Google Pixel 7 Motherboard Replacement
    1. Google Pixel 7 Motherboard Replacement, Safety precautions: step 1, image 1 of 2 Google Pixel 7 Motherboard Replacement, Safety precautions: step 1, image 2 of 2
      • Allow your battery to drain below 25% before starting this repair. A charged battery may catch fire if damaged.
      • Fully power off your phone and unplug any cables.
      Ask FixBot
    2. Google Pixel 7 Motherboard Replacement, Screen removal information: step 2, image 1 of 3 Google Pixel 7 Motherboard Replacement, Screen removal information: step 2, image 2 of 3 Google Pixel 7 Motherboard Replacement, Screen removal information: step 2, image 3 of 3
      • The screen of the Google Pixel 7 is held in place by a safety frame of plastic clips and adhesive.
      • During the removal procedure, make sure to insert your opening picks under the safety frame to avoid separating it from the screen.
      • Only insert the pick up to ~3.5 mm during the removal procedure to avoid damaging the internals and to avoid interfering with the plastic clips.
      • There are several plastic clips around the whole screen. In case your opening pick gets blocked during the screen removal procedure it means you inserted your pick too deep underneath the screen.
      Ask FixBot
    3. Google Pixel 7 Motherboard Replacement, Anti-Clamp instructions: step 3, image 1 of 3 Google Pixel 7 Motherboard Replacement, Anti-Clamp instructions: step 3, image 2 of 3 Google Pixel 7 Motherboard Replacement, Anti-Clamp instructions: step 3, image 3 of 3
      Tool used on this step:
      Clampy - Anti-Clamp
      $24.95
      Buy
      • The next three steps demonstrate the Anti-Clamp, a tool we designed to make the opening procedure easier. If you aren't using the Anti-Clamp, skip down three steps for an alternate method.
      • For complete instructions on how to use the Anti-Clamp, check out this guide.
      • If your screen is cracked, cover it with a layer of clear packing tape to help the suction cup adhere.
      • Pull the blue handle backwards to unlock the Anti-Clamp's arms.
      • Slide the arms over either the left or right edge of your phone.
      • Position the suction cups near the bottom edge of the phone—one on the front, and one on the back.
      • Squeeze the cups together to apply suction.
      • If you find that the surface of your phone is too slippery for the Anti-Clamp to hold onto, you can use tape to create a grippier surface.
      Ask FixBot
    4. Google Pixel 7 Motherboard Replacement: step 4, image 1 of 3 Google Pixel 7 Motherboard Replacement: step 4, image 2 of 3 Google Pixel 7 Motherboard Replacement: step 4, image 3 of 3
      • Pull the blue handle forward to lock the arms.
      • Turn the handle clockwise 360 degrees or until the cups start to stretch.
      • Make sure the suction cups remain aligned with each other. If they begin to slip out of alignment, loosen the suction cups slightly and realign the arms.
      Ask FixBot
    5. Google Pixel 7 Motherboard Replacement: step 5, image 1 of 3 Google Pixel 7 Motherboard Replacement: step 5, image 2 of 3 Google Pixel 7 Motherboard Replacement: step 5, image 3 of 3
      • Heat an iOpener and thread it through the arms of the Anti-Clamp.
      • You can also use a hair dryer or heat gun—but extreme heat can damage the display and/or internal battery, so proceed with care.
      • Fold the iOpener so it lays on the bottom edge of the phone.
      • Wait one minute to give the adhesive a chance to release and present an opening gap.
      • Insert an opening pick under the screen frame when the Anti-Clamp creates a large enough gap.
      • If the Anti-Clamp doesn't create a sufficient gap, apply more heat to the area and rotate the handle clockwise half a turn.
      • Don't crank more than a half a turn at a time, and wait one minute between turns. Let the Anti-Clamp and time do the work for you.
      • Skip the next two steps.
