Featured Guide
This guide has been found to be exceptionally cool by the iFixit staff.
Fix Kit
This kit contains all the parts and tools needed to complete this guide.
Parts
Tools
Spudger4.9
Introduction
Go to step 1 ↓This repair guide was authored by the iFixit staff and hasn’t been endorsed by Google. Learn more about our repair guides here.
Use this guide to replace the outer screen in your Google Pixel Fold.
Heat an iOpener and apply it to the bottom edge of the screen for two minutes.
While you're waiting for the adhesive to soften, note the following:
The adhesive is under the dark black border surrounding the screen.
Apply a suction cup to the screen, as close to the center of the bottom edge as possible.
Pull up on the suction cup with strong, steady force to create a gap between the screen and the frame.
Insert an opening pick into the gap.
Slide the opening pick along the bottom edge to separate the adhesive.
Leave the opening pick in the bottom right corner before continuing.
Apply a heated iOpener to the right edge of the screen for two minutes.
Rotate the opening pick around the bottom right corner to separate the adhesive.
Insert a new opening pick in the bottom right corner.
Slide the opening pick toward the top right corner to separate the adhesive.
Leave the opening pick in the top right corner before continuing.
Rotate the opening pick around the top right corner to separate its adhesive.
Insert a new opening pick in the top right corner.
Slide the opening pick toward the top left corner to separate its adhesive.
Apply a heated iOpener to the left edge of the screen for two minutes.
Angle your pick so it's as flat as possible to the screen.
Rotate the opening pick around the top left corner to separate the adhesive.
Insert a new opening pick in the top left corner.
Slide the opening pick toward the bottom left corner to separate the adhesive.
Rotate the opening pick around the bottom left corner to separate the adhesive.
There's a small adhesive strip that secures the screen near the top right corner of the phone.
Heat an iOpener and apply it to the top right corner of the screen for two minutes.
Insert an opening pick under the right edge of the screen, near the top right corner.
Push the opening pick under the screen as far you can go without losing your grip.
Swing the left edge of the screen up and over the right edge of the phone.
Let the screen rest next to the phone before continuing.
Tool used on this step:FixMat$31.41
Use a Torx Plus 3IP screwdriver to remove the five 2.5 mm‑long screws securing the bottom bracket.
Tool used on this step:Tweezers$4.99
Use tweezers, or your fingers, to remove the bottom bracket.
Use the flat end of a spudger to pry up and disconnect the flip battery press connector.
Insert the point of a spudger under the short edge of the screen press connector facing the bottom of the phone.
Pry up to disconnect the screen press connector.
Remove the screen.
When handling your screen, grip it by its edges.
When placing the screen on your work area, make sure nothing is touching the bottom of the screen. Consider placing it on a soft, lint-free cloth.
Tool used on this step:Tesa 61395 Tape$8.95
If you're reusing your screen, use tweezers to remove big chunks of adhesive from the perimeter of the screen.
Repeat for any adhesive on the frame, including the small adhesive at the top right of the phone.
Use isopropyl alcohol (>90%) and a lint-free cloth to remove any remaining adhesive residue.
Follow this guide to replace your screen adhesive.
Compare your new replacement part to the original part—you may need to transfer remaining components or remove adhesive backings from the new part before you install it.
To run a diagnostics test with the built-in Pixel Diagnostic tool, click here.
Repair didn’t go as planned? Try some basic troubleshooting, or ask our Google Pixel Fold Answers Community for help.
7 other people completed this guide.
3 Guide Comments
palecho cell
Please note that if you use a new screen, it may already have adhesive applied to it. If so, you can potentially skip the step of perfectly aligning the adhesive that the kit comes with... Until you realize you forgot to replace the bottom bracket and have to open your phone up again. 😅
