Google Pixel 10 Pro XL Battery Replacement
    1. Google Pixel 10 Pro XL Battery Replacement, Prepare your Pixel for disassembly: step 1, image 1 of 2 Google Pixel 10 Pro XL Battery Replacement, Prepare your Pixel for disassembly: step 1, image 2 of 2
      • Let your Pixel's battery drain below 25% before starting this repair. A charged lithium‑ion battery may catch fire if damaged.
      • Unplug all cables and completely power down your phone.
      Ask FixBot
    1. Google Pixel 10 Pro XL Battery Replacement, Cracked glass preparation: step 2, image 1 of 3 Google Pixel 10 Pro XL Battery Replacement, Cracked glass preparation: step 2, image 2 of 3 Google Pixel 10 Pro XL Battery Replacement, Cracked glass preparation: step 2, image 3 of 3
      • Glass shards can complicate disassembly—or worse, cause injury. If your phone's back glass is cracked, follow this step.
      • Apply strips of packing tape to the cracked glass until it's completely covered—this will help keep the glass contained and allow the suction cup to stick.
      • Make sure there's a single strip (not overlapping) of tape across the bottom edge, big enough for a suction cup to fit on.
      • Only cover the glass itself—don't stick any tape to the frame.
      • Consider wearing safety glasses to protect your eyes from any glass shaken free during the repair.
      Ask FixBot
    2. Google Pixel 10 Pro XL Battery Replacement, Heat the bottom edge: step 3, image 1 of 1
      • Adhesive secures the back glass to the frame. Heating the glass softens the adhesive, making it easier to separate.
      • Heat an iOpener and lay it on the bottom edge of the back glass for two minutes.
      • Alternatively, you can use a hair dryer or heat gun to heat the back glass.
      • Improper use of a heat gun can destroy the display and/or battery—follow the linked instructions carefully.
      Ask FixBot
    3. Google Pixel 10 Pro XL Battery Replacement, Apply a suction handle: step 4, image 1 of 2 Google Pixel 10 Pro XL Battery Replacement, Apply a suction handle: step 4, image 2 of 2
      • Apply a suction handle to the center of the back glass's bottom edge, as close to the edge as possible.
      Ask FixBot
    4. Google Pixel 10 Pro XL Battery Replacement, Insert an opening pick: step 5, image 1 of 3 Google Pixel 10 Pro XL Battery Replacement, Insert an opening pick: step 5, image 2 of 3 Google Pixel 10 Pro XL Battery Replacement, Insert an opening pick: step 5, image 3 of 3
      • Pull up on the suction handle with strong, steady force until a gap forms between the back glass and frame.
      • Insert the tip of an opening pick into the gap.
      Ask FixBot
    5. Google Pixel 10 Pro XL Battery Replacement, Back glass adhesive information: step 6, image 1 of 3 Google Pixel 10 Pro XL Battery Replacement, Back glass adhesive information: step 6, image 2 of 3 Google Pixel 10 Pro XL Battery Replacement, Back glass adhesive information: step 6, image 3 of 3
      • The back glass is secured with adhesive around the perimeter of the frame. Use this picture as a reference while you separate the adhesive.
      • A cable connects the back glass near the power button. Don't insert your pick here to avoid damaging the cable.
      Ask FixBot
    6. Google Pixel 10 Pro XL Battery Replacement, Separate the bottom edge adhesive: step 7, image 1 of 3 Google Pixel 10 Pro XL Battery Replacement, Separate the bottom edge adhesive: step 7, image 2 of 3 Google Pixel 10 Pro XL Battery Replacement, Separate the bottom edge adhesive: step 7, image 3 of 3
      • If the back glass feels stuck at any point during the next few steps, apply heat to the area and try again.
      • Slide the opening pick along the bottom edge to separate the adhesive.
      • Leave the pick inserted under the bottom left corner to prevent the adhesive from re‑sealing.
      Ask FixBot
    7. Google Pixel 10 Pro XL Battery Replacement, Separate the bottom left adhesive: step 8, image 1 of 3 Google Pixel 10 Pro XL Battery Replacement, Separate the bottom left adhesive: step 8, image 2 of 3 Google Pixel 10 Pro XL Battery Replacement, Separate the bottom left adhesive: step 8, image 3 of 3
      • Insert a second pick under the bottom left corner and slide it up the left edge, stopping at the power button.
