Google Pixel Buds 2a Charging Case Battery Replacement
    1. Google Pixel Buds 2a Charging Case Battery Replacement, Unplug the charging case: step 1, image 1 of 1
      • Before starting your repair, unplug your charging case.
      Ask FixBot
    2. Google Pixel Buds 2a Charging Case Battery Replacement, Remove the Buds: step 2, image 1 of 3 Google Pixel Buds 2a Charging Case Battery Replacement, Remove the Buds: step 2, image 2 of 3 Google Pixel Buds 2a Charging Case Battery Replacement, Remove the Buds: step 2, image 3 of 3
      • Open the case lid, remove the Pixel Buds, and set them aside.
      Ask FixBot
    3. Google Pixel Buds 2a Charging Case Battery Replacement, Remove the case screws: step 3, image 1 of 3 Google Pixel Buds 2a Charging Case Battery Replacement, Remove the case screws: step 3, image 2 of 3 Google Pixel Buds 2a Charging Case Battery Replacement, Remove the case screws: step 3, image 3 of 3
      • Use a T5 Torx screwdriver to remove the two 6.2 mm‑long screws from the ear bud recesses.
      • You may need to flip the case over and gently shake it to get the screws to fall out.
      Ask FixBot
    4. Google Pixel Buds 2a Charging Case Battery Replacement, Remove the bottom shell: step 4, image 1 of 3 Google Pixel Buds 2a Charging Case Battery Replacement, Remove the bottom shell: step 4, image 2 of 3 Google Pixel Buds 2a Charging Case Battery Replacement, Remove the bottom shell: step 4, image 3 of 3
      • Slide the main body of the charging case completely out of the bottom shell, inserting a fingernail in the seam near the top of the case to create an initial gap.
      • If you're having trouble, use the flat end of a spudger to start the initial gap.
      Ask FixBot
    1. Google Pixel Buds 2a Charging Case Battery Replacement, Remove the battery: step 5, image 1 of 3 Google Pixel Buds 2a Charging Case Battery Replacement, Remove the battery: step 5, image 2 of 3 Google Pixel Buds 2a Charging Case Battery Replacement, Remove the battery: step 5, image 3 of 3
      • Grip the small green tab on the back of the charging case and pull the battery out of its recess.
      • The battery fits snugly in place—this may take a little bit of force.
      Ask FixBot
Spencer Day
197,712 Reputation
1,243 Guides authored
1 Guide Comment
Great instructions, am I missing something because surely we'd need to know what cell is needed for replacement.
D R - Reply Share
Past 24 Hours: 8
Past 7 Days: 33
Past 30 Days: 168
All Time: 2,262
