Google Chromebook Pixel 2 Fan Replacement
    1. Google Chromebook Pixel 2 Fan Replacement, Back Panel: step 1, image 1 of 1
      • Working on your device while it is turned on may result in electric shock. Make sure to shut down and unplug your device before you begin.
      • Flip your device over so the bottom panel is facing up.
      Ask FixBot
    2. Google Chromebook Pixel 2 Fan Replacement: step 2, image 1 of 1
      • Peel off the black rubber strips from top and bottom of the back panel.
      Ask FixBot
    3. Google Chromebook Pixel 2 Fan Replacement: step 3, image 1 of 2 Google Chromebook Pixel 2 Fan Replacement: step 3, image 2 of 2
      • Remove the fifteen 3 mm Phillips #00 screws from the back panel.
      Ask FixBot
    4. Google Chromebook Pixel 2 Fan Replacement: step 4, image 1 of 1
      • Carefully lift the back panel off of the device.
      Ask FixBot
    1. Google Chromebook Pixel 2 Fan Replacement, Fan: step 5, image 1 of 2 Google Chromebook Pixel 2 Fan Replacement, Fan: step 5, image 2 of 2
      • Remove the three blue 4.0 mm Phillips #00 screws from the fan on the right side.
      Ask FixBot
    2. Google Chromebook Pixel 2 Fan Replacement: step 6, image 1 of 1
      • Using the plastic opening tool, slide out the right fan’s connector out of the motherboard slot.
      Ask FixBot
    3. Google Chromebook Pixel 2 Fan Replacement: step 7, image 1 of 1
      • Carefully remove lift the right fan out of its slot.
      Ask FixBot
    4. Google Chromebook Pixel 2 Fan Replacement: step 8, image 1 of 2 Google Chromebook Pixel 2 Fan Replacement: step 8, image 2 of 2
      • Remove three blue 4.0 mm Phillips #00 screws from the left fan.
      Ask FixBot
    5. Google Chromebook Pixel 2 Fan Replacement: step 9, image 1 of 1
      • Using the plastic opening tool, slide out the left fan’s connector.
      Ask FixBot
    6. Google Chromebook Pixel 2 Fan Replacement: step 10, image 1 of 1
      • Gently lift the left fan out of its slot.
      Ask FixBot
Garrett Monteiro
413 Reputation
3 Guides authored
Cal Poly, Team S22-G6, Livingston Spring 2017 Member of Cal Poly, Team S22-G6, Livingston Spring 2017
CPSU-LIVINGSTON-S17S22G6
4 Members
36 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 4
Past 30 Days: 17
All Time: 402
