Up to 20% off select tools
Google Pixel 9 Pro Rear Cover Replacement
Views: 9.9K
View statistics:
Past 24 Hours:
10
Past 7 Days:
95
Past 30 Days:
427
All Time:
9,866
Comments: 5
5 comments on steps.
Completed: 4
4 people have marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 45 minutes - 1 hour
Difficulty: Moderate
Featured Guide
This guide has been found to be exceptionally cool by the iFixit staff.
Parts
Tools
Introduction
Go to step 1 ↓
This repair guide was authored by the iFixit staff and hasn’t been endorsed by Google. Learn more about our repair guides here.
Follow this guide to replace a broken or cracked rear cover on your Google Pixel 9 Pro.
You'll need replacement rear cover adhesive to complete this repair.
Note: Any repair can compromise the water resistance of your phone. Retaining water resistance after the repair will depend on how well you reapply the rear cover adhesive.
    1. Google Pixel 9 Pro Rear Cover Replacement, Safety precautions: step 1, image 1 of 2 Google Pixel 9 Pro Rear Cover Replacement, Safety precautions: step 1, image 2 of 2
      • Let your Pixel's battery drain below 25% before starting this repair. A charged lithium‑ion battery may catch fire if damaged.
      • Unplug all cables and completely power down your phone.
      Ask FixBot
    1. Google Pixel 9 Pro Rear Cover Replacement, Adhesive information: step 2, image 1 of 3 Google Pixel 9 Pro Rear Cover Replacement, Adhesive information: step 2, image 2 of 3 Google Pixel 9 Pro Rear Cover Replacement, Adhesive information: step 2, image 3 of 3
      • Adhesive secures the perimeter of the rear cover to the frame.
      • When separating the adhesive, don't insert your tool more than 3 mm under the rear cover to avoid damaging the internal components.
      • Measure 3 mm from the tip and mark your opening pick with a permanent marker. Alternatively, you can tape a coin to a pick 3 mm from the tip.
      Ask FixBot
    2. Google Pixel 9 Pro Rear Cover Replacement, Apply a suction handle: step 3, image 1 of 2 Google Pixel 9 Pro Rear Cover Replacement, Apply a suction handle: step 3, image 2 of 2
      • Attach a suction handle to the bottom edge of the rear cover, as close to the edge as possible.
      Ask FixBot
    3. Google Pixel 9 Pro Rear Cover Replacement, Insert an opening pick: step 4, image 1 of 3 Google Pixel 9 Pro Rear Cover Replacement, Insert an opening pick: step 4, image 2 of 3 Google Pixel 9 Pro Rear Cover Replacement, Insert an opening pick: step 4, image 3 of 3
      • Pull up on the suction handle with strong, steady force to create a small gap under the rear cover.
      • Insert the tip of an opening pick in the gap.
      Ask FixBot
    4. Google Pixel 9 Pro Rear Cover Replacement, Separate the rear cover adhesive: step 5, image 1 of 3 Google Pixel 9 Pro Rear Cover Replacement, Separate the rear cover adhesive: step 5, image 2 of 3 Google Pixel 9 Pro Rear Cover Replacement, Separate the rear cover adhesive: step 5, image 3 of 3
      • Slide your opening pick along the bottom edge to separate the adhesive securing it.
      • Remember: don't insert the opening pick deeper than 3 mm.
      Ask FixBot
    5. Google Pixel 9 Pro Rear Cover Replacement: step 6, image 1 of 3 Google Pixel 9 Pro Rear Cover Replacement: step 6, image 2 of 3 Google Pixel 9 Pro Rear Cover Replacement: step 6, image 3 of 3
      • Slide your opening pick up the left edge and along the top edge to separate the adhesive.
      Ask FixBot
    6. Google Pixel 9 Pro Rear Cover Replacement: step 7, image 1 of 3 Google Pixel 9 Pro Rear Cover Replacement: step 7, image 2 of 3 Google Pixel 9 Pro Rear Cover Replacement: step 7, image 3 of 3
      • Slide your pick down the right edge to separate the remaining adhesive.
      Ask FixBot
    1. Google Pixel 9 Pro Rear Cover Replacement, Prop up the rear cover: step 8, image 1 of 3 Google Pixel 9 Pro Rear Cover Replacement, Prop up the rear cover: step 8, image 2 of 3 Google Pixel 9 Pro Rear Cover Replacement, Prop up the rear cover: step 8, image 3 of 3
      • Don't try to fully remove the rear cover yet, as a ribbon cable on the right edge connects it to the phone.
      • Use the suction handle to lift the left edge of the rear cover and swing it over the right edge, like opening the cover of a book.
      • If you're having trouble, check the perimeter for any remaining adhesive and use your opening pick to separate it.
      • Prop up the rear cover with the suction handle so you can access the ribbon cable near the top right corner.
      Ask FixBot
    2. Google Pixel 9 Pro Rear Cover Replacement, Remove the wireless charging assembly: step 9, image 1 of 2 Google Pixel 9 Pro Rear Cover Replacement, Remove the wireless charging assembly: step 9, image 2 of 2
      Tool used on this step:
      FixMat
      $31.41
      Buy
      • While the Pixel 9 Pro uses Torx Plus screws, standard Torx bits will also work. Make sure to apply constant, downward force to prevent stripping.
      • Use a Torx Plus 3IP screwdriver to remove the five screws securing the wireless charging assembly:
      • Four 5.4 mm‑long screws
      • One 1.5 mm‑long screw
      • This screw is non‑magnetic—you may need to use tweezers to remove it.
      Ask FixBot
    3. Google Pixel 9 Pro Rear Cover Replacement: step 10, image 1 of 3 Google Pixel 9 Pro Rear Cover Replacement: step 10, image 2 of 3 Google Pixel 9 Pro Rear Cover Replacement: step 10, image 3 of 3
      • Be very careful not to damage the spring contacts under the top left edge of the wireless charging assembly.
      • Use tweezers or your fingers to remove the wireless charging assembly.
      Ask FixBot
    1. Google Pixel 9 Pro Rear Cover Replacement, Disconnect the rear cover: step 11, image 1 of 3 Google Pixel 9 Pro Rear Cover Replacement, Disconnect the rear cover: step 11, image 2 of 3 Google Pixel 9 Pro Rear Cover Replacement, Disconnect the rear cover: step 11, image 3 of 3
      • Insert the tip of an opening pick under the left edge of the rear cover press connector and pry straight up to disconnect it.
      Ask FixBot
    2. Google Pixel 9 Pro Rear Cover Replacement, Remove the rear cover: step 12, image 1 of 1
      • Remove the rear cover.
      • During reassembly, follow this guide to apply new adhesive and install your rear cover.
      Ask FixBot
To reassemble your device, follow this guide.
To run a diagnostics test with the built-in Pixel Diagnostic tool, click here.
4 other people completed this guide.
Author
with
Spencer Day
210,836 Reputation
1,265 Guides authored
iFixit Member of iFixit
Staff
119 Members
72,966 Guides authored
0 Guide Comments
Past 24 Hours: 10
Past 7 Days: 95
Past 30 Days: 427
All Time: 9,866
