Featured Guide
This guide has been found to be exceptionally cool by the iFixit staff.
Introduction
Go to step 1 ↓This repair guide was authored by the iFixit staff and hasn’t been endorsed by Google. Learn more about our repair guides here.
Use this guide to replace a dead or worn-out battery in your Google Pixel Watch 4.
Your watch's battery has a limited lifespan. If your watch doesn't hold a charge or dies unexpectedly, it might be time to replace the battery.
This guide was written using a 41 mm LTE model Pixel Watch 4. While some photos may contain slight visual discrepancies, procedures for all 41 mm and 45 mm models are functionally the same.
Fix Kits
These kits contain all the parts and tools needed to complete this guide.
Parts
Tools
Spudger4.9
Before starting your repair:
Remove your watch from the charger.
Press and hold the crown button, then tap Power off to shut down your watch.
Remove each watch band by depressing the release button and sliding the band out of its groove.
Use a Torx Plus 2IP screwdriver to remove the 3.0 mm‑long screw from both watch band grooves (two screws total).
Make sure the O‑rings are on the screws before installing them.
Push down firmly on the back glass while installing the screws to make sure the glass gets properly seated.
Insert the point of a spudger (or a clean fingernail) into the seam between the back sensor glass and frame and pry up until the cover detaches.
Gently lift the back glass and flip it over the side of the watch opposite the crown.
Use a Torx Plus 2IP screwdriver to remove the two 2.2 mm‑long screws securing the vibration motor.
Gently flip the back sensor glass over the crown-side of the watch.
Use the point of a spudger to pry up and disconnect the battery press connector.
If you're having trouble, loosen the two battery screws and reposition the connector. Once connected, re-tighten the battery screws.
Use a Torx Plus 2IP screwdriver to remove the two 2.2 mm‑long screws securing the battery.
For optimal performance, calibrate your newly installed battery after completing this guide.
2 other people completed this guide.
1 Guide Comment
No adhesive needed? This feels very refreshing, good job google!
