Google Pixel 4 Wireless Charging Coil Replacement
    1. Google Pixel 4 Wireless Charging Coil Replacement, Remove the SIM card tray: step 1, image 1 of 3 Google Pixel 4 Wireless Charging Coil Replacement, Remove the SIM card tray: step 1, image 2 of 3 Google Pixel 4 Wireless Charging Coil Replacement, Remove the SIM card tray: step 1, image 3 of 3
      • Insert a SIM eject tool, bit, or a straightened paper clip into the small hole on the SIM card tray on the left edge of the phone.
      • Press firmly to eject the tray.
      • Remove the SIM card tray.
      Ask FixBot
    1. Google Pixel 4 Wireless Charging Coil Replacement, Heat the back panel glass: step 2, image 1 of 1
      • Prepare an iOpener and apply it to the bottom edge of the back panel for one minute.
      • A hair dryer, heat gun, or hot plate may also be used, but be careful not to overheat the phone—the display and internal battery are both susceptible to heat damage.
      Ask FixBot
    2. Google Pixel 4 Wireless Charging Coil Replacement, Apply a suction cup: step 3, image 1 of 2 Google Pixel 4 Wireless Charging Coil Replacement, Apply a suction cup: step 3, image 2 of 2
      • Apply a suction cup to the heated edge of the back panel by pressing down on it to create suction, as close to the edge as possible.
      • If your back glass is badly cracked, covering it with a layer of clear packing tape may allow the suction cup to adhere. Alternatively, very strong tape may be used instead of the suction cup. If all else fails, you can superglue the suction cup to the broken panel.
      Ask FixBot
    3. Google Pixel 4 Wireless Charging Coil Replacement, Insert an opening pick: step 4, image 1 of 2 Google Pixel 4 Wireless Charging Coil Replacement, Insert an opening pick: step 4, image 2 of 2
      • Pull up on the suction cup with strong, steady force to create a gap between the back panel and the frame.
      • Depending on the age of your phone, this may be difficult. If you are having trouble, apply more heat to the edge and try again.
      • Insert the point of an opening pick into the gap.
      Ask FixBot
    4. Google Pixel 4 Wireless Charging Coil Replacement, Begin to slice the adhesive: step 5, image 1 of 3 Google Pixel 4 Wireless Charging Coil Replacement, Begin to slice the adhesive: step 5, image 2 of 3 Google Pixel 4 Wireless Charging Coil Replacement, Begin to slice the adhesive: step 5, image 3 of 3
      • Slide the opening pick across the bottom towards the left corner to slice the adhesive.
      • With the pick still inserted, slide it from the bottom left corner over to the bottom right corner to completely slice the bottom side adhesive.
      • Leave the pick inserted in the bottom right corner to prevent the adhesive from re-sealing.
      Ask FixBot
    5. Google Pixel 4 Wireless Charging Coil Replacement, Slice the lefthand-side adhesive: step 6, image 1 of 1
      • Prepare an iOpener and apply it on the left edge of the phone for one minute.
      Ask FixBot
    6. Google Pixel 4 Wireless Charging Coil Replacement: step 7, image 1 of 2 Google Pixel 4 Wireless Charging Coil Replacement: step 7, image 2 of 2
      • Insert a second opening pick underneath the back panel directly over the charge port.
      • Slide the opening pick to the bottom left corner of the phone.
      Ask FixBot
    7. Google Pixel 4 Wireless Charging Coil Replacement: step 8, image 1 of 2 Google Pixel 4 Wireless Charging Coil Replacement: step 8, image 2 of 2
      • Slide the opening pick around the bottom left corner and across the left side of the phone to slice the adhesive.
      • The adhesive can be very gummy. Push the pick in and out in a sawing motion to help with slicing.
      • Stop when you reach the top left corner, near the camera, and leave the pick inserted.
      Ask FixBot
    8. Google Pixel 4 Wireless Charging Coil Replacement, Slice righthand-side adhesive: step 9, image 1 of 1
      • Prepare an iOpener and apply it on the right edge of the phone for one minute.
      Ask FixBot
    9. Google Pixel 4 Wireless Charging Coil Replacement: step 10, image 1 of 3 Google Pixel 4 Wireless Charging Coil Replacement: step 10, image 2 of 3 Google Pixel 4 Wireless Charging Coil Replacement: step 10, image 3 of 3
      • With the first two opening picks still in place, insert a third pick on the lower part of the righthand side.
      • Slide the opening pick up towards the top of the phone, slicing the right side's adhesive.
      • Stop when you reach the top right corner, and leave the pick inserted.
      Ask FixBot
    10. Google Pixel 4 Wireless Charging Coil Replacement, Slice the top-side adhesive: step 11, image 1 of 2 Google Pixel 4 Wireless Charging Coil Replacement, Slice the top-side adhesive: step 11, image 2 of 2
      • Slide the third opening pick around the top right corner and across the top side of the phone, slicing the final strip of adhesive.
      Ask FixBot
    11. Google Pixel 4 Wireless Charging Coil Replacement, Lift up the back panel: step 12, image 1 of 3 Google Pixel 4 Wireless Charging Coil Replacement, Lift up the back panel: step 12, image 2 of 3 Google Pixel 4 Wireless Charging Coil Replacement, Lift up the back panel: step 12, image 3 of 3
      • Once you have sliced around the perimeter of the phone, carefully lift the right edge of the back cover, opening it like a book.
