Up to 20% off select tools
Google Pixel C Screen Replacement
Views: 20K
View statistics:
Past 24 Hours:
3
Past 7 Days:
21
Past 30 Days:
133
All Time:
20,093
Comments: 32
4 comments on steps, 28 guide comments.
Go to guide comments
Completed: 9
9 people have marked this guide "completed." Will you be next?
Favorites: 4
4 people have favorited (and subscribed to) this guide. Will you be next?
Time Required: 10 - 15 minutes
Difficulty: Moderate
Featured Student Guide
This guide has been the hard work of our awesome students and is found to be exceptionally cool by the iFixit staff.
Tools
Introduction
Go to step 1 ↓
This guide will outline how to replace a cracked, shattered, or faulty screen on a Google Pixel C.
    1. Google Pixel C Screen Replacement, Screen: step 1, image 1 of 1
      • Ensure that the device is completely powered down before beginning to take it apart
      • Use a heat gun to melt the adhesive that holds the screen to the device
      • Move the heat gun around the edge of the screen for approximately 1 minute, or until the screen can be lifted off in the next step.
      • Make sure not to heat the screen for too long because too much can damage other components inside the tablet.
      Ask FixBot
    2. Google Pixel C Screen Replacement: step 2, image 1 of 2 Google Pixel C Screen Replacement: step 2, image 2 of 2
      • Use a suction cup to assist in lifting the screen while prying around its edges with a plastic spudger.
      • If necessary use a metal spudger to pry the screen up, taking care not to scratch the device.
      • Be careful not to pull the screen too far off. It will still be attached to the device by a cable for the front facing camera and the wide display data cable.
      • Reattaching the screen will require adhesive to ensure that it stays in place.
      Ask FixBot
    3. Google Pixel C Screen Replacement: step 3, image 1 of 2 Google Pixel C Screen Replacement: step 3, image 2 of 2
      • Detach the cables for the camera by lifting the small flap using the tip of your fingernail or a spudger. Gently pull the ribbon cable out.
      Ask FixBot
    4. Google Pixel C Screen Replacement: step 4, image 1 of 2 Google Pixel C Screen Replacement: step 4, image 2 of 2
      Tool used on this step:
      Buy
      • Follow the same removal procedure to detach the wide gold cable.
      • When reattaching cables, it is helpful to use tweezers to slide the cable in before securing it down with the flap.
      • This device is missing a battery, so the device that you are working on may appear slightly different inside.
      Ask FixBot
9 other people completed this guide.
Author
with
Deborah Iwakiri
522 Reputation
2 Guides authored
Cal Poly, Team S21-G4, Livingston Spring 2017 Member of Cal Poly, Team S21-G4, Livingston Spring 2017
CPSU-LIVINGSTON-S17S21G4
4 Members
60 Guides authored
28 Guide Comments
Where can a replacement screen be located?
Ronnie Williams - Reply Share
Where can i buy a spare screen for this tablet?
Luigi Abbinante - Reply Share
Yes, I have to buy the screen too, but where??
Кирилл Кнышев - Reply Share
All very nice but unfortunately useless without knowing where to get the parts :(
Lorenzo Braschi - Reply Share
Ciao Lorenzo, sei poi riuscito a trovare il ricambio?
Past 24 Hours: 3
Past 7 Days: 21
Past 30 Days: 133
All Time: 20,093