      • Leave the pick inserted to prevent the adhesive from re‑sealing.
      Ask FixBot
    8. Google Pixel 10 Pro XL Battery Replacement, Separate the right edge adhesive: step 9, image 1 of 3 Google Pixel 10 Pro XL Battery Replacement, Separate the right edge adhesive: step 9, image 2 of 3 Google Pixel 10 Pro XL Battery Replacement, Separate the right edge adhesive: step 9, image 3 of 3
      • Insert a third pick under the bottom right corner of the back glass and slide it up the right edge.
      • Leave the pick inserted under the top right corner.
      Ask FixBot
    9. Google Pixel 10 Pro XL Battery Replacement, Separate the top edge adhesive: step 10, image 1 of 3 Google Pixel 10 Pro XL Battery Replacement, Separate the top edge adhesive: step 10, image 2 of 3 Google Pixel 10 Pro XL Battery Replacement, Separate the top edge adhesive: step 10, image 3 of 3
      • Insert a fourth pick under the top right corner.
      • Slide the pick along the top edge and slightly around the top left corner, stopping at the bottom of the camera bump.
      • Don't try to fully remove the back glass yet, as it's still connected by a ribbon cable.
      Ask FixBot
    10. Google Pixel 10 Pro XL Battery Replacement, Prop up the back glass: step 11, image 1 of 3 Google Pixel 10 Pro XL Battery Replacement, Prop up the back glass: step 11, image 2 of 3 Google Pixel 10 Pro XL Battery Replacement, Prop up the back glass: step 11, image 3 of 3
      • Flip the back glass over the left side of the phone and use the suction handle (or a sturdy object) to prop it up.
      • If the back glass still feels stuck, go back around the perimeter with an opening pick and separate any remaining adhesive.
      Ask FixBot
    11. Google Pixel 10 Pro XL Battery Replacement, Remove the bracket screws: step 12, image 1 of 2 Google Pixel 10 Pro XL Battery Replacement, Remove the bracket screws: step 12, image 2 of 2
      • Use a Torx Plus 3IP screwdriver to remove the two 2.3 mm‑long screws securing the back glass connector bracket.
      Ask FixBot
    12. Google Pixel 10 Pro XL Battery Replacement: step 13, image 1 of 2 Google Pixel 10 Pro XL Battery Replacement: step 13, image 2 of 2
      • Use tweezers or your fingers to remove the bracket.
      • Be careful not to scratch or smudge the rear cameras.
      Ask FixBot
    13. Google Pixel 10 Pro XL Battery Replacement, Disconnect the back glass: step 14, image 1 of 3 Google Pixel 10 Pro XL Battery Replacement, Disconnect the back glass: step 14, image 2 of 3 Google Pixel 10 Pro XL Battery Replacement, Disconnect the back glass: step 14, image 3 of 3
      • Use the point of a spudger to pry up and disconnect the battery and back glass press connectors.
      Ask FixBot
    14. Google Pixel 10 Pro XL Battery Replacement, Remove the back glass: step 15, image 1 of 1
      • Remove the back glass.
      Ask FixBot
    1. Google Pixel 10 Pro XL Battery Replacement, Remove the motherboard cover screws: step 16, image 1 of 2 Google Pixel 10 Pro XL Battery Replacement, Remove the motherboard cover screws: step 16, image 2 of 2
      • Use a Torx Plus 3IP screwdriver to remove the four 5.0 mm‑long screws securing the motherboard cover.
      Ask FixBot
    2. Google Pixel 10 Pro XL Battery Replacement, Remove the motherboard cover: step 17, image 1 of 2 Google Pixel 10 Pro XL Battery Replacement, Remove the motherboard cover: step 17, image 2 of 2
      • Remove the motherboard cover.
