Google Pixel 2 XL Rear Camera Replacement
    1. Google Pixel 2 XL Rear Camera Replacement, Opening Procedure: step 1, image 1 of 2 Google Pixel 2 XL Rear Camera Replacement, Opening Procedure: step 1, image 2 of 2
      • If your display glass is cracked, tape over the glass to prevent bodily harm and further breakage. This also makes a smooth surface allowing the suction cup to bond.
      • Apply a suction cup as close to the SIM slot edge of the phone as you can while avoiding the curved edge.
      • The suction cup will not make a good seal on the curved portion of the glass.
      Ask FixBot
    2. Google Pixel 2 XL Rear Camera Replacement: step 2, image 1 of 3 Google Pixel 2 XL Rear Camera Replacement: step 2, image 2 of 3 Google Pixel 2 XL Rear Camera Replacement: step 2, image 3 of 3
      • Pull up on the suction cup with firm, constant pressure and insert an opening pick between the front panel and rear case.
      • This requires a significant amount of force and patience. If you have trouble, rock the suction cup and screen to weaken the adhesive, or apply heat with an iOpener, heat gun, or hair dryer.
      Ask FixBot
    3. Google Pixel 2 XL Rear Camera Replacement: step 3, image 1 of 2 Google Pixel 2 XL Rear Camera Replacement: step 3, image 2 of 2
      • In the following steps, extra caution is required in certain areas to avoid damage to the phone:
      • Do not insert the pick more than 0.25 inches (6 mm) into the bottom edge of the phone. If the pick contacts the folded portion of the OLED panel, it can damage the display.
      • Do not cut along the left edge; there are delicate display cables that can be damaged.
      • Only make very shallow cuts in the upper left corner; prying deeply can damage the front-facing camera.
      Ask FixBot
    4. Google Pixel 2 XL Rear Camera Replacement: step 4, image 1 of 2 Google Pixel 2 XL Rear Camera Replacement: step 4, image 2 of 2
      • Slide the opening pick down the right side of the phone to separate the display adhesive.
      Ask FixBot
    5. Google Pixel 2 XL Rear Camera Replacement: step 5, image 1 of 3 Google Pixel 2 XL Rear Camera Replacement: step 5, image 2 of 3 Google Pixel 2 XL Rear Camera Replacement: step 5, image 3 of 3
      • In the following steps, use the flat edge of the opening pick, rather than a corner, to cut. This will help prevent inserting the pick too deeply.
      • Slide the opening pick around the lower-right corner and along the bottom edge of the phone.
      Ask FixBot
    6. Google Pixel 2 XL Rear Camera Replacement: step 6, image 1 of 3 Google Pixel 2 XL Rear Camera Replacement: step 6, image 2 of 3 Google Pixel 2 XL Rear Camera Replacement: step 6, image 3 of 3
      • Reinsert the flat edge of the pick at the top-right corner of the phone, and slide it around the corner and the top edge of the phone.
      Ask FixBot
    7. Google Pixel 2 XL Rear Camera Replacement: step 7, image 1 of 2 Google Pixel 2 XL Rear Camera Replacement: step 7, image 2 of 2
      • Gently lift the display from the right side of the phone, opening it like a book.
      • If the display doesn't readily lift, do some extra prying to separate the last of the adhesive.
      • Don't try to fully separate the display yet, as fragile ribbon cables still connect it to the phone's motherboard.
      • Carefully lay the display flat on the table next to the rest of the phone, keeping it close to the phone to avoid straining the display and digitizer cables.
      Ask FixBot
    8. Google Pixel 2 XL Rear Camera Replacement: step 8, image 1 of 2 Google Pixel 2 XL Rear Camera Replacement: step 8, image 2 of 2
      • Use the corner of an opening tool to pry up and unclip on the lower edge of the digitizer cable connector cover.
      • The clip securing this cover is along the bottom edge.
      • Pry carefully to avoid damaging the cable underneath, or losing the cover itself.
      • Remove the connector cover.
      • Make sure to keep this component so you can reinstall it during reassembly.
      Ask FixBot
    9. Google Pixel 2 XL Rear Camera Replacement: step 9, image 1 of 2 Google Pixel 2 XL Rear Camera Replacement: step 9, image 2 of 2
      • Use the point of a spudger to lift the digitizer cable connector up and out of its socket on the motherboard.
