Google Pixel Slate Speaker Replacement
    1. Google Pixel Slate Speaker Replacement, Screen: step 1, image 1 of 3 Google Pixel Slate Speaker Replacement, Screen: step 1, image 2 of 3 Google Pixel Slate Speaker Replacement, Screen: step 1, image 3 of 3
      • Orient the Google Pixel Slate so that the screen is facing upwards.
      • Use the iFixit opening tool to separate screen from main body. The screen is held down by adhesive, you will need to use the iOpener or a heat gun/ hairdryer to soften it. Failure to do this will result in a broken screen.
      • Use the suction cup to remove the screen from the body of the device.
      Ask FixBot
    2. Google Pixel Slate Speaker Replacement: step 2, image 1 of 3 Google Pixel Slate Speaker Replacement: step 2, image 2 of 3 Google Pixel Slate Speaker Replacement: step 2, image 3 of 3
      • Gently disconnect the three flat-wires from the screen.
      • Carefully separate and remove the screen from the body of the device.
      Ask FixBot
    1. Google Pixel Slate Speaker Replacement, Speaker: step 3, image 1 of 3 Google Pixel Slate Speaker Replacement, Speaker: step 3, image 2 of 3 Google Pixel Slate Speaker Replacement, Speaker: step 3, image 3 of 3
      • There are two speakers, one on each side of the Google Pixel Slate. This guide works for either one.
      • Use the T2 Torx screwdriver to remove the yellow 2mm screw from the thin metal plate.
      • Use the T3 Torx screwdriver to remove the pink 3mm screw from the thin metal plate.
      • Remove the thin metal plate from the device.
      Ask FixBot
    2. Google Pixel Slate Speaker Replacement: step 4, image 1 of 1
      • Use the T2 Torx screwdriver to remove the two black 2mm screws from the speaker.
      Ask FixBot
    3. Google Pixel Slate Speaker Replacement: step 5, image 1 of 2 Google Pixel Slate Speaker Replacement: step 5, image 2 of 2
      Tool used on this step:
      Buy
      • Use the Nylon-Tipped Tweezers to remove the black plug.
      • There is a red and a black wire connected to the black plug.
      • Pull the black plug in an upwards direction.
      • Be sure to gently remove plug, as using too much force can damage the connecting wires.
      Ask FixBot
    4. Google Pixel Slate Speaker Replacement: step 6, image 1 of 2 Google Pixel Slate Speaker Replacement: step 6, image 2 of 2
      • Use the Nylon-Tipped Tweezers to disconnect the black tape-like plug connected to the speaker.
      Ask FixBot
    5. Google Pixel Slate Speaker Replacement: step 7, image 1 of 2 Google Pixel Slate Speaker Replacement: step 7, image 2 of 2
      • Detach the speaker wire from the motherboard.
      • Remove the adhesive strips that hold down the speaker wire.
      Ask FixBot
    6. Google Pixel Slate Speaker Replacement: step 8, image 1 of 3 Google Pixel Slate Speaker Replacement: step 8, image 2 of 3 Google Pixel Slate Speaker Replacement: step 8, image 3 of 3
      • Use the T2 Torx screwdriver to remove the 2mm black screw from the brass plate.
      • Pull back the brass plate.
      Ask FixBot
    7. Google Pixel Slate Speaker Replacement: step 9, image 1 of 1
      • You can now remove the speaker from the device.
      Ask FixBot
3 other people completed this guide.
Spencer Alonge
678 Reputation
5 Guides authored
Cal Poly, Team S2-G5, Maness Spring 2019 Member of Cal Poly, Team S2-G5, Maness Spring 2019
CPSU-MANESS-S19S2G5
4 Members
60 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 7
Past 30 Days: 30
All Time: 1,306