      Ask FixBot
    6. Google Pixel 7 Motherboard Replacement, Loosen the display adhesive: step 6, image 1 of 1
      • Apply a heated iOpener to the screen to loosen the adhesive underneath. Apply the iOpener for at least 3 minutes.
      • A hair dryer, heat gun, or hot plate may also be used, but be careful not to overheat the device. The edge should feel slightly too hot to the touch.
      Ask FixBot
    7. Google Pixel 7 Motherboard Replacement, Insert an opening pick: step 7, image 1 of 3 Google Pixel 7 Motherboard Replacement, Insert an opening pick: step 7, image 2 of 3 Google Pixel 7 Motherboard Replacement, Insert an opening pick: step 7, image 3 of 3
      • Once the screen is warm to the touch, apply a suction handle to the bottom edge of the screen.
      • If your display is badly cracked, covering it with a layer of clear packing tape may allow the suction cup to adhere. Alternatively, very strong tape may be used instead of the suction cup. If all else fails, you can superglue the suction cup to the broken screen.
      • Lift the screen including its safety frame with the suction handle to create a small gap between the screen and the phone assembly.
      • Depending on the age of your phone, this may be difficult. If you're having trouble, apply more heat to the bottom edge and try again.
      • Insert an opening pick into the gap.
      Ask FixBot
    8. Google Pixel 7 Motherboard Replacement, Prevent damage to your phone: step 8, image 1 of 2 Google Pixel 7 Motherboard Replacement, Prevent damage to your phone: step 8, image 2 of 2
      • To avoid damaging your phone, don't insert your pick more than ~2.5 mm as you separate the screen adhesive. Note the following areas:
      • The screen cable is a little less than halfway up the left edge of the phone. Be very careful here to avoid tearing the cable.
      • There are many spring contacts around the perimeter of the phone. Be very careful in these areas to avoid bending the contacts.
      Ask FixBot
    9. Google Pixel 7 Motherboard Replacement, Slice the bottom edge adhesive: step 9, image 1 of 2 Google Pixel 7 Motherboard Replacement, Slice the bottom edge adhesive: step 9, image 2 of 2
      • Slide the opening pick to the bottom right corner of the screen to slice its adhesive.
      • Leave the opening pick in place to prevent the adhesive from resealing.
      Ask FixBot
    10. Google Pixel 7 Motherboard Replacement: step 10, image 1 of 2 Google Pixel 7 Motherboard Replacement: step 10, image 2 of 2
      • Insert a second opening pick at the bottom edge and slide it to the bottom left corner of the screen to slice the adhesive.
      Ask FixBot
    11. Google Pixel 7 Motherboard Replacement, Release the left clips: step 11, image 1 of 3 Google Pixel 7 Motherboard Replacement, Release the left clips: step 11, image 2 of 3 Google Pixel 7 Motherboard Replacement, Release the left clips: step 11, image 3 of 3
      • Insert a third opening pick underneath the bottom left corner of the screen.
      • Slide the opening pick along the left edge of the screen to slice the adhesive and to release the plastic clips.
      • Leave the opening pick in the top left corner to prevent the adhesive from resealing.
      Ask FixBot
    12. Google Pixel 7 Motherboard Replacement, Slice the top edge adhesive: step 12, image 1 of 3 Google Pixel 7 Motherboard Replacement, Slice the top edge adhesive: step 12, image 2 of 3 Google Pixel 7 Motherboard Replacement, Slice the top edge adhesive: step 12, image 3 of 3
      • If the adhesive becomes hard to cut, it has most likely cooled down. Use your iOpener or heat gun for 1-2 minutes to reheat it.
      • When you slice near the front facing camera, insert only the tip of the opening pick (~2.5 mm) to avoid damaging or smearing the camera.
      • Insert a fourth opening pick at the top left corner of the screen.
      • Slide the opening pick along the top edge of the phone to slice the adhesive.
      • Leave the opening pick in the top right corner to prevent the adhesive from resealing.
