Up to 20% off select tools
Google Chromecast (4th Generation) Remote Battery Replacement
View statistics:
Past 24 Hours:
3
Past 7 Days:
15
Past 30 Days:
91
All Time:
156
Comments: 0
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 1 minute
Difficulty: Very easy
Community-Contributed Guide
Parts
Introduction
Go to step 1 ↓
Maintaining your Google Chromecast remote is a simple process that ensures your streaming experience remains uninterrupted. This guide covers the steps to safely replace the power source for your remote control.
To perform this battery replacement, you will need to acquire two new AAA batteries. One significant benefit of the Chromecast remote design is its tool-less entry; you will not require any screwdrivers or specialized equipment to access the battery compartment.
    1. Google Chromecast (4th Generation) Remote Battery Replacement, Locate the battery cover: step 1, image 1 of 1
      • Ensure the batteries are new and of high quality to prevent leaks and ensure consistent performance of the remote's Bluetooth and infrared functions.
      Ask FixBot
    2. Google Chromecast (4th Generation) Remote Battery Replacement, Opening the Battery Compartment: step 2, image 1 of 1
      • Accessing the internal battery compartment of the Chromecast remote requires a specific technique to disengage the back panel. No tools are required for this process.
      • Technique for Removal
      • Hold the remote securely and place your thumb on the center of the back cover. Apply firm, steady pressure to the panel. give it a "nice firm push" to release the latch.
      • While maintaining pressure, slide the cover downwards towards the base of the remote. The panel will slide off the tracks, exposing the battery housing. Ensure you are pushing "down and out" to smoothly remove the cover without damaging the plastic rails.
      Ask FixBot
    3. Google Chromecast (4th Generation) Remote Battery Replacement, Replacing the Batteries: step 3, image 1 of 1
      • Once the back cover is removed, you can proceed with swapping the batteries. This process requires two AAA batteries and no additional tools.
      • Removing Old Batteries
      • Carefully remove the existing batteries from the internal compartment. You can easily lift them out using your fingers once the tension from the spring-loaded terminals is released.
      Ask FixBot
    4. Google Chromecast (4th Generation) Remote Battery Replacement, Identifying Polarity: step 4, image 1 of 1
      • Before inserting the new batteries, look for the orientation markings (+ and -) etched into the plastic inside the battery compartment. Proper alignment is critical for the remote to function correctly.
      Ask FixBot
    5. Google Chromecast (4th Generation) Remote Battery Replacement, Installing New AAA Batteries: step 5, image 1 of 1
      • Insert the new AAA batteries one at a time, following these specific orientation steps:
      • First Battery: Slide the battery into the slot with the positive (+) terminal facing toward the top (the narrower end) of the remote.
      • Second Battery: Ensure the second battery also has its positive (+) terminal facing the top of the remote.
      • Confirm that both batteries are seated firmly against the contacts before attempting to replace the back cover.
      Ask FixBot
    6. Google Chromecast (4th Generation) Remote Battery Replacement, Disassembly complete: step 6, image 1 of 1
      • Congratulations on completing disassembly! The remaining steps will show how to reassemble your Remote
      Ask FixBot
    7. Google Chromecast (4th Generation) Remote Battery Replacement, Reassembling the Remote: step 7, image 1 of 1
      • After the batteries are securely placed, the final phase of maintenance is to reattach the battery compartment cover. This ensures the batteries remain in contact with the terminals and the remote retains its ergonomic form.
      • Replacing the Back Cover
      • To close the remote, align the tabs on the back cover with the guide rails located on the sides of the battery compartment. Carefully slide the cover upward toward the narrower end of the remote.
      • Apply steady pressure until you feel the cover click into its locked position. The back of the remote should now be flush and secure. With the cover replaced, your Chromecast remote is fully reassembled and ready for operation.
      Ask FixBot
Your remote should now work with fresh batteries! If the remote doesn't respond, double-check that the batteries are inserted in the correct direction (+ and -)
🎉 Did this get you back to streaming?
If this quick guide helped you open your remote safely without breaking the plastic tabs, please click the blue "Give the author +30 points!" button below!
Since I'm an independent community creator, your quick click costs nothing but deposits the full +30 reputation points directly into my profile—finally launching me past my 100-reputation milestone. Thank you for supporting independent fixers!
Shreyas vuyyuru
288 Reputation
16 Guides authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 15
Past 30 Days: 91
All Time: 156
