Up to 20% off select tools
Google Pixel 10a Battery Replacement
Views: 9.8K
View statistics:
Past 24 Hours:
51
Past 7 Days:
413
Past 30 Days:
1,566
All Time:
9,794
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 1 - 2 hours
Difficulty: Moderate
Featured Guide
This guide has been found to be exceptionally cool by the iFixit staff.
Fix Kit
This kit contains all the parts and tools needed to complete this guide.
Parts
Tools
Introduction
Go to step 1 ↓
This repair guide was authored by the iFixit staff and hasn’t been endorsed by Google. Learn more about our repair guides here.
Follow this guide to replace a dead or worn-out battery in your Google Pixel 10a. All batteries have limited lifespans. If your phone doesn't hold a charge or dies unexpectedly, it might be time to replace the battery.
You'll need replacement rear cover adhesives to complete this repair.
Note: Any repair can compromise the water resistance of your phone. Retaining water resistance after the repair depends on how accurately the new adhesives are applied and how clean the mating surfaces are.
    1. Google Pixel 10a Battery Replacement, Prepare your Pixel for disassembly: step 1, image 1 of 2 Google Pixel 10a Battery Replacement, Prepare your Pixel for disassembly: step 1, image 2 of 2
      • Let your Pixel's battery drain below 25% before starting this repair. A charged lithium‑ion battery may catch fire if damaged.
      • Unplug all cables and completely power down your Pixel.
      • If your rear cover is bulging, your battery may be swollen—take appropriate precautions.
      Ask FixBot
    1. Google Pixel 10a Battery Replacement, Heat the rear cover: step 2, image 1 of 1
      • The rear cover is secured by mild adhesive. Heating the cover softens the adhesive, making it easier to separate.
      • Use a hair dryer to heat the entire rear cover until it's hot to the touch.
      • For best practices on using a hair dryer to soften adhesive, check out this guide.
      • Alternatively, follow this guide if you're using an iOpener to heat the edge.
      Ask FixBot
    2. Google Pixel 10a Battery Replacement, Create an opening gap: step 3, image 1 of 2 Google Pixel 10a Battery Replacement, Create an opening gap: step 3, image 2 of 2
      • Apply a suction handle near the center of the rear cover's right edge, as close to the edge as possible.
      Ask FixBot
    3. Google Pixel 10a Battery Replacement: step 4, image 1 of 3 Google Pixel 10a Battery Replacement: step 4, image 2 of 3 Google Pixel 10a Battery Replacement: step 4, image 3 of 3
      • Pull up on the suction handle with strong, steady force until a gap forms between the cover and frame.
      • If you're having trouble, reheat the edge and try again.
      • Insert the tip of an opening pick into the gap.
      Ask FixBot
    4. Google Pixel 10a Battery Replacement, Adhesive information: step 5, image 1 of 2 Google Pixel 10a Battery Replacement, Adhesive information: step 5, image 2 of 2
      • The rear cover is secured with adhesive around the frame perimeter and near the cameras. Use this picture as a reference while you separate the adhesive.
      • When separating the left edge adhesive, don't insert your pick more than 3 mm to avoid damaging the wireless charging coil and its graphite film.
      Ask FixBot
    5. Google Pixel 10a Battery Replacement, Separate the rear cover: step 6, image 1 of 3 Google Pixel 10a Battery Replacement, Separate the rear cover: step 6, image 2 of 3 Google Pixel 10a Battery Replacement, Separate the rear cover: step 6, image 3 of 3
      • Slide the opening pick around the entire perimeter to separate the adhesive.
      • If you're having trouble separating the adhesive, apply more heat and try again.
      Ask FixBot
    6. Google Pixel 10a Battery Replacement: step 7, image 1 of 3 Google Pixel 10a Battery Replacement: step 7, image 2 of 3 Google Pixel 10a Battery Replacement: step 7, image 3 of 3
      • Insert the opening pick deeper near the top-left corner and pry to separate the adhesive around the camera bezel.
