Google Pixel 9 Pro XL Rear Cover Replacement
    1. Google Pixel 9 Pro XL Rear Cover Replacement, Safety precautions: step 1, image 1 of 2 Google Pixel 9 Pro XL Rear Cover Replacement, Safety precautions: step 1, image 2 of 2
      • Let your Pixel's battery drain below 25% before starting this repair. A charged lithium‑ion battery may catch fire if damaged.
      • Unplug all cables and completely power down your phone.
      Ask FixBot
    1. Google Pixel 9 Pro XL Rear Cover Replacement, Adhesive information: step 2, image 1 of 3 Google Pixel 9 Pro XL Rear Cover Replacement, Adhesive information: step 2, image 2 of 3 Google Pixel 9 Pro XL Rear Cover Replacement, Adhesive information: step 2, image 3 of 3
      • Adhesive secures the perimeter of the rear cover to the frame.
      • When separating the adhesive, don't insert your tool more than 3 mm under the rear cover to avoid damaging the internal components.
      • Measure 3 mm from the tip and mark your opening pick with a permanent marker. Alternatively, you can tape a coin to a pick 3 mm from the tip.
      Ask FixBot
    2. Google Pixel 9 Pro XL Rear Cover Replacement, Apply a suction handle: step 3, image 1 of 2 Google Pixel 9 Pro XL Rear Cover Replacement, Apply a suction handle: step 3, image 2 of 2
      • Attach a suction handle to the bottom edge of the rear cover, as close to the edge as possible.
      Ask FixBot
    3. Google Pixel 9 Pro XL Rear Cover Replacement, Insert an opening pick: step 4, image 1 of 3 Google Pixel 9 Pro XL Rear Cover Replacement, Insert an opening pick: step 4, image 2 of 3 Google Pixel 9 Pro XL Rear Cover Replacement, Insert an opening pick: step 4, image 3 of 3
      • Pull up on the suction handle with strong, steady force to create a small gap under the rear cover.
      • Insert the tip of an opening pick in the gap.
      Ask FixBot
    4. Google Pixel 9 Pro XL Rear Cover Replacement, Separate the rear cover adhesive: step 5, image 1 of 3 Google Pixel 9 Pro XL Rear Cover Replacement, Separate the rear cover adhesive: step 5, image 2 of 3 Google Pixel 9 Pro XL Rear Cover Replacement, Separate the rear cover adhesive: step 5, image 3 of 3
      • Slide your opening pick along the bottom edge to separate the adhesive securing it.
      • Remember: don't insert the opening pick deeper than 3 mm.
      Ask FixBot
    5. Google Pixel 9 Pro XL Rear Cover Replacement: step 6, image 1 of 3 Google Pixel 9 Pro XL Rear Cover Replacement: step 6, image 2 of 3 Google Pixel 9 Pro XL Rear Cover Replacement: step 6, image 3 of 3
      • Slide your opening pick up the left edge and along the top edge to separate the adhesive.
      Ask FixBot
    6. Google Pixel 9 Pro XL Rear Cover Replacement: step 7, image 1 of 3 Google Pixel 9 Pro XL Rear Cover Replacement: step 7, image 2 of 3 Google Pixel 9 Pro XL Rear Cover Replacement: step 7, image 3 of 3
      • Slide your pick down the right edge to separate the remaining adhesive.
      Ask FixBot
    1. Google Pixel 9 Pro XL Rear Cover Replacement, Prop up the rear cover: step 8, image 1 of 3 Google Pixel 9 Pro XL Rear Cover Replacement, Prop up the rear cover: step 8, image 2 of 3 Google Pixel 9 Pro XL Rear Cover Replacement, Prop up the rear cover: step 8, image 3 of 3
      • Don't try to fully remove the rear cover yet, as a ribbon cable on the right edge connects it to the phone.
      • Use the suction handle to lift the left edge of the rear cover and swing it over the right edge, like opening the cover of a book.
      • If you're having trouble, check the perimeter for any remaining adhesive and use your opening pick to separate it.
      • Prop up the rear cover with the suction handle so you can access the ribbon cable near the top right corner.
      Ask FixBot
    2. Google Pixel 9 Pro XL Rear Cover Replacement, Remove the cable cover: step 9, image 1 of 2 Google Pixel 9 Pro XL Rear Cover Replacement, Remove the cable cover: step 9, image 2 of 2
      • Use a Torx Plus 3IP screwdriver to remove the two 5.2 mm‑long screws securing the cable cover.
      Ask FixBot
    3. Google Pixel 9 Pro XL Rear Cover Replacement: step 10, image 1 of 2 Google Pixel 9 Pro XL Rear Cover Replacement: step 10, image 2 of 2
      • Use tweezers or your fingers to remove the cable cover.
      Ask FixBot
    4. Google Pixel 9 Pro XL Rear Cover Replacement, Disconnect the rear cover: step 11, image 1 of 3 Google Pixel 9 Pro XL Rear Cover Replacement, Disconnect the rear cover: step 11, image 2 of 3 Google Pixel 9 Pro XL Rear Cover Replacement, Disconnect the rear cover: step 11, image 3 of 3
      • Use the point of a spudger to pry up and disconnect the rear cover press connector.
      Ask FixBot
    5. Google Pixel 9 Pro XL Rear Cover Replacement, Remove the rear cover: step 12, image 1 of 1
      • Remove the rear cover.
      • During reassembly, follow this guide to apply new adhesive and install your back cover.
      Ask FixBot
To reassemble your device, follow this guide.
To run a diagnostics test with the built-in Pixel Diagnostic tool, click here.
9 other people completed this guide.
Spencer Day
206,456 Reputation
1,266 Guides authored
iFixit Member of iFixit
Staff
121 Members
72,737 Guides authored
5 Guide Comments
User Torx Plus 3IP screwdriver? I don't find the screwdriver anywhere . Can I use one screw from this toolkit? If so, which one? - Essential Electronics Toolkit
Ram A - Reply Share
Hi Ram. The Torx Plus 3IP bit (not driver) and many other bits are available here on our site. We also have drivers, in both aluminum and plastic.
Spencer Day - Reply Share
Does the rear cover come with glue? Or I have to buy the separately?
Bruno Llangostera Prats - Reply Share
ifixit's instructions that show a suction cup to remove a screen or a glass back always assume your glass is intact. I would assume most often it is shattered so forget using a suction cup. I used some thick shipping tape to cover the broken glass which gives the suction cup a chance to hold.
Scott Z - Reply Share
Easy guide to follow. I was able to replace my back glass due to the camera bar separating from the glass. Thank you!
David Z - Reply Share
Past 24 Hours: 23
Past 7 Days: 123
Past 30 Days: 533
All Time: 10,004