      Ask FixBot
    1. Google Pixel 10 Pro XL Battery Replacement, Remove the USB‑C board cover screws: step 18, image 1 of 2 Google Pixel 10 Pro XL Battery Replacement, Remove the USB‑C board cover screws: step 18, image 2 of 2
      • Use a Torx Plus 3IP screwdriver to remove the seven screws:
      • Five 5.0 mm‑long screws
      • Two 4.1 mm‑long screws
      Ask FixBot
    2. Google Pixel 10 Pro XL Battery Replacement, Remove the USB‑C board cover: step 19, image 1 of 2 Google Pixel 10 Pro XL Battery Replacement, Remove the USB‑C board cover: step 19, image 2 of 2
      • Remove the USB‑C board cover.
      Ask FixBot
    3. Google Pixel 10 Pro XL Battery Replacement: step 20, image 1 of 3 Google Pixel 10 Pro XL Battery Replacement: step 20, image 2 of 3 Google Pixel 10 Pro XL Battery Replacement: step 20, image 3 of 3
      • Use a spudger to pry up and disconnect both interconnect cable press connectors—one on the USB‑C board and one on the motherboard.
      Ask FixBot
    4. Google Pixel 10 Pro XL Battery Replacement, Remove the interconnect cable: step 21, image 1 of 2 Google Pixel 10 Pro XL Battery Replacement, Remove the interconnect cable: step 21, image 2 of 2
      • Remove the interconnect cable.
      Ask FixBot
    1. Google Pixel 10 Pro XL Battery Replacement, Peel up the battery pull tab: step 22, image 1 of 3 Google Pixel 10 Pro XL Battery Replacement, Peel up the battery pull tab: step 22, image 2 of 3 Google Pixel 10 Pro XL Battery Replacement, Peel up the battery pull tab: step 22, image 3 of 3
      • Use your fingers to peel up the entire battery tab on the left side of the battery, including the skinny strip running along the side.
      Ask FixBot
    2. Google Pixel 10 Pro XL Battery Replacement: step 23, image 1 of 1
      Tool used on this step:
      Finger Stalls
      $8.99
      Buy
      Ask FixBot
    3. Google Pixel 10 Pro XL Battery Replacement, Separate the battery adhesive: step 24, image 1 of 3 Google Pixel 10 Pro XL Battery Replacement, Separate the battery adhesive: step 24, image 2 of 3 Google Pixel 10 Pro XL Battery Replacement, Separate the battery adhesive: step 24, image 3 of 3
      • Secure the right side of your phone with one hand, and use your free hand to grip the battery pull tab.
      • Make sure your hand securing the phone is mainly pressing on the frame—it shouldn't be covering the battery or pressing down on delicate components.
      • Pull straight up on the tab and apply constant, steady force until the adhesive separates.
      Ask FixBot
    4. Google Pixel 10 Pro XL Battery Replacement, Remove the battery: step 25, image 1 of 3 Google Pixel 10 Pro XL Battery Replacement, Remove the battery: step 25, image 2 of 3 Google Pixel 10 Pro XL Battery Replacement, Remove the battery: step 25, image 3 of 3
      • Grip the battery and slowly pull it away from your phone to peel the plastic sleeve out of the recess.
      • Remove the battery.
      Ask FixBot
    1. Google Pixel 10 Pro XL Battery Replacement, Disassembly complete: step 26, image 1 of 1
      • Congratulations on completing disassembly! The remaining steps will show how to reassemble your phone.
      Ask FixBot
    1. Google Pixel 10 Pro XL Battery Replacement, Clean the battery recess: step 27, image 1 of 3 Google Pixel 10 Pro XL Battery Replacement, Clean the battery recess: step 27, image 2 of 3 Google Pixel 10 Pro XL Battery Replacement, Clean the battery recess: step 27, image 3 of 3
      • Before installing a new battery, check the recess for leftover bits of plastic, as well as adhesive residue from the battery sleeve.
      • If the battery came out cleanly, you can skip this step.
      • Remove any bits of plastic from the old battery sleeve.
      • Use one or two drops high‑concentration (>90%) isopropyl alcohol and a microfiber or lint‑free cloth to clean up any adhesive residue.
      • Be careful not to get alcohol in the cutouts in the battery recess—the bottom of the screen is exposed and may get damaged.
