Up to 20% off select tools
GoPro Karma Stabilizer Replacement
Views: 2.6K
View statistics:
Past 24 Hours:
5
Past 7 Days:
22
Past 30 Days:
80
All Time:
2,552
Comments: 1
1 guide comment.
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 1 - 2 minutes
Difficulty: Very easy
Introduction
Go to step 1 ↓
The GoPro Karma stabilizer is used to capture smooth and stable videos and photos. Use this guide to remove and replace the GoPro Karma Stabilizer.
    1. GoPro Karma Stabilizer Replacement, Stabilizer: step 1, image 1 of 3 GoPro Karma Stabilizer Replacement, Stabilizer: step 1, image 2 of 3 GoPro Karma Stabilizer Replacement, Stabilizer: step 1, image 3 of 3
      • Locate stabilizer collar’s unlock and lock symbols. Twist the collar counterclockwise to unlock the stabilizer from GoPro Karma body.
      • Place the GoPro Karma on a stable surface with the legs folded in and the stabilizer facing towards yourself.
      Ask FixBot
    2. GoPro Karma Stabilizer Replacement: step 2, image 1 of 1
      • Remove the stabilizer by pulling the entire stabilizer out of the drone body.
      Ask FixBot
Author
with
Joe Tatis-Flanagan
109 Reputation
1 Guide authored
Cal Poly, Team S25-G14, Maness Spring 2018 Member of Cal Poly, Team S25-G14, Maness Spring 2018
CPSU-MANESS-S18S25G14
4 Members
72 Guides authored
1 Guide Comment
My karma got accident and broke two arms on right side. But I tried to start it again and not working anymore.
Friday Aringo - Reply Share
Past 24 Hours: 5
Past 7 Days: 22
Past 30 Days: 80
All Time: 2,552