      Ask FixBot
    7. Google Pixel 10a Battery Replacement: step 8, image 1 of 2 Google Pixel 10a Battery Replacement: step 8, image 2 of 2
      • Slowly peel up and remove the rear cover.
      Ask FixBot
    1. Google Pixel 10a Battery Replacement, Remove the wireless charging assembly screws: step 9, image 1 of 2 Google Pixel 10a Battery Replacement, Remove the wireless charging assembly screws: step 9, image 2 of 2
      Tool used on this step:
      Magnetic Project Mat
      $16.96
      Buy
      • Use a Torx Plus 3IP screwdriver to remove the fifteen 5.0 mm‑long screws securing the wireless charging assembly:
      • Thirteen gray screws
      • Two silver non-magnetic screws
      • Throughout this repair, keep track of each screw and make sure it goes back exactly where it came from to avoid damaging your phone.
      Ask FixBot
    2. Google Pixel 10a Battery Replacement, Unclip the wireless charging assembly: step 10, image 1 of 3 Google Pixel 10a Battery Replacement, Unclip the wireless charging assembly: step 10, image 2 of 3 Google Pixel 10a Battery Replacement, Unclip the wireless charging assembly: step 10, image 3 of 3
      • Use an opening pick to pry up and unclip the wireless charging assembly from the two cutouts—one near the bottom-right corner, and another on the left edge near the power button.
      Ask FixBot
    3. Google Pixel 10a Battery Replacement, Remove the wireless charging assembly: step 11, image 1 of 2 Google Pixel 10a Battery Replacement, Remove the wireless charging assembly: step 11, image 2 of 2
      • Remove the wireless charging assembly.
      Ask FixBot
    1. Google Pixel 10a Battery Replacement, Remove the battery connector cover: step 12, image 1 of 1
      • Use a Torx Plus 3IP screwdriver to remove the 1.9 mm‑long screw securing the battery connector cover.
      Ask FixBot
    2. Google Pixel 10a Battery Replacement: step 13, image 1 of 2 Google Pixel 10a Battery Replacement: step 13, image 2 of 2
      • Remove the battery connector cover.
      Ask FixBot
    3. Google Pixel 10a Battery Replacement, Disconnect the battery: step 14, image 1 of 3 Google Pixel 10a Battery Replacement, Disconnect the battery: step 14, image 2 of 3 Google Pixel 10a Battery Replacement, Disconnect the battery: step 14, image 3 of 3
      • Insert the point of a spudger under the top-right corner of the battery connector.
      • Pry up to disconnect the battery.
      • Throughout the repair, pry only at the instructed area (also marked by a gold line on the circuit board) to prevent damage to the delicate components near the connector socket.
      Ask FixBot
    1. Google Pixel 10a Battery Replacement, Move the side button cable: step 15, image 1 of 3 Google Pixel 10a Battery Replacement, Move the side button cable: step 15, image 2 of 3 Google Pixel 10a Battery Replacement, Move the side button cable: step 15, image 3 of 3
      • Use your fingernail or a spudger to peel up the left-side button cable and flip it over the side of your phone.
      • Be careful not to poke the battery.
      Ask FixBot
    2. Google Pixel 10a Battery Replacement, Peel the pull tabs: step 16, image 1 of 3 Google Pixel 10a Battery Replacement, Peel the pull tabs: step 16, image 2 of 3 Google Pixel 10a Battery Replacement, Peel the pull tabs: step 16, image 3 of 3
      • Use your fingers or an opening pick to peel up a corner of the battery pull tab labeled "2".
      • Grab the tab with your fingers and peel it off the top of the battery.
      • Peel the pull tab labeled "1" completely off the top of the battery.
      Ask FixBot
    3. Google Pixel 10a Battery Replacement, Separate the battery: step 17, image 1 of 2 Google Pixel 10a Battery Replacement, Separate the battery: step 17, image 2 of 2
      • With both hands, firmly grab the pull tab labeled "2" as close to the left edge as possible. Brace your hands against the rest of the phone frame.
