
      • During reassembly, this is a good point to power on your device and test all functions before sealing it up. Be sure to power it back down completely before you continue working.
      Ask FixBot
    1. Google Pixel Watch Vibration Motor Replacement, Unfasten the speaker bracket: step 7, image 1 of 2 Google Pixel Watch Vibration Motor Replacement, Unfasten the speaker bracket: step 7, image 2 of 2
      FixMat
      $36.95
      Buy
      • Use a Torx T2 screwdriver to remove the 2.1 mm-long screw securing the speaker bracket.
      Ask FixBot
    2. Google Pixel Watch Vibration Motor Replacement, Remove the speaker bracket: step 8, image 1 of 3 Google Pixel Watch Vibration Motor Replacement, Remove the speaker bracket: step 8, image 2 of 3 Google Pixel Watch Vibration Motor Replacement, Remove the speaker bracket: step 8, image 3 of 3
      Buy
      • Take care not to puncture or bend the battery with sharp tools—it can leak dangerous chemicals or catch fire.
      • Use a pair of tweezers to remove the speaker bracket.
      Ask FixBot
    3. Google Pixel Watch Vibration Motor Replacement, Disconnect the vibration motor: step 9, image 1 of 2 Google Pixel Watch Vibration Motor Replacement, Disconnect the vibration motor: step 9, image 2 of 2
      • Use the point of a spudger to pry up and disconnect the vibration motor‘s press connector.
      • To re-attach press connectors like this one, carefully align and press down on one side until it clicks into place, then repeat on the other side. Do not press down in the middle. If the connector is misaligned, the pins can bend and cause permanent damage.
      Ask FixBot
    4. Google Pixel Watch Vibration Motor Replacement, Loosen the vibration motor cable: step 10, image 1 of 2 Google Pixel Watch Vibration Motor Replacement, Loosen the vibration motor cable: step 10, image 2 of 2
      • Be careful with sharp tools around the battery.
      • Use tweezers to peel up the yellow tape securing the vibration motor cable to the battery.
      Ask FixBot
    5. Google Pixel Watch Vibration Motor Replacement, Unfasten the vibration motor: step 11, image 1 of 1
      • Use a Torx T2 screwdriver to remove the two screws securing the vibration motor:
      • One 1.8 mm-long screw
      • One 2.8 mm-long screw
      Ask FixBot
    6. Google Pixel Watch Vibration Motor Replacement, Remove the grounding bracket: step 12, image 1 of 3 Google Pixel Watch Vibration Motor Replacement, Remove the grounding bracket: step 12, image 2 of 3 Google Pixel Watch Vibration Motor Replacement, Remove the grounding bracket: step 12, image 3 of 3
      • Use tweezers to lift the grounding bracket out of its recess and remove it.
      Ask FixBot
    7. Google Pixel Watch Vibration Motor Replacement, Remove the vibration motor: step 13, image 1 of 2 Google Pixel Watch Vibration Motor Replacement, Remove the vibration motor: step 13, image 2 of 2
      • Remove the vibration motor.
      Ask FixBot
During reassembly, apply new adhesive where it's necessary after cleaning the relevant areas with isopropyl alcohol (>90%).
Dominik Schnabelrauch
266,648 Reputation
682 Guides authored
iFixit Member of iFixit
Staff
121 Members
72,931 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 13
Past 30 Days: 75
All Time: 1,586
