Google Pixel 4a Loudspeaker Replacement
    1. Google Pixel 4a Loudspeaker Replacement, Eject the SIM card tray: step 1, image 1 of 3 Google Pixel 4a Loudspeaker Replacement, Eject the SIM card tray: step 1, image 2 of 3 Google Pixel 4a Loudspeaker Replacement, Eject the SIM card tray: step 1, image 3 of 3
      • Insert a SIM eject tool, bit, or straightened paper clip into the SIM tray hole.
      • Press directly into the hole to eject the SIM card tray.
      • Remove the SIM card tray.
      Ask FixBot
    1. Google Pixel 4a Loudspeaker Replacement, Precautionary notes: step 2, image 1 of 3 Google Pixel 4a Loudspeaker Replacement, Precautionary notes: step 2, image 2 of 3 Google Pixel 4a Loudspeaker Replacement, Precautionary notes: step 2, image 3 of 3
      • You will need to pry the screen up to remove it from the phone. Read the following notes carefully before proceeding.
      • Take note of the two seams on the edge of the phone:
      • Screen seam: This seam separates the screen from the rest of the phone. This is where you should pry.
      • Frame seam: This is where the plastic frame meets the back cover. It is held in place by screws. Do not pry at this seam.
      • Before you begin, note the following areas on the screen:
      • Screen flex cable: Do not insert the opening pick deeper than instructed or you risk damaging this cable.
      • Note the orange ribbon cable under the lower-right corner of the screen, which is susceptible to damage if your opening pick is pressed into it. Only insert your opening pick as little as is necessary to separate the screen adhesive.
      • Adhesive perimeter: Prying beyond this narrow perimeter without angling the pick will damage the OLED panel.
      Ask FixBot
    2. Google Pixel 4a Loudspeaker Replacement, Heat the right edge of the screen: step 3, image 1 of 1
      • Apply a heated iOpener to the right edge of the display for one minute to soften the adhesive.
      • A hair dryer, heat gun, or hot plate may also be used, but be careful not to overheat the phone—the display and internal battery are both susceptible to heat damage.
      Ask FixBot
    3. Google Pixel 4a Loudspeaker Replacement, Insert an opening pick: step 4, image 1 of 3 Google Pixel 4a Loudspeaker Replacement, Insert an opening pick: step 4, image 2 of 3 Google Pixel 4a Loudspeaker Replacement, Insert an opening pick: step 4, image 3 of 3
      • If your display is badly cracked, covering it with a layer of clear packing tape may allow the suction cup to adhere. Alternatively, very strong tape may be used instead of the suction cup. If all else fails, you can superglue the suction cup to the broken screen.
      • Place a suction cup as close to the right edge of the screen as possible.
      • Lift the suction cup with a strong steady force.
      • Insert the tip of an opening pick into the screen seam no more than 1 mm.
      Ask FixBot
    4. Google Pixel 4a Loudspeaker Replacement, Guide the opening pick under the OLED panel: step 5, image 1 of 3 Google Pixel 4a Loudspeaker Replacement, Guide the opening pick under the OLED panel: step 5, image 2 of 3 Google Pixel 4a Loudspeaker Replacement, Guide the opening pick under the OLED panel: step 5, image 3 of 3
      • This step shows how to insert the pick without damaging the OLED panel. Do this before beginning to slice the adhesive.
      • With the pick 1 mm into the gap, pivot the pick upwards to a steep angle.
      • At a steep angle, carefully push the pick into the gap about 1/4 inch (6 mm). The pick should slide in below the OLED panel.
      • Stop if you feel the point of the pick hitting a ridge. The pick may be pressing against the edge of the OLED panel. Angle the pick and try again.
      Ask FixBot
    5. Google Pixel 4a Loudspeaker Replacement, Cut the adhesive: step 6, image 1 of 3 Google Pixel 4a Loudspeaker Replacement, Cut the adhesive: step 6, image 2 of 3 Google Pixel 4a Loudspeaker Replacement, Cut the adhesive: step 6, image 3 of 3
      • Slide the pick along the right edge of the screen to cut the adhesive.