      • Pull up with firm, steady force until the battery separates.
      • The battery adhesive is strong and may require multiple attempts before it separates.
      • If you can't loosen the battery, follow the next step for an alternate method.
      Ask FixBot
    4. Google Pixel 10a Battery Replacement, Loosen the battery (alternate method): step 18, image 1 of 3 Google Pixel 10a Battery Replacement, Loosen the battery (alternate method): step 18, image 2 of 3 Google Pixel 10a Battery Replacement, Loosen the battery (alternate method): step 18, image 3 of 3
      • Skip this step if you separated the battery in the previous step.
      • Apply two or three drops of high-concentration (>90%) isopropyl alcohol to the left edge of the battery.
      • Tilt the left edge of the phone up to help the alcohol flow under the battery.
      • Wait one minute to allow the alcohol to soften the adhesive.
      • Use the flat edge of an opening pick to pry up the left edge of the battery until it separates.
      Ask FixBot
    5. Google Pixel 10a Battery Replacement, Remove the battery and liner: step 19, image 1 of 2 Google Pixel 10a Battery Replacement, Remove the battery and liner: step 19, image 2 of 2
      • Peel and remove the battery and its plastic liner from the phone.
      Ask FixBot
    1. Google Pixel 10a Battery Replacement, Disassembly complete: step 20, image 1 of 1
      • Congratulations on completing disassembly! The remaining steps will show how to reassemble your phone.
      Ask FixBot
    1. Google Pixel 10a Battery Replacement, Clean the frame: step 21, image 1 of 1
      • Use high‑concentration (>90%) isopropyl alcohol and a lint‑free cloth (or coffee filters) to remove any adhesive residue from the battery well.
      Ask FixBot
    2. Google Pixel 10a Battery Replacement, Remove the thin battery liner: step 22, image 1 of 1
      • Remove the thin liner from the top edge of the back of the battery.
      Ask FixBot
    3. Google Pixel 10a Battery Replacement, Move the left button cable out of the way: step 23, image 1 of 1
      • Bend the left button cable over the edge so it'll be out of the battery's way.
      Ask FixBot
    4. Google Pixel 10a Battery Replacement, Connect the battery: step 24, image 1 of 1
      • Hold the battery above its recess and use your finger to press and connect the battery press connector.
      • This will help align the battery when you stick it in place.
      • Don't try to force the connector into place. If you're having trouble, reposition it and try again.
      Ask FixBot
    5. Google Pixel 10a Battery Replacement, Install the battery: step 25, image 1 of 3 Google Pixel 10a Battery Replacement, Install the battery: step 25, image 2 of 3 Google Pixel 10a Battery Replacement, Install the battery: step 25, image 3 of 3
      • With one hand, steady the battery over its recess.
      • With the other hand, pull the liner from the underside of the battery to expose the adhesive.
      • Carefully lay the battery in its recess.
      Ask FixBot
    6. Google Pixel 10a Battery Replacement: step 26, image 1 of 2 Google Pixel 10a Battery Replacement: step 26, image 2 of 2
      • Use your fingers to firmly press on the battery to secure it with the adhesive.
      Ask FixBot
    7. Google Pixel 10a Battery Replacement, Install the battery connector cover: step 27, image 1 of 2 Google Pixel 10a Battery Replacement, Install the battery connector cover: step 27, image 2 of 2
      • Hook the left edge of the battery connector cover in place, then lay the cover down flat.
      Ask FixBot
    8. Google Pixel 10a Battery Replacement: step 28, image 1 of 1
      • Use a Torx Plus 3IP screwdriver to install the 1.9 mm‑long battery connector cover screw.
