GoPro Karma Landing Gear Replacement
    1. GoPro Karma Landing Gear Replacement, Battery: step 1, image 1 of 1
      • Hook your fingers on the tab and pull out the battery.
      Ask FixBot
    1. GoPro Karma Landing Gear Replacement, Stabilizer: step 2, image 1 of 3 GoPro Karma Landing Gear Replacement, Stabilizer: step 2, image 2 of 3 GoPro Karma Landing Gear Replacement, Stabilizer: step 2, image 3 of 3
      • Locate stabilizer collar’s unlock and lock symbols. Twist the collar counterclockwise to unlock the stabilizer from GoPro Karma body.
      • Place the GoPro Karma on a stable surface with the legs folded in and the stabilizer facing towards yourself.
      Ask FixBot
    2. GoPro Karma Landing Gear Replacement: step 3, image 1 of 1
      • Remove the stabilizer by pulling the entire stabilizer out of the drone body.
      Ask FixBot
    1. GoPro Karma Landing Gear Replacement, Landing Gear: step 4, image 1 of 1
      • Flip the drone upside down with the landing gear out.
      • Remove the four 1.2 cm long hex screws with a Hex 2.0 screwdriver in the four corners of the landing gear
      Ask FixBot
    2. GoPro Karma Landing Gear Replacement: step 5, image 1 of 1
      • Push with your thumb and pull up with your fingers to remove the landing gear.
      • Caution: The landing gear is connected by a thin cable so do not pull too far away.
      Ask FixBot
    3. GoPro Karma Landing Gear Replacement: step 6, image 1 of 2 GoPro Karma Landing Gear Replacement: step 6, image 2 of 2
      • Flip over the landing gear and locate the cable connector.
      • Use your thumbnail to disconnect the cable and free the landing gear.
      Ask FixBot
Jay Ingram
334 Reputation
3 Guides authored
Cal Poly, Team S25-G14, Maness Spring 2018 Member of Cal Poly, Team S25-G14, Maness Spring 2018
CPSU-MANESS-S18S25G14
4 Members
72 Guides authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 5
Past 30 Days: 24
All Time: 1,026
