Up to 20% off select tools
Google Pixel 6 Camera Glass Panel Replacement
Views: 3.3K
View statistics:
Past 24 Hours:
4
Past 7 Days:
36
Past 30 Days:
203
All Time:
3,281
Comments: 0
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 1 hour
Difficulty: Moderate
Featured Student Guide
This guide has been the hard work of our awesome students and is found to be exceptionally cool by the iFixit staff.
Parts
Tools
Introduction
Go to step 1 ↓
Are your pictures coming out blurry? Is your camera cracked? This could be because of the glass panel that covers the camera lenses on the Google Pixel. The solution? A simple replacement of the glass panel.
This guide demonstrates how to replace the glass panel on the Google Pixel 6.
Since the cover that holds the camera on the Google Pixel 6 is made out of glass, over time with wear and tear it can cause the problems listed above. Luckily, the glass panel comes separate from camera lenses themselves, making a replacement by the average consumer possible without much experience.
If you believe the camera lens itself is scratched, this guide will not solve that issue.
Choosing to replace the glass panel will save you potential grief from unclear pictures and the annoyance that comes with scratched or cracked glass on the device. In addition, it saves potential e-waste that would come from throwing out a phone and save you about $1000.
Since this guide is working with glass, exercise caution and handle with care to prevent yourself from injury.
    1. Google Pixel 6 Camera Glass Panel Replacement, Camera Glass Panel: step 1, image 1 of 2 Google Pixel 6 Camera Glass Panel Replacement, Camera Glass Panel: step 1, image 2 of 2
      • Use the wet wipe included in your kit to clean the rear camera glass panel.
      • Dry off the rear camera glass panel with the dry wipe.
      Ask FixBot
    2. Google Pixel 6 Camera Glass Panel Replacement: step 2, image 1 of 2 Google Pixel 6 Camera Glass Panel Replacement: step 2, image 2 of 2
      • Carefully cut around the edges of the phone's rear glass panel using an X-Acto knife.
      • Caution: Hazardous situation which involves a sharp utensil and glass fragments.
      Ask FixBot
    3. Google Pixel 6 Camera Glass Panel Replacement: step 3, image 1 of 2 Google Pixel 6 Camera Glass Panel Replacement: step 3, image 2 of 2
      • Using the tweezers, begin chipping and tweezing away at the cracked region.
      • Caution: Shards and shrapnel can splinter off of the panel.
      • Keep some masking tape near to be able to pick up shrapnel without injuring yourself.
      Ask FixBot
    4. Google Pixel 6 Camera Glass Panel Replacement: step 4, image 1 of 3 Google Pixel 6 Camera Glass Panel Replacement: step 4, image 2 of 3 Google Pixel 6 Camera Glass Panel Replacement: step 4, image 3 of 3
      • Use the metal spudger to remove the larger pieces of the glass to expose the layer underneath.
      • Caution: Hastily removing sharp fragments pieces could result in injury.
      Ask FixBot
    5. Google Pixel 6 Camera Glass Panel Replacement: step 5, image 1 of 2 Google Pixel 6 Camera Glass Panel Replacement: step 5, image 2 of 2
      • Use the opening tool to remove excess glue leftover from the old glass panel.
      • Perform this step only when all glass has been removed from the camera area.
      Ask FixBot
    6. Google Pixel 6 Camera Glass Panel Replacement: step 6, image 1 of 3 Google Pixel 6 Camera Glass Panel Replacement: step 6, image 2 of 3 Google Pixel 6 Camera Glass Panel Replacement: step 6, image 3 of 3
      • Take a piece of masking tape about 3 inches wide.
      • Gently press the masking tape (sticky side down) onto the rear camera lens and lift, removing the glass debris.
      • Repeat until most of the glass debris is removed.
      Ask FixBot
    7. Google Pixel 6 Camera Glass Panel Replacement: step 7, image 1 of 3 Google Pixel 6 Camera Glass Panel Replacement: step 7, image 2 of 3 Google Pixel 6 Camera Glass Panel Replacement: step 7, image 3 of 3
      • Align the glass panel replacement with the exposed camera area.
      • Press the glass panel firmly into the camera area.
      • Do not press too hard to avoid cracking glass from excess pressure.
      • Let the glass panel adhesive dry for approximately two hours before using the phone.
      Ask FixBot
Finish Line
Author
with
Aliyah Sims
154 Reputation
1 Guide authored
UC Davis, Team 1-6, Andersen Winter 2025 Member of UC Davis, Team 1-6, Andersen Winter 2025
UCD-ANDERSEN-W25S1G6
3 Members
12 Guides authored
0 Guide Comments
Past 24 Hours: 4
Past 7 Days: 36
Past 30 Days: 203
All Time: 3,281
