Google Pixel 4 XL Battery Replacement
    1. Google Pixel 4 XL Battery Replacement, Heat the back panel glass: step 1, image 1 of 1
      • Prepare an iOpener and apply it to the bottom edge of the back panel for one minute.
      • A hair dryer, heat gun, or hot plate may also be used, but be careful not to overheat the phone—the display and internal battery are both susceptible to heat damage.
      Ask FixBot
    2. Google Pixel 4 XL Battery Replacement, Apply a suction cup: step 2, image 1 of 2 Google Pixel 4 XL Battery Replacement, Apply a suction cup: step 2, image 2 of 2
      • Apply a suction cup to the heated edge of the back panel by pressing down on it to create suction, as close to the edge as possible.
      • If your back glass is badly cracked, covering it with a layer of clear packing tape may allow the suction cup to adhere. Alternatively, very strong tape may be used instead of the suction cup. If all else fails, you can superglue the suction cup to the broken panel.
      Ask FixBot
    3. Google Pixel 4 XL Battery Replacement, Insert an opening pick: step 3, image 1 of 2 Google Pixel 4 XL Battery Replacement, Insert an opening pick: step 3, image 2 of 2
      • Pull up on the suction cup with strong, steady force to create a gap between the back panel and the frame.
      • Depending on the age of your phone, this may be difficult. If you are having trouble, apply more heat to the edge and try again.
      • Insert the point of an opening pick into the gap.
      Ask FixBot
    4. Google Pixel 4 XL Battery Replacement, Begin to slice the adhesive: step 4, image 1 of 3 Google Pixel 4 XL Battery Replacement, Begin to slice the adhesive: step 4, image 2 of 3 Google Pixel 4 XL Battery Replacement, Begin to slice the adhesive: step 4, image 3 of 3
      • Slide the opening pick across the bottom towards the left corner to slice the adhesive.
      • With the pick still inserted, slide it from the bottom left corner over to the bottom right corner to completely slice the bottom side adhesive.
      • Leave the pick inserted in the bottom right corner to prevent the adhesive from re-sealing.
      Ask FixBot
    5. Google Pixel 4 XL Battery Replacement, Slice the lefthand-side adhesive: step 5, image 1 of 1
      • Prepare an iOpener and apply it on the left edge of the phone for one minute.
      Ask FixBot
    6. Google Pixel 4 XL Battery Replacement: step 6, image 1 of 2 Google Pixel 4 XL Battery Replacement: step 6, image 2 of 2
      • Insert a second opening pick underneath the back panel directly over the charge port.
      • Slide the opening pick to the bottom left corner of the phone.
      Ask FixBot
    7. Google Pixel 4 XL Battery Replacement: step 7, image 1 of 2 Google Pixel 4 XL Battery Replacement: step 7, image 2 of 2
      • Slide the opening pick around the bottom left corner and across the left side of the phone to slice the adhesive.
      • The adhesive can be very gummy. Push the pick in and out in a sawing motion to help with slicing.
      • Stop when you reach the top left corner, near the camera, and leave the pick inserted.
      Ask FixBot
    8. Google Pixel 4 XL Battery Replacement, Slice righthand-side adhesive: step 8, image 1 of 1
      • Prepare an iOpener and apply it on the right edge of the phone for one minute.
      Ask FixBot
    9. Google Pixel 4 XL Battery Replacement: step 9, image 1 of 3 Google Pixel 4 XL Battery Replacement: step 9, image 2 of 3 Google Pixel 4 XL Battery Replacement: step 9, image 3 of 3
      • With the first two opening picks still in place, insert a third pick on the lower part of the righthand side.
      • Slide the opening pick up towards the top of the phone, slicing the right side's adhesive.
      • Stop when you reach the top right corner, and leave the pick inserted.
      Ask FixBot
    10. Google Pixel 4 XL Battery Replacement, Slice the top-side adhesive: step 10, image 1 of 2 Google Pixel 4 XL Battery Replacement, Slice the top-side adhesive: step 10, image 2 of 2
      • Slide the third opening pick around the top right corner and across the top side of the phone, slicing the final strip of adhesive.
