Golf Club Shaft Replacement
Views: 2.4K
View statistics:
Past 24 Hours:
6
Past 7 Days:
41
Past 30 Days:
139
All Time:
2,350
Comments: 0
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 15 minutes
Difficulty: Moderate
Introduction
Go to step 1 ↓
This guide will show you how to replace the shaft of a golf club. New golf clubs are expensive, so it is very common to buy golf clubs second hand. A second hand club with a worn out, loose, or warped shaft not only deems itself almost useless, but if used, it prevents a danger in the form of the club head flying off of the shaft swing. Oftentimes, it is recommended to take one’s golf club to a specialty repair shop where they can charge you anywhere from $50-$250 to do these simple steps.
    1. Golf Club Shaft Replacement, Shaft: step 1, image 1 of 1
      • Use a heat gun to melt the old epoxy holding the club head to the old shaft.
      • Caution: Heat guns can get very hot, so use caution when handling them.
      Ask FixBot
    2. Golf Club Shaft Replacement: step 2, image 1 of 3 Golf Club Shaft Replacement: step 2, image 2 of 3 Golf Club Shaft Replacement: step 2, image 3 of 3
      • Stabilize the club shaft using a vise grip or the weight of a friend.
      • With a pair of oven mitts, remove the club head by carefully twisting it from the shaft.
      Ask FixBot
    3. Golf Club Shaft Replacement: step 3, image 1 of 2 Golf Club Shaft Replacement: step 3, image 2 of 2
      • Clean out the inside of the club head with acetone and a small wire brush.
      • Cleaning the club head will make applying the new epoxy effective.
      Ask FixBot
    4. Golf Club Shaft Replacement: step 4, image 1 of 1
      • Place the cleaned club head on the new shaft and mark the where the end of the club head reaches on the shaft.
      • Remove the club head.
      Ask FixBot
    5. Golf Club Shaft Replacement: step 5, image 1 of 3 Golf Club Shaft Replacement: step 5, image 2 of 3 Golf Club Shaft Replacement: step 5, image 3 of 3
      • Take some sand paper and sand the shaft past your mark leading to the tip.
      • A good technique is to wrap the sandpaper around the tip while twisting the hand holding the sandpaper back and forth.
      Ask FixBot
    6. Golf Club Shaft Replacement: step 6, image 1 of 3 Golf Club Shaft Replacement: step 6, image 2 of 3 Golf Club Shaft Replacement: step 6, image 3 of 3
      • Get the epoxy ready by pouring it into a plate.
      • Use a toothpick to apply epoxy into the part of the club head that goes over the shaft.
      Ask FixBot
    7. Golf Club Shaft Replacement: step 7, image 1 of 3 Golf Club Shaft Replacement: step 7, image 2 of 3 Golf Club Shaft Replacement: step 7, image 3 of 3
      • Slide the new shaft into the club head.
      • Wipe off the excess epoxy that squeezes out.
      • Let the epoxy set overnight for an optimal seal, then it will be ready for use.
      Ask FixBot
Finish Line
George Bassili
166 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 6
Past 7 Days: 41
Past 30 Days: 139
All Time: 2,350