      Ask FixBot
    13. Google Pixel 7 Motherboard Replacement, Release the right clips: step 13, image 1 of 3 Google Pixel 7 Motherboard Replacement, Release the right clips: step 13, image 2 of 3 Google Pixel 7 Motherboard Replacement, Release the right clips: step 13, image 3 of 3
      • Insert a fifth opening pick and slide it along the right edge of the phone to slice the remaining adhesive and release the right plastic clips.
      • Do not try to remove the display all the way yet, the screen is still connected to the phone assembly by a flex cable.
      Ask FixBot
    14. Google Pixel 7 Motherboard Replacement, Open up the phone assembly: step 14, image 1 of 3 Google Pixel 7 Motherboard Replacement, Open up the phone assembly: step 14, image 2 of 3 Google Pixel 7 Motherboard Replacement, Open up the phone assembly: step 14, image 3 of 3
      • Lift the right edge of the screen up and towards the left side of the device, like opening a book.
      • Don't twist the screen or move it too far away from the frame to avoid straining or damaging the flex cable.
      • Rest the screen upside down and parallel to the frame before continuing.
      Ask FixBot
    15. Google Pixel 7 Motherboard Replacement, Release the display cable bracket: step 15, image 1 of 2 Google Pixel 7 Motherboard Replacement, Release the display cable bracket: step 15, image 2 of 2
      Buy
      • The display cable bracket sits tightly and requires some force to release it.
      • Insert one arm of a pair of tweezers into the opening at the upper end of the display cable bracket.
      • Push the bracket inwards and pry up to release it.
      Ask FixBot
    16. Google Pixel 7 Motherboard Replacement, Remove the display cable bracket: step 16, image 1 of 2 Google Pixel 7 Motherboard Replacement, Remove the display cable bracket: step 16, image 2 of 2
      • Use a pair of tweezers to remove the display cable bracket by pulling it from underneath the midframe and in direction of the cameras.
      Ask FixBot
    17. Google Pixel 7 Motherboard Replacement, Disconnect the display cable: step 17, image 1 of 2 Google Pixel 7 Motherboard Replacement, Disconnect the display cable: step 17, image 2 of 2
      • Use a spudger to disconnect the display flex cable by prying the connector straight up from its socket.
      • To re-attach press connectors like this one, carefully align and press down on one side until it clicks into place, then repeat on the other side. Do not press down on the middle. If the connector is misaligned, the pins can bend, causing permanent damage.
      Ask FixBot
    18. Google Pixel 7 Motherboard Replacement, Screen information: step 18, image 1 of 1
      • The back of the Pixel's screen is very fragile. Even a small scratch or dent can damage the screen.
      • To prevent damaging your screen or replacement screen:
      • When handling your screen, grip it by its edges.
      • When placing the screen on your work area, make sure nothing is touching the bottom of the screen. Consider placing it on a soft, lint-free cloth.
      Ask FixBot
    1. Google Pixel 7 Motherboard Replacement, Separate the screen: step 19, image 1 of 1
      • Separate the screen from the phone.
      • During reassembly:
      • Check that all screws are tightened and there are no loose parts.
      • Reconnect the screen and test your phone to make sure it works. Power it back down and continue reassembly.
      • Apply new adhesive where it's necessary after cleaning the relevant areas with isopropyl alcohol (>90%).
      • Follow this guide if you're using custom-cut adhesives for your device.
      • Follow this guide if you're using a pre-cut adhesive card.
      • During the boot-up process after reassembly, the screen will go through a calibration sequence. Do not touch the screen during this process, as it could result in improper touch calibration and create touch issues.
      Ask FixBot
    1. Google Pixel 7 Motherboard Replacement, Remove the black silicone pad: step 20, image 1 of 3 Google Pixel 7 Motherboard Replacement, Remove the black silicone pad: step 20, image 2 of 3 Google Pixel 7 Motherboard Replacement, Remove the black silicone pad: step 20, image 3 of 3
      Buy
      • Take care not to puncture or bend the battery with your tool in the following steps—a punctured or bent battery may leak dangerous chemicals or cause a fire.