      • Do not insert the pick more than 1/4 inch (6 mm) or you may damage the screen's flex cable.
      • Leave the pick in the top right corner to prevent the adhesive from re-sealing.
      Ask FixBot
    6. Google Pixel 4a Loudspeaker Replacement: step 7, image 1 of 3 Google Pixel 4a Loudspeaker Replacement: step 7, image 2 of 3 Google Pixel 4a Loudspeaker Replacement: step 7, image 3 of 3
      • The screen adhesive is very weak and you should not need to re-apply heat. If the screen does feel hard to slice, apply heat to the difficult area for one minute and try again.
      • Insert another opening pick into the right edge of the phone at an angle where a gap has already formed to prevent damage to the OLED panel.
      • Slide the opening pick around the bottom of the phone to cut the adhesive.
      • There is a delicate cable under the bottom-right corner of the screen. If you feel your opening pick snag on anything, pull it out and try again. Make sure your pick is angled downward and only inserted as little as is necessary to separate the adhesive (no more than 2 mm deep).
      • Leave the pick inserted along the bottom edge to prevent the adhesive from resealing.
      Ask FixBot
    7. Google Pixel 4a Loudspeaker Replacement: step 8, image 1 of 3 Google Pixel 4a Loudspeaker Replacement: step 8, image 2 of 3 Google Pixel 4a Loudspeaker Replacement: step 8, image 3 of 3
      • Insert another opening pick into the bottom edge of the phone at an angle where a gap has already formed to prevent damage to the OLED panel.
      • Use the pick to slice through the left edge of the phone.
      • If the screen feels hard to slice, heat the left edge for one minute and try again.
      • Leave the pick inserted along the left edge of the phone to prevent the adhesive from re-sealing.
      Ask FixBot
    8. Google Pixel 4a Loudspeaker Replacement: step 9, image 1 of 3 Google Pixel 4a Loudspeaker Replacement: step 9, image 2 of 3 Google Pixel 4a Loudspeaker Replacement: step 9, image 3 of 3
      • There's a mesh covering the earpiece speaker on the top edge of the screen. If you don’t have a replacement mesh, take care not to damage or lose this component.
      • Insert another opening pick into the left edge of the phone at an angle where a gap has already formed to prevent damage to the OLED panel.
      • Slide the pick around the top edge of the phone to cut the adhesive.
      • If the screen feels hard to slice, heat the top edge for one minute and try again.
      Ask FixBot
    9. Google Pixel 4a Loudspeaker Replacement: step 10, image 1 of 2 Google Pixel 4a Loudspeaker Replacement: step 10, image 2 of 2
      • Once you have cut around the perimeter of the phone, carefully lift the right edge of the screen, opening the phone like a book.
      • Do not remove the screen yet.
      • Use an opening pick to carefully cut through any remaining adhesive.
      Ask FixBot
    10. Google Pixel 4a Loudspeaker Replacement, Flip the screen over: step 11, image 1 of 3 Google Pixel 4a Loudspeaker Replacement, Flip the screen over: step 11, image 2 of 3 Google Pixel 4a Loudspeaker Replacement, Flip the screen over: step 11, image 3 of 3
      • Lift from the top edge and swing the screen over the bottom edge until you can rest it glass-side down.
      • Be careful not to put any stress on the attached ribbon cable.
      Ask FixBot
    11. Google Pixel 4a Loudspeaker Replacement, Disconnect the display: step 12, image 1 of 1
      Tool used on this step:
      Buy
      • Use a pair of tweezers to carefully peel up the black tape covering the screen connector bracket.
      • If it is in good condition, you can re-use this tape during reassembly. Otherwise, replace it with a piece of electrical tape.
      Ask FixBot
    12. Google Pixel 4a Loudspeaker Replacement: step 13, image 1 of 1
      Magnetic Project Mat
      $19.95
      Buy
      • Use a T3 Torx driver to remove the two 2.1 mm screws securing the screen connector bracket.
      Ask FixBot
    13. Google Pixel 4a Loudspeaker Replacement: step 14, image 1 of 1
      • Use a pair of tweezers to remove the screen connector bracket.
