Up to 20% off select tools
GoPro Karma Arms Replacement
Views: 2.9K
View statistics:
Past 24 Hours:
3
Past 7 Days:
18
Past 30 Days:
77
All Time:
2,913
Comments: 0
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 1
1 person has favorited (and subscribed to) this guide. Will you be next?
Time Required: 15 - 30 minutes
Difficulty: Moderate
Tools
Introduction
Go to step 1 ↓
Replacing the landing gear in your Karma is a relatively easy task, but requires caution because of small screws. There is a specific tool to help remove the clips connecting the arms but it is not necessary at all. Removing the clips without that tool can be tedious and requires a soft touch so be sure to go slow.
    1. GoPro Karma Arms Replacement, Battery: step 1, image 1 of 1
      • Hook your fingers on the tab and pull out the battery.
      Ask FixBot
    1. GoPro Karma Arms Replacement, Stabilizer: step 2, image 1 of 3 GoPro Karma Arms Replacement, Stabilizer: step 2, image 2 of 3 GoPro Karma Arms Replacement, Stabilizer: step 2, image 3 of 3
      • Locate stabilizer collar’s unlock and lock symbols. Twist the collar counterclockwise to unlock the stabilizer from GoPro Karma body.
      • Place the GoPro Karma on a stable surface with the legs folded in and the stabilizer facing towards yourself.
      Ask FixBot
    2. GoPro Karma Arms Replacement: step 3, image 1 of 1
      • Remove the stabilizer by pulling the entire stabilizer out of the drone body.
      Ask FixBot
    1. GoPro Karma Arms Replacement, Landing Gear: step 4, image 1 of 1
      • Flip the drone upside down with the landing gear out.
      • Remove the four 1.2 cm long hex screws with a Hex 2.0 screwdriver in the four corners of the landing gear
      Ask FixBot
    2. GoPro Karma Arms Replacement: step 5, image 1 of 1
      • Push with your thumb and pull up with your fingers to remove the landing gear.
      • Caution: The landing gear is connected by a thin cable so do not pull too far away.
      Ask FixBot
    3. GoPro Karma Arms Replacement: step 6, image 1 of 2 GoPro Karma Arms Replacement: step 6, image 2 of 2
      • Flip over the landing gear and locate the cable connector.
      • Use your thumbnail to disconnect the cable and free the landing gear.
      Ask FixBot
    1. GoPro Karma Arms Replacement, Arms: step 7, image 1 of 1
      • Remove the two 1.2 cm long hex screws with a Hex 2.0 screwdriver and set them aside.
      Ask FixBot
    2. GoPro Karma Arms Replacement: step 8, image 1 of 2 GoPro Karma Arms Replacement: step 8, image 2 of 2
      • Remove both locked connectors by pushing the connector release tool into the hole in the center and pulling up with the white handles.
      • The connector release tool is only included with the purchase of a replacement arm from the GoPro website.
      • If you do not have a connector release tool, use a small screwdriver to push each tab while pulling up with the white handles.
      Ask FixBot
    3. GoPro Karma Arms Replacement: step 9, image 1 of 3 GoPro Karma Arms Replacement: step 9, image 2 of 3 GoPro Karma Arms Replacement: step 9, image 3 of 3
      • Remove the cover plate by pulling up on the side.
      • Feed each connector through the hole and set aside the cover plate.
      Ask FixBot
    4. GoPro Karma Arms Replacement: step 10, image 1 of 2 GoPro Karma Arms Replacement: step 10, image 2 of 2
      • Loosen the 2 cm long hex screw in the arm with a Hex 2.0 screwdriver.
      • The screw will not come out but loosen it until it can rotate easily.
      • Pull up and off the broken arm.
      Ask FixBot
Author
with
Kyle Hoff
141 Reputation
1 Guide authored
Cal Poly, Team S25-G14, Maness Spring 2018 Member of Cal Poly, Team S25-G14, Maness Spring 2018
CPSU-MANESS-S18S25G14
4 Members
72 Guides authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 18
Past 30 Days: 77
All Time: 2,913