      • To re-attach press connectors like this one, carefully align and press down on one side until it clicks into place, then repeat on the other side. Do not press down on the middle. If the connector is misaligned, the pins can bend, causing permanent damage.
      • If any part of your screen doesn't respond to touch after your repair, re-seat this connector, making sure it clicks fully into place and that there's no dust or other obstruction in the socket.
      Ask FixBot
    10. Google Pixel 2 XL Rear Camera Replacement: step 10, image 1 of 1
      Tool used on this step:
      Buy
      • Use tweezers to remove any tape from the display connector cover.
      Ask FixBot
    11. Google Pixel 2 XL Rear Camera Replacement: step 11, image 1 of 2 Google Pixel 2 XL Rear Camera Replacement: step 11, image 2 of 2
      • Insert the point of a spudger into the small hole on the edge of the display connector cover.
      • Use the spudger to pry the cover out of its recess.
      Ask FixBot
    12. Google Pixel 2 XL Rear Camera Replacement: step 12, image 1 of 2 Google Pixel 2 XL Rear Camera Replacement: step 12, image 2 of 2
      Ask FixBot
    1. Google Pixel 2 XL Rear Camera Replacement, Midframe: step 13, image 1 of 1
      Magnetic Project Mat
      $19.95
      Buy
      • Remove eleven 3.8 mm Phillips screws securing the midframe.
      Ask FixBot
    2. Google Pixel 2 XL Rear Camera Replacement: step 14, image 1 of 3 Google Pixel 2 XL Rear Camera Replacement: step 14, image 2 of 3 Google Pixel 2 XL Rear Camera Replacement: step 14, image 3 of 3
      • Insert an opening tool into the notch in the midframe near the volume buttons and pry the midframe up and away from the rest of the phone.
      • Remove the midframe.
      Ask FixBot
    1. Google Pixel 2 XL Rear Camera Replacement, Battery Connector: step 15, image 1 of 2 Google Pixel 2 XL Rear Camera Replacement, Battery Connector: step 15, image 2 of 2
      • Use the flat end of a spudger to disconnect the battery connector.
      Ask FixBot
    1. Google Pixel 2 XL Rear Camera Replacement, Rear Camera: step 16, image 1 of 2 Google Pixel 2 XL Rear Camera Replacement, Rear Camera: step 16, image 2 of 2
      • Use the flat edge of a spudger to disconnect the rear camera connector.
      Ask FixBot
    2. Google Pixel 2 XL Rear Camera Replacement: step 17, image 1 of 1
      • Remove the rear camera module.
      Ask FixBot
15 other people completed this guide.
Adam O'Camb
225,561 Reputation
415 Guides authored
6 Guide Comments
Is there a guide for replacing the lens cover? I bought the replacement camera and lens cover, but not sure how to replace the cover. I may not even need a new camera, since my camera is just a little blurry. Any help would be appreciated!
dcmcleod - Reply Share
Unfortunately we don’t have a guide for the camera lens cover yet. It’s just adhered to the back of the phone, so you should be able to heat it and carefully pry it up, or push it out from the inside of the phone. Before installing the new lens cover make sure you scrape all the old adhesive off of the phone and clean adhesion surface with isopropyl alcohol. Then you should be able to use the provided adhesive to install the new cover. Try not to touch the clear part of the new cover since fingerprints might be tough to clean off.
Also, I’d probably try just replacing the lens cover first and then testing the camera (without sealing the phone closed) and see if that fixes your issue before you replace the whole camera. Hope that helps, and good luck with the repair!
Adam O'Camb - Reply Share
I just recently replaced the camera and lens on a pixel 2 xl, after installing and reassembly every time I opened the camera app it just came up dark screen and closed, I cleared cache, memory and even ended up performing a hard reset on the device and nothing helped; also updated the OS and the camera app and nothing helped out. Any suggestions?
Edgar Urena - Reply Share
Sorry you're experiencing that. I just did the camera replacement, and didn't need to clear any cache or anything, and it just works
Niels Klassen - Reply Share
Hi, I've replaced the display on a pixel 2 xl, and all work fine but both camera. I open the camera app and after a black screen the app crasches.
I've bought new back and front camera and replaced but I still have the same issues.
Do you have any suggestions?
Thanks.
Nicola - Reply Share
Past 24 Hours: 3
Past 7 Days: 21
Past 30 Days: 69
All Time: 13,272