      • Allow the alcohol to dry completely before continuing.
      Ask FixBot
    2. Google Pixel 10 Pro XL Battery Replacement, Remove the battery liner: step 28, image 1 of 1
      • Remove the large, colored liner from the battery to expose the adhesive.
      Ask FixBot
    3. Google Pixel 10 Pro XL Battery Replacement, Install the battery: step 29, image 1 of 3 Google Pixel 10 Pro XL Battery Replacement, Install the battery: step 29, image 2 of 3 Google Pixel 10 Pro XL Battery Replacement, Install the battery: step 29, image 3 of 3
      • Hold the battery above its recess and use your finger to push down and reconnect the battery press connector.
      • Temporarily reconnecting the battery ensures that it's sitting properly in its recess.
      • Lay the battery into its recess and press down firmly to secure it.
      Ask FixBot
    4. Google Pixel 10 Pro XL Battery Replacement, Disconnect the battery: step 30, image 1 of 2 Google Pixel 10 Pro XL Battery Replacement, Disconnect the battery: step 30, image 2 of 2
      • Use a spudger to pry up and disconnect the battery.
      Ask FixBot
    5. Google Pixel 10 Pro XL Battery Replacement: step 31, image 1 of 2 Google Pixel 10 Pro XL Battery Replacement: step 31, image 2 of 2
      • Use your fingers to remove any remaining stickers or liners from the battery.
      Ask FixBot
    1. Google Pixel 10 Pro XL Battery Replacement, Place the interconnect cable: step 32, image 1 of 2 Google Pixel 10 Pro XL Battery Replacement, Place the interconnect cable: step 32, image 2 of 2
      • Put the interconnect cable back into place.
      Ask FixBot
    2. Google Pixel 10 Pro XL Battery Replacement, Connect the interconnect cable: step 33, image 1 of 3 Google Pixel 10 Pro XL Battery Replacement, Connect the interconnect cable: step 33, image 2 of 3 Google Pixel 10 Pro XL Battery Replacement, Connect the interconnect cable: step 33, image 3 of 3
      • Use your finger to press down and reconnect both interconnect cable press connectors.
      Ask FixBot
    3. Google Pixel 10 Pro XL Battery Replacement, Install the USB‑C board cover: step 34, image 1 of 2 Google Pixel 10 Pro XL Battery Replacement, Install the USB‑C board cover: step 34, image 2 of 2
      • Put the USB‑C board cover back into place.
      Ask FixBot
    4. Google Pixel 10 Pro XL Battery Replacement: step 35, image 1 of 2 Google Pixel 10 Pro XL Battery Replacement: step 35, image 2 of 2
      • Use a Torx Plus 3IP screwdriver to install the seven screws:
      Ask FixBot
    1. Google Pixel 10 Pro XL Battery Replacement, Place the motherboard cover: step 36, image 1 of 2 Google Pixel 10 Pro XL Battery Replacement, Place the motherboard cover: step 36, image 2 of 2
      • Put the motherboard cover back into place.
      Ask FixBot
    2. Google Pixel 10 Pro XL Battery Replacement, Install the motherboard cover screws: step 37, image 1 of 2 Google Pixel 10 Pro XL Battery Replacement, Install the motherboard cover screws: step 37, image 2 of 2
      • Use a Torx Plus 3IP screwdriver to install the four 5.0 mm‑long screws securing the motherboard cover.
      Ask FixBot
    1. Google Pixel 10 Pro XL Battery Replacement, Remove the old back glass adhesive: step 38, image 1 of 2 Google Pixel 10 Pro XL Battery Replacement, Remove the old back glass adhesive: step 38, image 2 of 2
      • Before installing new adhesive, all the old adhesive and its residue must be completely removed from the frame.
      • Take your time during the next two steps. A clean frame allows replacement adhesive to lay totally flat, ensuring a better seal for your back glass.
      Ask FixBot
    2. Google Pixel 10 Pro XL Battery Replacement: step 39, image 1 of 3 Google Pixel 10 Pro XL Battery Replacement: step 39, image 2 of 3 Google Pixel 10 Pro XL Battery Replacement: step 39, image 3 of 3
      • Removing all the old adhesive can be very tricky and time‑consuming.
