Google Pixel Watch 5 Battery Replacement
View statistics:
Past 24 Hours:
15
Past 7 Days:
157
Past 30 Days:
410
All Time:
687
Comments: 6
6 comments on steps.
Completed: 0
Favorites: 0
Time Required: 20 - 30 minutes
Difficulty: Moderate
Featured Guide
This guide has been found to be exceptionally cool by the iFixit staff.
Introduction
Go to step 1 ↓
This repair guide was authored by the iFixit staff and hasn’t been endorsed by Google. Learn more about our repair guides here.
Use this guide to replace a dead or worn-out battery in your Google Pixel Watch 5.
Your watch's battery has a limited lifespan. If your watch doesn't hold a charge or dies unexpectedly, it might be time to replace the battery.
This guide was written using a 41 mm LTE model Pixel Watch 4. While some photos may contain slight visual discrepancies, procedures for all Pixel Watch 4/5 41 mm/45 mm models are functionally the same.
Tools
    1. Google Pixel Watch 5 Battery Replacement, Prepare your watch for disassembly: step 1, image 1 of 3 Google Pixel Watch 5 Battery Replacement, Prepare your watch for disassembly: step 1, image 2 of 3 Google Pixel Watch 5 Battery Replacement, Prepare your watch for disassembly: step 1, image 3 of 3
      • Before starting your repair:
      • Remove your watch from the charger.
      • Press and hold the crown button, then tap Power off to shut down your watch.
      Ask FixBot
    2. Google Pixel Watch 5 Battery Replacement, Remove the watch bands: step 2, image 1 of 3 Google Pixel Watch 5 Battery Replacement, Remove the watch bands: step 2, image 2 of 3 Google Pixel Watch 5 Battery Replacement, Remove the watch bands: step 2, image 3 of 3
      • Remove each watch band by depressing the release button and sliding the band out of its groove.
      Ask FixBot
    3. Google Pixel Watch 5 Battery Replacement: step 3, image 1 of 1
      • Throughout the rest of your repair, consider placing your watch on something soft like a clean cloth to help stabilize it and prevent scratches to the front glass.
      Ask FixBot
    4. Google Pixel Watch 5 Battery Replacement, Remove the back sensor glass screws: step 4, image 1 of 3 Google Pixel Watch 5 Battery Replacement, Remove the back sensor glass screws: step 4, image 2 of 3 Google Pixel Watch 5 Battery Replacement, Remove the back sensor glass screws: step 4, image 3 of 3
      • Use a Torx Plus 2IP screwdriver to remove the 3.0 mm‑long screw from both watch band grooves (two screws total).
      • Both screws have a tiny O‑ring. If they don't lift away with the screw, use a pair of tweezers to carefully remove them from the band groove and set them aside. These O-rings are required to maintain waterproofing.
      • Handle these O-rings carefully. Avoid pinching or slicing them with your tool.
      • During reassembly:
      • Make sure the O‑rings are on the screws before installing them.
      • Push down firmly on the back glass while installing the screws to make sure the glass gets properly seated.
      • If there's a gap between the back glass and frame, remove the screws and reinstall them.
      Ask FixBot
    5. Google Pixel Watch 5 Battery Replacement, Separate the back sensor glass: step 5, image 1 of 2 Google Pixel Watch 5 Battery Replacement, Separate the back sensor glass: step 5, image 2 of 2
      • Insert the point of a spudger (or a clean fingernail) into the seam between the back sensor glass and frame and pry up until the cover detaches.
      Ask FixBot
    6. Google Pixel Watch 5 Battery Replacement, Reposition the back sensor glass: step 6, image 1 of 3 Google Pixel Watch 5 Battery Replacement, Reposition the back sensor glass: step 6, image 2 of 3 Google Pixel Watch 5 Battery Replacement, Reposition the back sensor glass: step 6, image 3 of 3
      • Gently lift the back glass and flip it over the side of the watch opposite the crown.
      • Be careful not to strain the cable connecting the back sensor glass.
      Ask FixBot
    1. Google Pixel Watch 5 Battery Replacement, Remove the vibration motor screws: step 7, image 1 of 2 Google Pixel Watch 5 Battery Replacement, Remove the vibration motor screws: step 7, image 2 of 2
      • Optionally, you can disconnect the back glass to give you more room to work—though you can complete the repair just fine with it still connected.
      • Use a Torx Plus 2IP screwdriver to remove the two 2.2 mm‑long screws securing the vibration motor.
      Ask FixBot
    2. Google Pixel Watch 5 Battery Replacement, Remove the vibration motor: step 8, image 1 of 2 Google Pixel Watch 5 Battery Replacement, Remove the vibration motor: step 8, image 2 of 2
      Ask FixBot
    1. Google Pixel Watch 5 Battery Replacement, Reposition the back sensor glass: step 9, image 1 of 3 Google Pixel Watch 5 Battery Replacement, Reposition the back sensor glass: step 9, image 2 of 3 Google Pixel Watch 5 Battery Replacement, Reposition the back sensor glass: step 9, image 3 of 3
      • Gently flip the back sensor glass over the crown-side of the watch.
      Ask FixBot
    2. Google Pixel Watch 5 Battery Replacement, Disconnect the battery: step 10, image 1 of 2 Google Pixel Watch 5 Battery Replacement, Disconnect the battery: step 10, image 2 of 2
      • Use the point of a spudger to pry up and disconnect the battery press connector.
      • During reassembly, use the point of a spudger to press down and reconnect the press connector.
      • This can be tricky, and may take a few tries.
      • If you're having trouble, loosen the two battery screws and reposition the connector. Once connected, re-tighten the battery screws.
      Ask FixBot
    3. Google Pixel Watch 5 Battery Replacement, Remove the battery screws: step 11, image 1 of 2 Google Pixel Watch 5 Battery Replacement, Remove the battery screws: step 11, image 2 of 2
      • Use a Torx Plus 2IP screwdriver to remove the two 2.2 mm‑long screws securing the battery.
      Ask FixBot
    4. Google Pixel Watch 5 Battery Replacement, Remove the battery: step 12, image 1 of 3 Google Pixel Watch 5 Battery Replacement, Remove the battery: step 12, image 2 of 3 Google Pixel Watch 5 Battery Replacement, Remove the battery: step 12, image 3 of 3
      • Remove the battery.
      Ask FixBot
For optimal performance, calibrate your newly installed battery after completing this guide.
Carsten Frauenheim
171,827 Reputation
441 Guides authored
0 Guide Comments
Past 24 Hours: 15
Past 7 Days: 157
Past 30 Days: 410
All Time: 687