      • Make sure to keep this component to reinstall it during reassembly.
      Ask FixBot
    14. Google Pixel 4a Loudspeaker Replacement: step 15, image 1 of 2 Google Pixel 4a Loudspeaker Replacement: step 15, image 2 of 2
      • Use the tip of a spudger to pry up and disconnect the screen flex cable.
      • To re-attach press connectors like this one, carefully align and press down on one side until it clicks into place, then repeat on the other side. Do not press down on the middle. If the connector is misaligned, the pins can bend, causing permanent damage.
      Ask FixBot
    15. Google Pixel 4a Loudspeaker Replacement, Remove the screen: step 16, image 1 of 3 Google Pixel 4a Loudspeaker Replacement, Remove the screen: step 16, image 2 of 3 Google Pixel 4a Loudspeaker Replacement, Remove the screen: step 16, image 3 of 3
      • Remove the screen.
      • To install a new screen:
      • Check if your replacement screen has speaker mesh and top edge adhesive pre-installed.
      • If it does, you won't need the top edge adhesive.
      • If it doesn't, remove the larger clear liner from the top edge adhesive and apply it to the screen (not the frame). Make sure the larger cutout lines up with the speaker mesh.
      • Follow this guide to apply the custom-cut adhesive.
      • Use the third photo as a reference to position your adhesives.
      • During the boot-up process after reassembly, the screen will go through a calibration sequence. Don't touch the screen during this process, as it could result in improper touch calibration and create touch issues.
      Ask FixBot
    1. Google Pixel 4a Loudspeaker Replacement, Remove the midframe screws: step 17, image 1 of 2 Google Pixel 4a Loudspeaker Replacement, Remove the midframe screws: step 17, image 2 of 2
      • Use a T3 Torx driver to remove the eight 4.3 mm screws securing the back cover to the midframe.
      Ask FixBot
    2. Google Pixel 4a Loudspeaker Replacement, Spring contact information: step 18, image 1 of 1
      • This photo shows the midframe components behind the back cover. Note the spring contacts near the edge of the midframe. As you slice with the opening pick in the next step, be sure not to insert the pick more than 2 mm to avoid damaging the spring contacts.
      Ask FixBot
    3. Google Pixel 4a Loudspeaker Replacement, Separate the back cover from the midframe: step 19, image 1 of 2 Google Pixel 4a Loudspeaker Replacement, Separate the back cover from the midframe: step 19, image 2 of 2
      • In the next three steps, be careful not to insert the opening pick more than 2 mm into the seam.
      • Insert an opening pick into the seam between the midframe and the back cover. Angle the pick downwards at a steep angle into the seam.
      • Slide the opening pick along the bottom edge of the phone to release the plastic clips securing the back cover to the midframe.
      Ask FixBot
    4. Google Pixel 4a Loudspeaker Replacement: step 20, image 1 of 2 Google Pixel 4a Loudspeaker Replacement: step 20, image 2 of 2
      • Slide the opening pick around the left edge of the phone to release the plastic clips securing the back cover to the midframe.
      Ask FixBot
    5. Google Pixel 4a Loudspeaker Replacement: step 21, image 1 of 3 Google Pixel 4a Loudspeaker Replacement: step 21, image 2 of 3 Google Pixel 4a Loudspeaker Replacement: step 21, image 3 of 3
      • Slide the opening pick around the top and right edges of the phone to release the rest of the clips.
      Ask FixBot
    6. Google Pixel 4a Loudspeaker Replacement: step 22, image 1 of 3 Google Pixel 4a Loudspeaker Replacement: step 22, image 2 of 3 Google Pixel 4a Loudspeaker Replacement: step 22, image 3 of 3
      • Carefully swing the back cover from the bottom of the phone over the top and around the back.
      • Lay the back cover on the work surface and lightly rest the midframe on the back cover, being careful not to put any stress on the attached ribbon cables.
