Community-Contributed Guide
Introduction
Go to step 1 ↓This will serve as a walk-through in the disassembly and repair of a blower motor for any Goodman branded home furnace.
Tools
Unscrew the two screws located on the rear side of the unit.
Remove the doors and set them aside.
Disconnect the brown wire from the top of the motor.
Disconnect the second brown wire from the bottom of the unit.
Remove the white, blue, red, orange, and black wires from the controller board.
Unscrew both screws connected the motherboard to the cylindrical motor container.
Unscrew the cylindrical motor housing from the unit.
Grab the motor container with two hands and pull it out of the unit.
Place the motherboard to the side.
Turn the motor container on its side, with the wires pointing up.
Unscrew the 3 screws attaching the motor to the housing.
Take the yellow wire out of the screw.
Use a wrench to remove the bolt from the shaft of the motor, located on the opposite side.
Firmly grasp the motor from the side where the screws were previously located and pull to remove it.
Insert the new motor into the motor housing.
Tighten the bolt at the shaft of the motor that you removed in the previous step.