      • Use a pair of tweezers to peel the black silicone pad off the battery and midframe.
      Ask FixBot
    2. Google Pixel 7 Motherboard Replacement, Peel off the upper graphite foil: step 21, image 1 of 3 Google Pixel 7 Motherboard Replacement, Peel off the upper graphite foil: step 21, image 2 of 3 Google Pixel 7 Motherboard Replacement, Peel off the upper graphite foil: step 21, image 3 of 3
      • Use a pair of tweezers to carefully peel the upper graphite foil off the battery and midframe.
      • If you're having a hard time peeling off the foil, apply a heated iOpener to the foil for two minutes to loosen its adhesive.
      Ask FixBot
    1. Google Pixel 7 Motherboard Replacement, Peel off the lower graphite foil: step 22, image 1 of 3 Google Pixel 7 Motherboard Replacement, Peel off the lower graphite foil: step 22, image 2 of 3 Google Pixel 7 Motherboard Replacement, Peel off the lower graphite foil: step 22, image 3 of 3
      Buy
      • Use a pair of tweezers to carefully peel the lower graphite foil off the battery and midframe.
      Ask FixBot
    2. Google Pixel 7 Motherboard Replacement, Unfasten the loudspeaker screws: step 23, image 1 of 2 Google Pixel 7 Motherboard Replacement, Unfasten the loudspeaker screws: step 23, image 2 of 2
      • Use a Torx T3 screwdriver to remove the three 5.1 mm-long screws securing the loudspeaker.
      Ask FixBot
    3. Google Pixel 7 Motherboard Replacement, Remove the loudspeaker: step 24, image 1 of 2 Google Pixel 7 Motherboard Replacement, Remove the loudspeaker: step 24, image 2 of 2
      • Use a pair of tweezers to lift the loudspeaker out of its recess and remove it.
      Ask FixBot
    1. Google Pixel 7 Motherboard Replacement, Unfasten the midframe screws: step 25, image 1 of 2 Google Pixel 7 Motherboard Replacement, Unfasten the midframe screws: step 25, image 2 of 2
      • Use a Torx T3 screwdriver to remove the nine 5.1 mm-long screws securing the midframe.
      Ask FixBot
    2. Google Pixel 7 Motherboard Replacement, Remove the midframe: step 26, image 1 of 3 Google Pixel 7 Motherboard Replacement, Remove the midframe: step 26, image 2 of 3 Google Pixel 7 Motherboard Replacement, Remove the midframe: step 26, image 3 of 3
      Buy
      • Use a pair of tweezers to remove the midframe.
      • During reassembly check the condition of the thermal pad. If it's damaged, remove the pad, clean the area with high-concentration (greater than 90%) isopropyl alcohol and a microfiber or lint-free cloth, and apply a new thermal pad.
      Ask FixBot
    1. Google Pixel 7 Motherboard Replacement, Disconnect the battery cable: step 27, image 1 of 2 Google Pixel 7 Motherboard Replacement, Disconnect the battery cable: step 27, image 2 of 2
      • Use a spudger to disconnect the battery cable by prying the connector straight up from its socket.
      Ask FixBot
    1. Google Pixel 7 Motherboard Replacement, Heat the battery's adhesive: step 28, image 1 of 1
      • Apply a heated iOpener to the back of the device to loosen the adhesive underneath. Apply the iOpener for at least 3 minutes.
      Ask FixBot
    2. Google Pixel 7 Motherboard Replacement, Separate the battery pull tabs: step 29, image 1 of 3 Google Pixel 7 Motherboard Replacement, Separate the battery pull tabs: step 29, image 2 of 3 Google Pixel 7 Motherboard Replacement, Separate the battery pull tabs: step 29, image 3 of 3
      Buy
      • Use tweezers, or your fingers, to peel the plastic pull tabs away from the battery.