      • When removing the back glass adhesive during this step, be very careful not to damage the battery or any of the fragile components near the perimeter of the frame.
      • Use the point of a spudger to remove all the old screen adhesive from the frame. Try to "roll" the adhesive onto itself so it balls up, making it easier to remove.
      • If you can ball up a big enough chunk, use tweezers to slowly pull the adhesive the opposite way you were scraping with your spudger.
      • If you're having trouble removing smaller chunks, apply a single drop of high‑concentration (>90%) isopropyl alcohol and scrape them up with your spudger.
      Ask FixBot
    3. Google Pixel 10 Pro XL Battery Replacement: step 40, image 1 of 1
      • Wrap a microfiber or lint‑free cloth around a spudger.
      • Use the spudger and high‑concentration (>90%) isopropyl alcohol to clean up all the remaining adhesive residue from the frame, applying more drops of alcohol as necessary.
      • Let the alcohol dry completely before continuing.
      Ask FixBot
    4. Google Pixel 10 Pro XL Battery Replacement: step 41, image 1 of 3 Google Pixel 10 Pro XL Battery Replacement: step 41, image 2 of 3 Google Pixel 10 Pro XL Battery Replacement: step 41, image 3 of 3
      • If you're reinstalling your original back glass, repeat the procedures in the previous two steps on the back glass to clean it.
      Ask FixBot
    5. Google Pixel 10 Pro XL Battery Replacement, Orient the adhesive: step 42, image 1 of 2 Google Pixel 10 Pro XL Battery Replacement, Orient the adhesive: step 42, image 2 of 2
      • Before applying the back glass adhesive, make sure you know how it will sit on the frame. If you apply the adhesive incorrectly, you'll need to restart with new adhesive.
      • Hold the adhesive above the frame to find its orientation. Use the rear camera cutout in the liner to help visualize how it will lay in the frame.
      Ask FixBot
    6. Google Pixel 10 Pro XL Battery Replacement: step 43, image 1 of 1
      • Peel down the top half of the larger, clear liner to expose the adhesive—don't fully remove the liner yet.
      Ask FixBot
    7. Google Pixel 10 Pro XL Battery Replacement, Install the back glass adhesive: step 44, image 1 of 3 Google Pixel 10 Pro XL Battery Replacement, Install the back glass adhesive: step 44, image 2 of 3 Google Pixel 10 Pro XL Battery Replacement, Install the back glass adhesive: step 44, image 3 of 3
      • Take your time aligning the adhesive with the frame—it's very sticky and can't be moved after you apply it.
      • With the larger, clear liner folded towards the bottom of the phone, lay the exposed top edge of the adhesive onto the frame.
      • Use the lip of the frame to help align the adhesive.
      • Once the top edge is properly aligned, gently press down on the top corners to secure the adhesive.
      Ask FixBot
    8. Google Pixel 10 Pro XL Battery Replacement: step 45, image 1 of 3 Google Pixel 10 Pro XL Battery Replacement: step 45, image 2 of 3 Google Pixel 10 Pro XL Battery Replacement: step 45, image 3 of 3
      • Slowly lay the rest of the adhesive onto the frame, pressing it into place and peeling away the larger, clear liner as you go.
      Ask FixBot
    9. Google Pixel 10 Pro XL Battery Replacement: step 46, image 1 of 3 Google Pixel 10 Pro XL Battery Replacement: step 46, image 2 of 3 Google Pixel 10 Pro XL Battery Replacement: step 46, image 3 of 3
      • Use a spudger to press down firmly on the adhesive to secure it to the frame.
      Ask FixBot
    10. Google Pixel 10 Pro XL Battery Replacement, Remove the large colored liner: step 47, image 1 of 3 Google Pixel 10 Pro XL Battery Replacement, Remove the large colored liner: step 47, image 2 of 3 Google Pixel 10 Pro XL Battery Replacement, Remove the large colored liner: step 47, image 3 of 3
      • Slowly peel up and remove the large colored liner, gripping it from the cutout near the top edge.
