Google Pixel C Headphone Jack Replacement
    1. Google Pixel C Headphone Jack Replacement, Screen: step 1, image 1 of 1
      • Ensure that the device is completely powered down before beginning to take it apart
      • Use a heat gun to melt the adhesive that holds the screen to the device
      • Move the heat gun around the edge of the screen for approximately 1 minute, or until the screen can be lifted off in the next step.
      • Make sure not to heat the screen for too long because too much can damage other components inside the tablet.
      Ask FixBot
    2. Google Pixel C Headphone Jack Replacement: step 2, image 1 of 2 Google Pixel C Headphone Jack Replacement: step 2, image 2 of 2
      • Use a suction cup to assist in lifting the screen while prying around its edges with a plastic spudger.
      • If necessary use a metal spudger to pry the screen up, taking care not to scratch the device.
      • Be careful not to pull the screen too far off. It will still be attached to the device by a cable for the front facing camera and the wide display data cable.
      • Reattaching the screen will require adhesive to ensure that it stays in place.
      Ask FixBot
    3. Google Pixel C Headphone Jack Replacement: step 3, image 1 of 2 Google Pixel C Headphone Jack Replacement: step 3, image 2 of 2
      • Detach the cables for the camera by lifting the small flap using the tip of your fingernail or a spudger. Gently pull the ribbon cable out.
      Ask FixBot
    4. Google Pixel C Headphone Jack Replacement: step 4, image 1 of 2 Google Pixel C Headphone Jack Replacement: step 4, image 2 of 2
      Tool used on this step:
      Buy
      • Follow the same removal procedure to detach the wide gold cable.
      • When reattaching cables, it is helpful to use tweezers to slide the cable in before securing it down with the flap.
      • This device is missing a battery, so the device that you are working on may appear slightly different inside.
      Ask FixBot
    1. Google Pixel C Headphone Jack Replacement, Headphone Jack: step 5, image 1 of 1
      • Orient the device so that the headphone jack is in the bottom right corner.
      Ask FixBot
    2. Google Pixel C Headphone Jack Replacement: step 6, image 1 of 2 Google Pixel C Headphone Jack Replacement: step 6, image 2 of 2
      • Remove the two 3.5mm Phillips #000 screws.
      Ask FixBot
    3. Google Pixel C Headphone Jack Replacement: step 7, image 1 of 1
      • Locate and remove the two 2.5mm Phillips #000 screws on either side of the wire coil.
      Ask FixBot
    4. Google Pixel C Headphone Jack Replacement: step 8, image 1 of 2 Google Pixel C Headphone Jack Replacement: step 8, image 2 of 2
      • Detach the red and black cable using a narrow spudger.
      Ask FixBot
    5. Google Pixel C Headphone Jack Replacement: step 9, image 1 of 2 Google Pixel C Headphone Jack Replacement: step 9, image 2 of 2
      • Detach the cable connecting to the headphone jack.
      Ask FixBot
    6. Google Pixel C Headphone Jack Replacement: step 10, image 1 of 2 Google Pixel C Headphone Jack Replacement: step 10, image 2 of 2
      • Lift the headphone jack, coiled wire, and cable, peeling the adhesive back.
      • Reassembly will require adhesive to ensure that the components are secured to the device.
      Ask FixBot
Deborah Iwakiri
522 Reputation
2 Guides authored
Cal Poly, Team S21-G4, Livingston Spring 2017 Member of Cal Poly, Team S21-G4, Livingston Spring 2017
CPSU-LIVINGSTON-S17S21G4
4 Members
60 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 6
Past 30 Days: 24
All Time: 1,404