      Ask FixBot
    3. Google Pixel 7 Motherboard Replacement, Separate the battery's adhesive: step 30, image 1 of 3 Google Pixel 7 Motherboard Replacement, Separate the battery's adhesive: step 30, image 2 of 3 Google Pixel 7 Motherboard Replacement, Separate the battery's adhesive: step 30, image 3 of 3
      • Pull the tabs back and forth in a sawing motion up the length of the battery to separate the adhesive underneath.
      • Work slowly. It's easy to lose your grip and accidentally pull the tab up from under the battery.
      • If you're having difficulty separating the adhesive, apply more heat and wait for the adhesive to loosen.
      • If you lose or tear the release strip, follow the next step for an alternative battery removal method.
      Ask FixBot
    4. Google Pixel 7 Motherboard Replacement, How to remove a stuck battery: step 31, image 1 of 3 Google Pixel 7 Motherboard Replacement, How to remove a stuck battery: step 31, image 2 of 3 Google Pixel 7 Motherboard Replacement, How to remove a stuck battery: step 31, image 3 of 3
      • Follow this step if you couldn't loosen the battery using the battery release strip.
      • Apply a few drops of high concentration (90% or higher) isopropyl alcohol into the gap at the top edge of the battery.
      • Don't apply too much alcohol, or you'll loosen the NFC antenna and charging coil underneath the battery.
      • Wait about one minute for the alcohol solution to weaken the adhesive.
      • Use the flat end of a spudger or an opening pick to gently lift the top edge of the battery until you can grab it with your fingers.
      • Don't use excessive force on the battery. Slow, consistent pressure is all that's required to free it from the frame.
      • Take care not to puncture or bend the battery with your tool—a punctured or bent battery may leak dangerous chemicals or cause a fire.
      Ask FixBot
    5. Google Pixel 7 Motherboard Replacement, Remove the battery: step 32, image 1 of 3 Google Pixel 7 Motherboard Replacement, Remove the battery: step 32, image 2 of 3 Google Pixel 7 Motherboard Replacement, Remove the battery: step 32, image 3 of 3
      • Tilt the battery out of the device to separate the rest of the adhesive.
      • Remove the battery.
      • Do not reinstall a damaged or deformed battery, as doing so is a potential safety hazard.
      • To secure the replacement battery:
      • Apply pre-cut adhesive adhesive or double-sided tape to the battery well at the places where the old adhesive was located, not directly onto the battery.
      • Temporarily reconnect the battery to the motherboard to help align it correctly. Disconnect the battery after it's seated.
      • Make sure that the battery sits in the center of the battery well and there's an even gap around the battery.
      • Press the new battery firmly into place.
      Ask FixBot
    1. Google Pixel 7 Motherboard Replacement, Unfasten the mmWave antenna bracket screw: step 33, image 1 of 2 Google Pixel 7 Motherboard Replacement, Unfasten the mmWave antenna bracket screw: step 33, image 2 of 2
      • Use a Torx T3 screwdriver to remove the 5.1 mm-long screw securing the mmWave antenna bracket.
      Ask FixBot
    2. Google Pixel 7 Motherboard Replacement, Remove the mmWave antenna bracket: step 34, image 1 of 2 Google Pixel 7 Motherboard Replacement, Remove the mmWave antenna bracket: step 34, image 2 of 2
      Buy
      • Use a pair of tweezers to remove the mmWave antenna bracket.
      Ask FixBot
    3. Google Pixel 7 Motherboard Replacement, Disconnect the mmWave antenna cable: step 35, image 1 of 2 Google Pixel 7 Motherboard Replacement, Disconnect the mmWave antenna cable: step 35, image 2 of 2
      • Use a spudger to disconnect the mmWave antenna cable by prying the connector straight up from its socket.
      Ask FixBot
    4. Google Pixel 7 Motherboard Replacement, Remove the mmWave antenna assembly: step 36, image 1 of 3 Google Pixel 7 Motherboard Replacement, Remove the mmWave antenna assembly: step 36, image 2 of 3 Google Pixel 7 Motherboard Replacement, Remove the mmWave antenna assembly: step 36, image 3 of 3
      • Use a pair of tweezers to lift the mmWave antenna including its cable out of its recess.