      Ask FixBot
    7. Google Pixel 4a Loudspeaker Replacement, Remove the motherboard bracket: step 23, image 1 of 2 Google Pixel 4a Loudspeaker Replacement, Remove the motherboard bracket: step 23, image 2 of 2
      • Use a T3 Torx driver to remove the seven screws securing the motherboard bracket:
      • Three 2.9 mm-long black screws
      • Three 2 mm-long screws
      • One 4.1 mm-long screw
      Ask FixBot
    8. Google Pixel 4a Loudspeaker Replacement: step 24, image 1 of 1
      • Use a spudger to lift the fingerprint sensor ribbon cable from the adhesive securing it to the motherboard bracket.
      Ask FixBot
    9. Google Pixel 4a Loudspeaker Replacement: step 25, image 1 of 3 Google Pixel 4a Loudspeaker Replacement: step 25, image 2 of 3 Google Pixel 4a Loudspeaker Replacement: step 25, image 3 of 3
      • Use the tip of a spudger to unclip the motherboard bracket from the upper-right and lower-right corners of the motherboard.
      Ask FixBot
    10. Google Pixel 4a Loudspeaker Replacement: step 26, image 1 of 3 Google Pixel 4a Loudspeaker Replacement: step 26, image 2 of 3 Google Pixel 4a Loudspeaker Replacement: step 26, image 3 of 3
      Buy
      • Use a pair of tweezers to remove the motherboard bracket.
      Ask FixBot
    11. Google Pixel 4a Loudspeaker Replacement, Disconnect the battery: step 27, image 1 of 2 Google Pixel 4a Loudspeaker Replacement, Disconnect the battery: step 27, image 2 of 2
      • Use the flat end of a spudger to pry up and disconnect the battery cable.
      Ask FixBot
    1. Google Pixel 4a Loudspeaker Replacement, Remove the back cover: step 28, image 1 of 3 Google Pixel 4a Loudspeaker Replacement, Remove the back cover: step 28, image 2 of 3 Google Pixel 4a Loudspeaker Replacement, Remove the back cover: step 28, image 3 of 3
      • Use the tip of a spudger to disconnect the two flex cables connecting the fingerprint sensor and buttons to the motherboard.
      Ask FixBot
    2. Google Pixel 4a Loudspeaker Replacement: step 29, image 1 of 2 Google Pixel 4a Loudspeaker Replacement: step 29, image 2 of 2
      • Remove the back cover.
      Ask FixBot
    1. Google Pixel 4a Loudspeaker Replacement, Remove the loudspeaker: step 30, image 1 of 2 Google Pixel 4a Loudspeaker Replacement, Remove the loudspeaker: step 30, image 2 of 2
      • Use a T3 Torx driver to remove the two 4.1 mm screws securing the loudspeaker assembly.
      Ask FixBot
    2. Google Pixel 4a Loudspeaker Replacement: step 31, image 1 of 3 Google Pixel 4a Loudspeaker Replacement: step 31, image 2 of 3 Google Pixel 4a Loudspeaker Replacement: step 31, image 3 of 3
      • Insert the tip of a spudger underneath the loudspeaker assembly.
      • Be careful not to puncture the white membrane on either side of the speaker if you are intending to reuse it.
      • Flip the loudspeaker assembly over so it lightly rests on top of the battery.
      Ask FixBot
    3. Google Pixel 4a Loudspeaker Replacement: step 32, image 1 of 3 Google Pixel 4a Loudspeaker Replacement: step 32, image 2 of 3 Google Pixel 4a Loudspeaker Replacement: step 32, image 3 of 3
      • Use the tip of a spudger to disconnect the antenna flex cable from the loudspeaker assembly.
      Ask FixBot
    4. Google Pixel 4a Loudspeaker Replacement: step 33, image 1 of 3 Google Pixel 4a Loudspeaker Replacement: step 33, image 2 of 3 Google Pixel 4a Loudspeaker Replacement: step 33, image 3 of 3
      • Carefully peel the loudspeaker assembly up off of the tape underneath it.
      • Remove the loudspeaker assembly.
      Ask FixBot
2 other people completed this guide.
Sam Omiotek
100,961 Reputation
289 Guides authored
0 Guide Comments
Past 24 Hours: 5
Past 7 Days: 22
Past 30 Days: 77
All Time: 5,745