      • If the adhesive starts to peel up with the liner, check that you’ve pushed all of it into place with your spudger. If it continues to peel up, hold it down with the point of your spudger as you go.
      Ask FixBot
    11. Google Pixel 10 Pro XL Battery Replacement, Remove any liners from the back glass: step 48, image 1 of 2 Google Pixel 10 Pro XL Battery Replacement, Remove any liners from the back glass: step 48, image 2 of 2
      • If you're installing a new back glass, your replacement will have various protective liners and pieces of tape on the underside that must be removed. Your part may have different pieces in different locations, so make sure to check carefully!
      • Remove all liners from the underside of the back glass, paying special attention to the front camera cutouts and bottom edge.
      • Usually, you can identify the liners by their pull tabs.
      Ask FixBot
    12. Google Pixel 10 Pro XL Battery Replacement, Prop up the back glass: step 49, image 1 of 1
      • Apply a suction handle to the back glass and prop it up on the left side of your phone, so the cable is near its connector.
      • Alternatively, you can use a sturdy object (such as a stack of books) to prop up the back glass.
      Ask FixBot
    13. Google Pixel 10 Pro XL Battery Replacement, Reconnect the back glass and battery: step 50, image 1 of 3 Google Pixel 10 Pro XL Battery Replacement, Reconnect the back glass and battery: step 50, image 2 of 3 Google Pixel 10 Pro XL Battery Replacement, Reconnect the back glass and battery: step 50, image 3 of 3
      • Use your finger to press down and connect the back glass and battery press connectors.
      • For wider connectors like the back glass one, first press down on one of the short sides until it clicks into place, then repeat on the other side. Don't press down in the middle. If the connector is misaligned, the pins can bend and cause permanent damage.
      Ask FixBot
    14. Google Pixel 10 Pro XL Battery Replacement: step 51, image 1 of 2 Google Pixel 10 Pro XL Battery Replacement: step 51, image 2 of 2
      • Put the back glass connector cover back into place.
      Ask FixBot
    15. Google Pixel 10 Pro XL Battery Replacement: step 52, image 1 of 2 Google Pixel 10 Pro XL Battery Replacement: step 52, image 2 of 2
      • Use a Torx Plus 3IP screwdriver to install the two 2.3 mm‑long screws securing the cover.
      Ask FixBot
    16. Google Pixel 10 Pro XL Battery Replacement, Secure the adhesive: step 53, image 1 of 3 Google Pixel 10 Pro XL Battery Replacement, Secure the adhesive: step 53, image 2 of 3 Google Pixel 10 Pro XL Battery Replacement, Secure the adhesive: step 53, image 3 of 3
      • This is a good point to power on your device and test all functions before sealing it up. If you have trouble, try some basic troubleshooting. Be sure to power back down completely before you continue working.
      Ask FixBot
    17. Google Pixel 10 Pro XL Battery Replacement, Remove the remaining liners: step 54, image 1 of 3 Google Pixel 10 Pro XL Battery Replacement, Remove the remaining liners: step 54, image 2 of 3 Google Pixel 10 Pro XL Battery Replacement, Remove the remaining liners: step 54, image 3 of 3
      • Remove the remaining liners from the back glass adhesive.
      Ask FixBot
    18. Google Pixel 10 Pro XL Battery Replacement, Install the back glass: step 55, image 1 of 3 Google Pixel 10 Pro XL Battery Replacement, Install the back glass: step 55, image 2 of 3 Google Pixel 10 Pro XL Battery Replacement, Install the back glass: step 55, image 3 of 3
      • Flip the back glass onto the frame and press it firmly into place.
      • Hold your phone up and squeeze firmly around the perimeter to strengthen the bond.
      • For an even stronger bond, you can stack books on the back glass or use screen vise clamps.
      Ask FixBot
Congratulations on completing your repair!
For optimal performance, calibrate your newly installed battery after completing this guide.
To run a diagnostics test with the built-in Pixel Diagnostic tool, click here.
2 other people completed this guide.
Spencer Day
206,465 Reputation
1,266 Guides authored
0 Guide Comments
Past 24 Hours: 13
Past 7 Days: 140
Past 30 Days: 578
All Time: 4,944