      • Remove the mmWave antenna assembly.
      Ask FixBot
    5. Google Pixel 7 Motherboard Replacement, Remove the thermal paste: step 37, image 1 of 3 Google Pixel 7 Motherboard Replacement, Remove the thermal paste: step 37, image 2 of 3 Google Pixel 7 Motherboard Replacement, Remove the thermal paste: step 37, image 3 of 3
      • Use the flat end of a spudger to scrape the thermal paste off the mmWave antenna.
      • Clean any remaining thermal paste with isopropyl alcohol and either a coffee filter or a lint-free cloth.
      • Repeat the cleaning process for the thermal paste on the mmWave antenna bracket.
      • During reassembly, follow this guide for reapplying thermal paste onto the mmWave antenna.
      Ask FixBot
    6. Google Pixel 7 Motherboard Replacement, Disconnect the front facing camera: step 38, image 1 of 2 Google Pixel 7 Motherboard Replacement, Disconnect the front facing camera: step 38, image 2 of 2
      • Use a spudger to disconnect the front facing camera cable by prying the connector straight up from its socket.
      Ask FixBot
    7. Google Pixel 7 Motherboard Replacement, Remove the front facing camera: step 39, image 1 of 2 Google Pixel 7 Motherboard Replacement, Remove the front facing camera: step 39, image 2 of 2
      • Use a pair of tweezers to lift the front facing camera out of its recess and remove it.
      Ask FixBot
    8. Google Pixel 7 Motherboard Replacement, Unfasten the rear camera screw: step 40, image 1 of 2 Google Pixel 7 Motherboard Replacement, Unfasten the rear camera screw: step 40, image 2 of 2
      • Use a Torx T3 screwdriver to remove the 5.1 mm-long screw securing the rear cameras.
      Ask FixBot
    9. Google Pixel 7 Motherboard Replacement, Disconnect the wide-angle camera cable: step 41, image 1 of 2 Google Pixel 7 Motherboard Replacement, Disconnect the wide-angle camera cable: step 41, image 2 of 2
      • Use a spudger to disconnect the wide-angle camera cable by prying the connector straight up from its socket.
      Ask FixBot
    10. Google Pixel 7 Motherboard Replacement, Remove the wide-angle camera: step 42, image 1 of 2 Google Pixel 7 Motherboard Replacement, Remove the wide-angle camera: step 42, image 2 of 2
      • Use a pair of tweezers to remove the wide-angle camera.
      Ask FixBot
    11. Google Pixel 7 Motherboard Replacement, Disconnect the ultra wide-angle camera cable: step 43, image 1 of 2 Google Pixel 7 Motherboard Replacement, Disconnect the ultra wide-angle camera cable: step 43, image 2 of 2
      • Use a spudger to disconnect the ultra wide-angle camera cable by prying the connector straight up from its socket.
      Ask FixBot
    12. Google Pixel 7 Motherboard Replacement, Remove the ultra wide-angle camera: step 44, image 1 of 2 Google Pixel 7 Motherboard Replacement, Remove the ultra wide-angle camera: step 44, image 2 of 2
      • Use a pair of tweezers to remove the ultra wide-angle camera.
      Ask FixBot
    13. Google Pixel 7 Motherboard Replacement, Unfasten the earpiece speaker screw: step 45, image 1 of 2 Google Pixel 7 Motherboard Replacement, Unfasten the earpiece speaker screw: step 45, image 2 of 2
      • Use a Torx T3 screwdriver to remove the 5.1 mm-long screw securing the earpiece speaker.
      Ask FixBot
    14. Google Pixel 7 Motherboard Replacement, Pry up the earpiece speaker: step 46, image 1 of 2 Google Pixel 7 Motherboard Replacement, Pry up the earpiece speaker: step 46, image 2 of 2
      • Insert the pointed end of a spudger underneath the bottom edge of the earpiece speaker.
