Tools
Spudger4.9
Introduction
Go to step 1 ↓This guide will outline how to fix the keyboard in the event that it is nonresponsive.
Heat the black plastic strip on the front lower edge of the keyboard with an iOpener to weaken the adhesive holding it down.
2 other people completed this guide.
1 Guide Comment
Uninstall a Pixel c's keyboard case's battery system,The Battery is out of life, but the case cost Pixel c's power while closed. No suitable battery to replace temporarily. Use a Hot Gun with higher temparature but control the temparature not too high then you will easily peal off the skin but no any broken and finally you can adhere it back to normal.Finished and accept. Now I just use the case as a case only and no need consider it cost the power.
