Google Home Mini Speaker Replacement
    1. Google Home Mini Speaker Replacement, Google Home Mini Disassembly: step 1, image 1 of 1
      • Place device on a flat surface.
      Ask FixBot
    2. Google Home Mini Speaker Replacement: step 2, image 1 of 1
      Ask FixBot
    3. Google Home Mini Speaker Replacement: step 3, image 1 of 1
      • Remove the lower half of the device.
      • Be careful as a black ribbon cable connects the two halves together.
      Ask FixBot
    4. Google Home Mini Speaker Replacement: step 4, image 1 of 1
      Tool used on this step:
      Buy
      • Using a pair of tweezers, unlatch the Zero Insertion Force (ZIF) fastener that connects the ribbon cable to the board.
      • Flip up and push the ZIF fastener towards outside of the lower case to loosen it.
      Ask FixBot
    5. Google Home Mini Speaker Replacement: step 5, image 1 of 1
      • Pull the ribbon cable off.
      Ask FixBot
    1. Google Home Mini Speaker Replacement, Speaker: step 6, image 1 of 1
      • Remove the four 7.8mm T8 Torx screws.
      Ask FixBot
    2. Google Home Mini Speaker Replacement: step 7, image 1 of 3 Google Home Mini Speaker Replacement: step 7, image 2 of 3 Google Home Mini Speaker Replacement: step 7, image 3 of 3
      • The speaker will still be connected to the device.
      • Using your fingers, disconnect the wires.
      Ask FixBot
9 other people completed this guide.
Mia Sulaiman
1,170 Reputation
3 Guides authored
IUPUI, Team S1-G4, Harley Spring 2018 Member of IUPUI, Team S1-G4, Harley Spring 2018
IUPUI-HARLEY-S18S1G4
7 Members
60 Guides authored
3 Guide Comments
HI There I only have 2 lights on the google mini - and although it was working yesterday - with all 4 lights - it most certainly isn't now? I am not sure why and I am not sure what has happened?
susan woods - Reply Share
Okay, but where can one obtain a spare speaker?
Bil McArthur - Reply Share
This how to is kind of pointless if you don't let us know where to obtain a speaker.
Past 24 Hours: 0
Past 7 Days: 9
Past 30 Days: 78
All Time: 9,035