      Ask FixBot
    11. Google Pixel 4 XL Battery Replacement, Lift up the back panel: step 11, image 1 of 3 Google Pixel 4 XL Battery Replacement, Lift up the back panel: step 11, image 2 of 3 Google Pixel 4 XL Battery Replacement, Lift up the back panel: step 11, image 3 of 3
      • Once you have sliced around the perimeter of the phone, carefully lift the right edge of the back cover, opening it like a book.
      • Do not try to pull the panel all the way off yet, as it is still connected to the phone.
      Ask FixBot
    12. Google Pixel 4 XL Battery Replacement: step 12, image 1 of 2 Google Pixel 4 XL Battery Replacement: step 12, image 2 of 2
      • Continue swinging open the back panel until you can rest it on the left edge the phone, being careful not to put any stress on the attached ribbon cable.
      • During reassembly, this is a good point to power on your phone and test all functions before sealing it up. Be sure to power your phone back down completely before you continue working.
      Ask FixBot
    13. Google Pixel 4 XL Battery Replacement, Disconnect the battery: step 13, image 1 of 1
      Tool used on this step:
      Magnetic Project Mat
      $19.95
      Buy
      • Remove the four T3 Torx screws securing the battery connector shield:
      • One 1.8 mm screw
      • One 4.1 mm screw
      • One 4.4 mm shouldered screw
      • One 4.0 mm shouldered screw
      Ask FixBot
    14. Google Pixel 4 XL Battery Replacement: step 14, image 1 of 2 Google Pixel 4 XL Battery Replacement: step 14, image 2 of 2
      Buy
      • Use a pair of tweezers to remove the battery connector shield.
      Ask FixBot
    15. Google Pixel 4 XL Battery Replacement: step 15, image 1 of 2 Google Pixel 4 XL Battery Replacement: step 15, image 2 of 2
      • Whenever you use the spudger near the battery, be very careful not to puncture the battery.
      • Using the pointed end of a spudger, pry the battery connector straight up from the motherboard to disconnect the battery.
      • To re-attach press connectors like this one, carefully align and press down on one side until it clicks into place, then repeat on the other side. Do not press down on the middle. If the connector is misaligned, the pins can bend, causing permanent damage.
      Ask FixBot
    16. Google Pixel 4 XL Battery Replacement: step 16, image 1 of 2 Google Pixel 4 XL Battery Replacement: step 16, image 2 of 2
      • Using the flat end of a spudger, gently fold the battery cable over so it doesn't accidentally make contact during the rest of your repairs.
      Ask FixBot
    17. Google Pixel 4 XL Battery Replacement, Disconnect the back panel connector: step 17, image 1 of 1
      • Use a T3 Torx driver to remove the two 4.1 mm screws securing the back panel connector cover.
      Ask FixBot
    18. Google Pixel 4 XL Battery Replacement: step 18, image 1 of 2 Google Pixel 4 XL Battery Replacement: step 18, image 2 of 2
      • Use a pair of tweezers to remove the back panel connector cover.
      Ask FixBot
    19. Google Pixel 4 XL Battery Replacement: step 19, image 1 of 2 Google Pixel 4 XL Battery Replacement: step 19, image 2 of 2
      • Using the pointed end of a spudger, pry up and disconnect the back panel connector.
      Ask FixBot
    20. Google Pixel 4 XL Battery Replacement, Remove the back panel: step 20, image 1 of 1
      • Remove the back panel.
      • During reassembly, follow this guide to install custom-cut adhesives for your device.
      • Follow this guide if you are using a pre-cut adhesive card.
      Ask FixBot
    1. Google Pixel 4 XL Battery Replacement, Remove the battery's adhesive pull tabs: step 21, image 1 of 2 Google Pixel 4 XL Battery Replacement, Remove the battery's adhesive pull tabs: step 21, image 2 of 2
      Buy
      • Use blunt tweezers to lift up the battery adhesive pull tabs so you can more easily grip them with your fingers.
      • The battery is held in place with three separate stretch adhesive strips, which are connected to a single black pull tab. You can try to pull all three strips out together, but it is easier to cut the black pull tab where it is notched and pull each strip out individually.
      Ask FixBot
    2. Google Pixel 4 XL Battery Replacement: step 22, image 1 of 2 Google Pixel 4 XL Battery Replacement: step 22, image 2 of 2
      • Pull on the black pull tab at a shallow angle with steady force. When the adhesive grows long, roll it around a spudger and continue pulling.
