Google Cr-48 Chromebook Bottom Casing Replacement
  1. Google Cr-48 Chromebook Bottom Casing Replacement, Battery: step 1, image 1 of 3 Google Cr-48 Chromebook Bottom Casing Replacement, Battery: step 1, image 2 of 3 Google Cr-48 Chromebook Bottom Casing Replacement, Battery: step 1, image 3 of 3
    • To take out the battery, slide the switch on the bottom of the laptop.
    • The battery should then pop out and you can remove it.
    Ask FixBot
  2. Google Cr-48 Chromebook Bottom Casing Replacement, Bottom Casing: step 2, image 1 of 2 Google Cr-48 Chromebook Bottom Casing Replacement, Bottom Casing: step 2, image 2 of 2
    Tool used on this step:
    Buy
    • Using a pair of tweezers, remove the two rear rubber feet. You should then see the two screws underneath.
    Ask FixBot
  3. Google Cr-48 Chromebook Bottom Casing Replacement: step 3, image 1 of 3 Google Cr-48 Chromebook Bottom Casing Replacement: step 3, image 2 of 3 Google Cr-48 Chromebook Bottom Casing Replacement: step 3, image 3 of 3
    • First, position the computer to have the silver battery compartment closest to you. Then, using a Phillips #00 screwdriver, remove the ten 3 mm screws in the battery compartment.
    • Now, using the same screwdriver, remove the two 4.5 mm screws that were underneath the previously removed rubber feet.
    Ask FixBot
  4. Google Cr-48 Chromebook Bottom Casing Replacement: step 4, image 1 of 3 Google Cr-48 Chromebook Bottom Casing Replacement: step 4, image 2 of 3 Google Cr-48 Chromebook Bottom Casing Replacement: step 4, image 3 of 3
    • Starting where the body of the laptop and the laptop screen meet, pry apart the lower case from the rest of the laptop.
    • The case is easier to remove when separating in a clockwise motion, as seen in the pictures.
    Ask FixBot
2 other people completed this guide.
Robert McLaughlin
471 Reputation
3 Guides authored
CSU Fullerton, Team 2-2, Bruce Fall 2014 Member of CSU Fullerton, Team 2-2, Bruce Fall 2014
CSUF-BRUCE-F14S2G2
3 Members
10 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 6
Past 30 Days: 30
All Time: 1,180