      Ask FixBot
    9. Google Pixel 10a Battery Replacement, Fold the left button cable down: step 29, image 1 of 2 Google Pixel 10a Battery Replacement, Fold the left button cable down: step 29, image 2 of 2
      • Use your finger to fold the left button cable onto the battery and press it in place.
      Ask FixBot
    1. Google Pixel 10a Battery Replacement, Install the wireless charging assembly: step 30, image 1 of 3 Google Pixel 10a Battery Replacement, Install the wireless charging assembly: step 30, image 2 of 3 Google Pixel 10a Battery Replacement, Install the wireless charging assembly: step 30, image 3 of 3
      • Lay the wireless charging assembly onto the frame.
      • Use your fingers to press around the perimeter to engage all of its clips.
      • Stop if the assembly feels like it won't clip in. Check if anything underneath it may be out of place.
      Ask FixBot
    2. Google Pixel 10a Battery Replacement: step 31, image 1 of 2 Google Pixel 10a Battery Replacement: step 31, image 2 of 2
      • Use a Torx Plus 3IP screwdriver to install the fifteen 5.0 mm‑long wireless charging assembly screws:
      Ask FixBot
    1. Google Pixel 10a Battery Replacement, Test your repair: step 32, image 1 of 1
      • Now is a good time to test your repair:
      • Power on your phone and check all functions.
      • Run a diagnostics test with the built-in Pixel Diagnostic tool.
      • If the screen or fingerprint sensor doesn't work correctly, you may need to reconnect the screen connector.
      • Fully power off your phone before you continue with reassembly.
      Ask FixBot
    1. Google Pixel 10a Battery Replacement, Clean the frame: step 33, image 1 of 3 Google Pixel 10a Battery Replacement, Clean the frame: step 33, image 2 of 3 Google Pixel 10a Battery Replacement, Clean the frame: step 33, image 3 of 3
      • Take your time cleaning the frame. A clean frame allows replacement adhesive to lay evenly, ensuring a better bond.
      • Use your fingers, spudger, or tweezers to remove the adhesive from the frame perimeter.
      • If you scrape up a piece big enough to grip with your fingers, you can pull long sections of the adhesive up. Pull slowly and straight in the opposite direction of the adhesive.
      • Use some high concentration (>90%) isopropyl alcohol and a lint-free cloth (or coffee filter) to remove any adhesive residue.
      Ask FixBot
    2. Google Pixel 10a Battery Replacement, Replace the camera bezel adhesive: step 34, image 1 of 2 Google Pixel 10a Battery Replacement, Replace the camera bezel adhesive: step 34, image 2 of 2
      • Inspect the adhesive blocks surrounding the rear cameras. If they're clean and unwrinkled, you can reuse them and skip down three steps.
      • Use the point of a spudger to pry up and remove the seven adhesive blocks surrounding the rear cameras.
      Ask FixBot
    3. Google Pixel 10a Battery Replacement: step 35, image 1 of 3 Google Pixel 10a Battery Replacement: step 35, image 2 of 3 Google Pixel 10a Battery Replacement: step 35, image 3 of 3
      • Peel the clear liner from the camera bezel adhesive.
      • Carefully align and lay the adhesive in place. Use the rear cameras to help with alignment.
      Ask FixBot
    4. Google Pixel 10a Battery Replacement: step 36, image 1 of 3 Google Pixel 10a Battery Replacement: step 36, image 2 of 3 Google Pixel 10a Battery Replacement: step 36, image 3 of 3
      • Use your fingers to press the camera bezel adhesive onto the frame.
      • Peel and remove the top blue liner from the adhesive.
      • There will still be a thin liner covering the adhesive.
      Ask FixBot
    5. Google Pixel 10a Battery Replacement, Replace the rear cover interior adhesive: step 37, image 1 of 2 Google Pixel 10a Battery Replacement, Replace the rear cover interior adhesive: step 37, image 2 of 2
      • Inspect the interior adhesive blocks on the rear cover. If they're clean and unwrinkled, you can reuse them and skip down two steps.