      • Do not try to pull the panel all the way off yet, as it is still connected to the phone.
      Ask FixBot
    12. Google Pixel 4 Wireless Charging Coil Replacement: step 13, image 1 of 2 Google Pixel 4 Wireless Charging Coil Replacement: step 13, image 2 of 2
      • Continue swinging open the back panel until you can rest it on the left edge the phone, being careful not to put any stress on the attached ribbon cable.
      • During reassembly, this is a good point to power on your phone and test all functions before re-sealing the back panel. Be sure to power your phone back down completely before you continue working.
      Ask FixBot
    13. Google Pixel 4 Wireless Charging Coil Replacement, Disconnect the battery: step 14, image 1 of 1
      Tool used on this step:
      Magnetic Project Mat
      $19.95
      Buy
      • Remove the five T3 Torx screws securing the battery connector shield:
      • Four 4.0 mm screws
      • One 2.1 mm screw
      Ask FixBot
    14. Google Pixel 4 Wireless Charging Coil Replacement: step 15, image 1 of 2 Google Pixel 4 Wireless Charging Coil Replacement: step 15, image 2 of 2
      Buy
      • Use a pair of tweezers to remove the battery connector shield.
      Ask FixBot
    15. Google Pixel 4 Wireless Charging Coil Replacement: step 16, image 1 of 2 Google Pixel 4 Wireless Charging Coil Replacement: step 16, image 2 of 2
      • Whenever you use the spudger near the battery, be very careful not to puncture the battery.
      • Using the pointed end of a spudger, pry the battery connector straight up from the motherboard to disconnect the battery.
      • To re-attach press connectors like this one, carefully align and press down on one side until it clicks into place, then repeat on the other side. Do not press down on the middle. If the connector is misaligned, the pins can bend, causing permanent damage.
      Ask FixBot
    16. Google Pixel 4 Wireless Charging Coil Replacement: step 17, image 1 of 2 Google Pixel 4 Wireless Charging Coil Replacement: step 17, image 2 of 2
      • Using the flat end of a spudger, gently fold the battery cable over so it doesn't accidentally make contact during the rest of your repairs.
      Ask FixBot
    17. Google Pixel 4 Wireless Charging Coil Replacement, Disconnect the back panel connector: step 18, image 1 of 1
      • Use a T3 Torx driver to remove the two 4 mm screws securing the back panel connector cover.
      Ask FixBot
    18. Google Pixel 4 Wireless Charging Coil Replacement: step 19, image 1 of 2 Google Pixel 4 Wireless Charging Coil Replacement: step 19, image 2 of 2
      • Use a pair of tweezers to remove the back panel connector cover.
      Ask FixBot
    19. Google Pixel 4 Wireless Charging Coil Replacement: step 20, image 1 of 2 Google Pixel 4 Wireless Charging Coil Replacement: step 20, image 2 of 2
      • Using the pointed end of a spudger, pry up and disconnect the back panel connector.
      Ask FixBot
    20. Google Pixel 4 Wireless Charging Coil Replacement, Remove the back panel: step 21, image 1 of 1
      • Remove the back panel.
      • During reassembly, follow this guide to install custom-cut adhesives for your device.
      • Follow this guide if you are using a pre-cut adhesive card.
      Ask FixBot
    1. Google Pixel 4 Wireless Charging Coil Replacement, Peel off the graphite adhesive layer: step 22, image 1 of 1
      Buy
      • The wireless charging coil is adhered to the back panel and is covered by a graphite adhesive layer which will need to be removed.
      • Use tweezers on one of the bottom corners to pull up the adhesive enough to grab it with your fingers.
      Ask FixBot
    2. Google Pixel 4 Wireless Charging Coil Replacement: step 23, image 1 of 2 Google Pixel 4 Wireless Charging Coil Replacement: step 23, image 2 of 2
      • Peel back the graphite adhesive layer to expose the wireless charging coil, NFC pads, and LED flash module.
      • Completely remove the graphite adhesive layer.
      Ask FixBot
    3. Google Pixel 4 Wireless Charging Coil Replacement, Remove the wireless charging coil: step 24, image 1 of 2 Google Pixel 4 Wireless Charging Coil Replacement, Remove the wireless charging coil: step 24, image 2 of 2
      • Use tweezers on one of the bottom corners of the wireless charging coil pad to pull up the adhesive backing enough so you can grab it with your fingers.
      • Peel off and remove the wireless charging coil.
      • When installing a new wireless charging coil pad, align the contacts with the residue outline left by the old adhesive.
      • If the contacts don't line up with the corresponding spring contacts on the motherboard, the wireless charging coil will not work properly.
      Ask FixBot
Repair didn’t go as planned? Try some basic troubleshooting, or ask our Answers community for help.
3 other people completed this guide.
Carsten Frauenheim
169,095 Reputation
437 Guides authored
iFixit Member of iFixit
Staff
123 Members
85,578 Guides authored
1 Guide Comment
I don’t see a charging antenna coil for sale for the pixel 4, just for the pixel 4 XL. Is the 4XL part compatible with the 4?
Jonathan Polgar - Reply Share
Past 24 Hours: 1
Past 7 Days: 11
Past 30 Days: 117
All Time: 4,850