      • Continue firmly pulling up on the adhesive strip with constant force, spinning the spudger every so often to keep the exposed section of the pull tab as short as possible.
      • This may take a lot of force.
      • These adhesive pull tabs are very prone to snapping in half during this process. Try pulling as slowly as possible.
      • If the adhesive pull tabs are not stretching, you can fill a plastic dropper or syringe with high concentration isopropyl alcohol and apply a few drops under the left edge of the battery. Give the alcohol a minute to weaken the battery adhesive.
      • Continue this process for each of the three pull tabs, until all are either out or have snapped in half.
      Ask FixBot
    3. Google Pixel 4 XL Battery Replacement, Remove the battery: step 23, image 1 of 3 Google Pixel 4 XL Battery Replacement, Remove the battery: step 23, image 2 of 3 Google Pixel 4 XL Battery Replacement, Remove the battery: step 23, image 3 of 3
      • If the battery tabs snapped during removal, insert an opening pick on the upper right edge of the battery, slicing the adhesive underneath.
      • Even if you successfully removed all three adhesive pull tabs, using an opening pick to dislodge the battery may be helpful.
      • Don't insert the opening pick on or anywhere below the grip sensor cable, as the pick can damage the charge port flex cable located underneath the battery.
      Ask FixBot
    4. Google Pixel 4 XL Battery Replacement: step 24, image 1 of 2 Google Pixel 4 XL Battery Replacement: step 24, image 2 of 2
      Tesa 61395 Tape
      $8.95
      Buy
      • Don't reuse the battery if it has been deformed or damaged, as doing so is a potential safety hazard. Replace it with a new battery.
      • Lift the battery up, away from the phone to remove it.
      • To install a replacement battery:
      • Remove any remaining adhesive from the battery well.
      • If you're using stretch release adhesive, apply them onto the battery. Otherwise, apply some double-sided tape, or pre-cut adhesive strips in the phone's battery well, being careful not to cover the charge port flex cable. Peel away any tape liners to expose the adhesive.
      • Temporarily re-connect the battery's connector to the motherboard socket. This ensures that the battery is properly positioned.
      • Lay the battery in place and press firmly.
      • Disconnect the battery connector from its motherboard socket and resume re-assembly.
      Ask FixBot
For optimal performance, calibrate your newly installed battery after completing this guide.
Repair didn’t go as planned? Try some basic troubleshooting, or ask our Answers community for help.
102 other people completed this guide.
Carsten Frauenheim
171,545 Reputation
441 Guides authored
iFixit Member of iFixit
Staff
121 Members
72,737 Guides authored
42 Guide Comments
Worked great, was tough pulling up the battery but other than that went super smoothly. thanks!!
Kader Belbina - Reply Share
Really comprehensive, helpful and well-written guide. I prefer to learn to fix things on my own, so this was immensely helpful and just what I needed. Thank you so much!
Zaeda June - Reply Share
the adhesive pull tabs? there was no way to get them out as the hardware prevents you from pulling at the right angle. i went with softening the glue with a couple drops of alcohol and prying the battery up enough to get a guitar pick in and cut the rest.
Camilo Santana - Reply Share
Just finished changing the battery to my Pixel 4XL. Battery was slightly bloated (about 1mm) but still running great, at 104% after one year and a half. However, it suddenly stopped charging wirelessly, even from the original Pixel charger.
The kit was great, everything happened according to the instructions. Carefully cleaning the old adhesive took most of the time. I used lint-free wipes and a small syringe filled with Isopropyl alcohol 99.9% to drop the liquid over the adhesive strips in small sections, with the phone positioned vertically, so the alcohol didn’t get inside. Same for the rear cover [Regular rubbing alcohol does not work at all for this purpose] The alcohol really helped removing the old stretch release strips really fast. The connector of the new battery was slightly out of alignment, so I had to plug it first, with the battery leaning at a small angle, then seat the battery on the glue strips. Thank you, that was fun! :)
Radu O. - Reply Share
Great tutorial. I followed all the steps. And, even with the new battery, it's still stuck in 50%.
My phone took a dive in the pool. I love in Brazil, do I don't have Google technical support available, and due to battery mailing restrictions it took 6 months until I managed to receive a spare one.
Do you guys know what could I do?
Thanks
r.duarte - Reply Share
Past 24 Hours: 13
Past 7 Days: 82
Past 30 Days: 328
All Time: 84,615
