Google Cr-48 Chromebook RAM Replacement
    1. Google Cr-48 Chromebook RAM Replacement, Battery: step 1, image 1 of 3 Google Cr-48 Chromebook RAM Replacement, Battery: step 1, image 2 of 3 Google Cr-48 Chromebook RAM Replacement, Battery: step 1, image 3 of 3
      • To take out the battery, slide the switch on the bottom of the laptop.
      • The battery should then pop out and you can remove it.
      Ask FixBot
    1. Google Cr-48 Chromebook RAM Replacement, Bottom Casing: step 2, image 1 of 2 Google Cr-48 Chromebook RAM Replacement, Bottom Casing: step 2, image 2 of 2
      Tool used on this step:
      Buy
      • Using a pair of tweezers, remove the two rear rubber feet. You should then see the two screws underneath.
      Ask FixBot
    2. Google Cr-48 Chromebook RAM Replacement: step 3, image 1 of 3 Google Cr-48 Chromebook RAM Replacement: step 3, image 2 of 3 Google Cr-48 Chromebook RAM Replacement: step 3, image 3 of 3
      • First, position the computer to have the silver battery compartment closest to you. Then, using a Phillips #00 screwdriver, remove the ten 3 mm screws in the battery compartment.
      • Now, using the same screwdriver, remove the two 4.5 mm screws that were underneath the previously removed rubber feet.
      Ask FixBot
    3. Google Cr-48 Chromebook RAM Replacement: step 4, image 1 of 3 Google Cr-48 Chromebook RAM Replacement: step 4, image 2 of 3 Google Cr-48 Chromebook RAM Replacement: step 4, image 3 of 3
      • Starting where the body of the laptop and the laptop screen meet, pry apart the lower case from the rest of the laptop.
      • The case is easier to remove when separating in a clockwise motion, as seen in the pictures.
      Ask FixBot
    1. Google Cr-48 Chromebook RAM Replacement, RAM: step 5, image 1 of 3 Google Cr-48 Chromebook RAM Replacement, RAM: step 5, image 2 of 3 Google Cr-48 Chromebook RAM Replacement, RAM: step 5, image 3 of 3
      • Locate the RAM under a black flap alongside where the laptop screen and device body meet.
      Ask FixBot
    2. Google Cr-48 Chromebook RAM Replacement: step 6, image 1 of 3 Google Cr-48 Chromebook RAM Replacement: step 6, image 2 of 3 Google Cr-48 Chromebook RAM Replacement: step 6, image 3 of 3
      • Using your thumbs, pull the metal arms away from the RAM and then the RAM card should pop up.
      Ask FixBot
    3. Google Cr-48 Chromebook RAM Replacement: step 7, image 1 of 2 Google Cr-48 Chromebook RAM Replacement: step 7, image 2 of 2
      • Use two fingers to slide the RAM out at the angle that it has been released.
      • Be careful when removing or replacing the RAM sticks that you don't bend the pins or they won't attach properly to the socket.
      Ask FixBot
2 other people completed this guide.
Athar
365 Reputation
2 Guides authored
CSU Fullerton, Team 2-2, Bruce Fall 2014 Member of CSU Fullerton, Team 2-2, Bruce Fall 2014
CSUF-BRUCE-F14S2G2
3 Members
60 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 4
Past 30 Days: 27
All Time: 2,528