      • Pry upwards to loosen the earpiece speaker.
      Ask FixBot
    15. Google Pixel 7 Motherboard Replacement, Remove the earpiece speaker: step 47, image 1 of 2 Google Pixel 7 Motherboard Replacement, Remove the earpiece speaker: step 47, image 2 of 2
      • Use a pair of tweezers to remove the earpiece speaker.
      Ask FixBot
    16. Google Pixel 7 Motherboard Replacement, Disconnect the microphone interconnect cable: step 48, image 1 of 2 Google Pixel 7 Motherboard Replacement, Disconnect the microphone interconnect cable: step 48, image 2 of 2
      • Use a spudger to disconnect the microphone interconnect cable by prying the connector straight up from its socket.
      Ask FixBot
    17. Google Pixel 7 Motherboard Replacement, Eject the SIM card tray: step 49, image 1 of 3 Google Pixel 7 Motherboard Replacement, Eject the SIM card tray: step 49, image 2 of 3 Google Pixel 7 Motherboard Replacement, Eject the SIM card tray: step 49, image 3 of 3
      • Insert a SIM eject tool, bit, or straightened paper clip into the SIM card tray hole.
      • Press the SIM eject tool into the SIM card tray hole to eject the SIM card tray.
      Ask FixBot
    18. Google Pixel 7 Motherboard Replacement, Remove the SIM card tray: step 50, image 1 of 2 Google Pixel 7 Motherboard Replacement, Remove the SIM card tray: step 50, image 2 of 2
      • Remove the SIM card tray.
      Ask FixBot
    19. Google Pixel 7 Motherboard Replacement, Unfasten the motherboard screw: step 51, image 1 of 2 Google Pixel 7 Motherboard Replacement, Unfasten the motherboard screw: step 51, image 2 of 2
      • Use a Torx T3 screwdriver to remove the 5.1 mm-long screw securing the motherboard.
      Ask FixBot
    20. Google Pixel 7 Motherboard Replacement, Pry up the motherboard: step 52, image 1 of 2 Google Pixel 7 Motherboard Replacement, Pry up the motherboard: step 52, image 2 of 2
      • Make sure the motherboard isn't blocked or tangled by any cables during this step.
      • Insert a spudger underneath the top edge of the motherboard.
      • Pry upwards to loosen the motherboard until you can grab it with your fingers.
      Ask FixBot
    21. Google Pixel 7 Motherboard Replacement, Remove the motherboard: step 53, image 1 of 3 Google Pixel 7 Motherboard Replacement, Remove the motherboard: step 53, image 2 of 3 Google Pixel 7 Motherboard Replacement, Remove the motherboard: step 53, image 3 of 3
      • Grab the top end of the motherboard with your fingers.
      • Pull the motherboard in direction of the top edge of the frame to free the charging port from its recess.
      • Remove the motherboard.
      • Compare your new replacement part to the original part—you may need to transfer components like the antenna cables to your new motherboard.
      Ask FixBot
To run a diagnostics test with the built-in Pixel Diagnostic tool, click here.
Repair didn’t go as planned? Try some basic troubleshooting, or ask our Google Pixel 7 answers community for help.
8 other people completed this guide.
Dominik Schnabelrauch
266,047 Reputation
682 Guides authored
iFixit Member of iFixit
Staff
121 Members
72,625 Guides authored
2 Guide Comments
Hey, i am very glad to found your guide for Pixel 7 board replacement. And i have a question - i had my Pixel 7 died. Was at repair center, the tech said motherboard is just died . They have not this part . Please can you help me with finding of Pixel 7 board like a replacement part ? You can email me at vanko.68@gmail.com
Thanks in advance!
aidavanko - Reply Share
eBay has broken Google Pixel 7s I just bought a broken with and used the motherboard out of that it's around 75.00 to a hundred.
Elliott sanderson - Reply Share
Past 24 Hours: 21
Past 7 Days: 124
Past 30 Days: 486
All Time: 19,569