      • Use a spudger to scrape and remove the interior adhesive blocks from the rear cover.
      Ask FixBot
    6. Google Pixel 10a Battery Replacement: step 38, image 1 of 3 Google Pixel 10a Battery Replacement: step 38, image 2 of 3 Google Pixel 10a Battery Replacement: step 38, image 3 of 3
      • Peel the clear liner from the interior adhesive sheet.
      • Align and press the adhesive onto the rear cover. Use the camera cutout to help with alignment.
      • Slowly peel and remove the large liner.
      Ask FixBot
    7. Google Pixel 10a Battery Replacement, Install the rear cover adhesive: step 39, image 1 of 1
      • Without peeling any liners, hold the rear cover adhesive over the phone to figure out how it'll sit on the frame. Use the camera cutout to help with orientation.
      Ask FixBot
    8. Google Pixel 10a Battery Replacement: step 40, image 1 of 1
      • Peel down the top half of the clear liner to expose the adhesive—don't fully remove the liner yet.
      Ask FixBot
    9. Google Pixel 10a Battery Replacement: step 41, image 1 of 3 Google Pixel 10a Battery Replacement: step 41, image 2 of 3 Google Pixel 10a Battery Replacement: step 41, image 3 of 3
      • Take your time aligning the adhesive to the frame. If you apply it incorrectly, you'll need to restart with new adhesive.
      • Align and lay the top edge of the adhesive onto the frame.
      • Press down along the top edge to secure the alignment.
      • Slowly peel away the clear liner as you press the rest of the adhesive in place.
      Ask FixBot
    10. Google Pixel 10a Battery Replacement: step 42, image 1 of 2 Google Pixel 10a Battery Replacement: step 42, image 2 of 2
      • Use a spudger to press the adhesive onto the entire frame perimeter.
      Ask FixBot
    11. Google Pixel 10a Battery Replacement: step 43, image 1 of 2 Google Pixel 10a Battery Replacement: step 43, image 2 of 2
      • Peel up and remove the large liner from the rear cover adhesive.
      Ask FixBot
    12. Google Pixel 10a Battery Replacement: step 44, image 1 of 1
      • If you installed replacement camera bezel adhesive, remove all remaining liners from it.
      Ask FixBot
    13. Google Pixel 10a Battery Replacement: step 45, image 1 of 1
      • Remove the perimeter adhesive liner.
      • Carefully inspect the frame for any remaining liners and remove them.
      Ask FixBot
    14. Google Pixel 10a Battery Replacement, Inspect the rear camera glass: step 46, image 1 of 2 Google Pixel 10a Battery Replacement, Inspect the rear camera glass: step 46, image 2 of 2
      • Make sure the rear cover camera cutouts are clean. Carefully wipe them with a lint-free cloth if needed.
      • Remove any lens caps or liners from the rear cameras. Make sure the lenses are clean. Gently wipe them with a lint-free cloth if needed.
      Ask FixBot
    15. Google Pixel 10a Battery Replacement, Install the rear cover: step 47, image 1 of 3 Google Pixel 10a Battery Replacement, Install the rear cover: step 47, image 2 of 3 Google Pixel 10a Battery Replacement, Install the rear cover: step 47, image 3 of 3
      • Lay the rear cover over the frame.
      • Firmly press around the perimeter to secure the adhesive.
      • You can also hold your phone and squeeze firmly around the perimeter to strengthen the adhesive bond.
      • For an even more secure bond, lay your phone screen-down on a clean and flat surface underneath a few books overnight.
      Ask FixBot
Congratulations on completing your repair!
For optimal performance, calibrate your newly installed battery after completing this guide.
To run a diagnostics test with the built-in Pixel Diagnostic tool, click here.
Author
with
Arthur Shi
354,431 Reputation
938 Guides authored
0 Guide Comments
Past 24 Hours: 51
Past 7 Days: 413
Past 30 Days: 1,566
All Time: 9,794
