Up to 20% off select tools
Google Home Mini USB Power Port Replacement
Views: 8.5K
View statistics:
Past 24 Hours:
7
Past 7 Days:
33
Past 30 Days:
142
All Time:
8,541
Comments: 14
5 comments on steps, 9 guide comments.
Go to guide comments
Completed: 12
12 people have marked this guide "completed." Will you be next?
Favorites: 1
1 person has favorited (and subscribed to) this guide. Will you be next?
Time Required: 8 minutes
Difficulty: Moderate
Tools
Introduction
Go to step 1 ↓
A guide to change Google Home Mini USB power port.
    1. Google Home Mini USB Power Port Replacement, Google Home Mini Disassembly: step 1, image 1 of 1
      • Place device on a flat surface.
      Ask FixBot
    2. Google Home Mini USB Power Port Replacement: step 2, image 1 of 1
      Ask FixBot
    3. Google Home Mini USB Power Port Replacement: step 3, image 1 of 1
      • Remove the lower half of the device.
      • Be careful as a black ribbon cable connects the two halves together.
      Ask FixBot
    4. Google Home Mini USB Power Port Replacement: step 4, image 1 of 1
      Tool used on this step:
      Buy
      • Using a pair of tweezers, unlatch the Zero Insertion Force (ZIF) fastener that connects the ribbon cable to the board.
      • Flip up and push the ZIF fastener towards outside of the lower case to loosen it.
      Ask FixBot
    5. Google Home Mini USB Power Port Replacement: step 5, image 1 of 1
      • Pull the ribbon cable off.
      Ask FixBot
    1. Google Home Mini USB Power Port Replacement, USB Power Port: step 6, image 1 of 2 Google Home Mini USB Power Port Replacement, USB Power Port: step 6, image 2 of 2
      • Remove the three 5.3mm T6 Torx screws from the board.
      Ask FixBot
    2. Google Home Mini USB Power Port Replacement: step 7, image 1 of 2 Google Home Mini USB Power Port Replacement: step 7, image 2 of 2
      • Remove the black metal plate from the board.
      Ask FixBot
    3. Google Home Mini USB Power Port Replacement: step 8, image 1 of 2 Google Home Mini USB Power Port Replacement: step 8, image 2 of 2
      • Remove the board.
      Ask FixBot
12 other people completed this guide.
Author
with
Mia Sulaiman
1,191 Reputation
3 Guides authored
IUPUI, Team S1-G4, Harley Spring 2018 Member of IUPUI, Team S1-G4, Harley Spring 2018
IUPUI-HARLEY-S18S1G4
7 Members
60 Guides authored
9 Guide Comments
Where I can buy micro USB PCB ?
so_ang - Reply Share
Planet Carl - Reply Share
Would like to know this as well disapointing to have an instruction on how to replace a part, but nowere to buy it.
Wolve 8383 - Reply Share
Has anyone had any luck buying a replacement part?
Caitlin Barnum - Reply Share
Just broke mine :-(
Is anyone managed to find a place to buy one?
Jim - Reply Share
Past 24 Hours: 7
Past 7 Days: 33
Past 30 Days: 142
All Time: 8,541
