Up to 20% off select tools
GoPro Hero5 Black Lens Assembly Replacement
Views: 18K
View statistics:
Past 24 Hours:
3
Past 7 Days:
30
Past 30 Days:
148
All Time:
18,428
Comments: 13
6 comments on steps, 7 guide comments.
Go to guide comments
Completed: 16
16 people have marked this guide "completed." Will you be next?
Favorites: 1
1 person has favorited (and subscribed to) this guide. Will you be next?
Time Required: 45 minutes - 1 hour
Difficulty: Moderate
Parts
Tools
Introduction
Go to step 1 ↓
In this guide, you will be removing the lens assembly from the rest of the GoPro. To get to the lens assembly, you must remove almost every other part first. The GoPro Hero5 Black is waterproofed with plenty of adhesives. By completing this guide, you will have to remove the adhesive and your GoPro will no longer be waterproof.
    1. GoPro Hero5 Black Lens Assembly Replacement, Battery: step 1, image 1 of 3 GoPro Hero5 Black Lens Assembly Replacement, Battery: step 1, image 2 of 3 GoPro Hero5 Black Lens Assembly Replacement, Battery: step 1, image 3 of 3
      • While pressing the button on the bottom of the GoPro, slide the battery door to the side to pop it open.
      Ask FixBot
    2. GoPro Hero5 Black Lens Assembly Replacement: step 2, image 1 of 3 GoPro Hero5 Black Lens Assembly Replacement: step 2, image 2 of 3 GoPro Hero5 Black Lens Assembly Replacement: step 2, image 3 of 3
      • Grab the plastic flap on the battery and pull the battery out.
      Ask FixBot
    1. GoPro Hero5 Black Lens Assembly Replacement, Back Housing: step 3, image 1 of 2 GoPro Hero5 Black Lens Assembly Replacement, Back Housing: step 3, image 2 of 2
      • Pull and twist the lens cover right or left until it pops off.
      • The lens cover is secured tightly and might be difficult to twist off.
      Ask FixBot
    2. GoPro Hero5 Black Lens Assembly Replacement: step 4, image 1 of 1
      • This step is not necessary but will make the process of removing the faceplate much easier.
      • Refer to the iOpener instructions for how to heat up and use the iOpener.
      • Apply the heated iOpener to the front of the GoPro for a few minutes to melt the adhesive under the faceplate.
      • The heated iOpener is very hot and can burn your hands. Avoid burns by using towels or gloves to hold the iOpener.
      Ask FixBot
    3. GoPro Hero5 Black Lens Assembly Replacement: step 5, image 1 of 3 GoPro Hero5 Black Lens Assembly Replacement: step 5, image 2 of 3 GoPro Hero5 Black Lens Assembly Replacement: step 5, image 3 of 3
      • Starting with the edges, use the spudger to pry off the faceplate.
      • The faceplate is held down with adhesive and may take a while to get off.
      Ask FixBot
    4. GoPro Hero5 Black Lens Assembly Replacement: step 6, image 1 of 2 GoPro Hero5 Black Lens Assembly Replacement: step 6, image 2 of 2
      • Remove the six T3 Torx screws.
      Ask FixBot
    5. GoPro Hero5 Black Lens Assembly Replacement: step 7, image 1 of 3 GoPro Hero5 Black Lens Assembly Replacement: step 7, image 2 of 3 GoPro Hero5 Black Lens Assembly Replacement: step 7, image 3 of 3
      • Be careful when pulling open the motherboard assembly as it is still connected to the back housing by four cables. The cables may break if stretched.
      • Using the spudger, slowly pry open the motherboard assembly from the LCD side of the GoPro.
      Ask FixBot
    6. GoPro Hero5 Black Lens Assembly Replacement: step 8, image 1 of 3 GoPro Hero5 Black Lens Assembly Replacement: step 8, image 2 of 3 GoPro Hero5 Black Lens Assembly Replacement: step 8, image 3 of 3
      • Use the flat end of a spudger to pry the three ribbon cables connected to the side of the motherboard.
      Ask FixBot
    7. GoPro Hero5 Black Lens Assembly Replacement: step 9, image 1 of 2 GoPro Hero5 Black Lens Assembly Replacement: step 9, image 2 of 2
      • Use the flat end of the spudger to pry the battery housing power cable straight up from its socket on the motherboard.
      Ask FixBot
    1. GoPro Hero5 Black Lens Assembly Replacement, Motherboard: step 10, image 1 of 1
      • Use the flat end of the spudger to pry the black cover plate straight up from its socket on the motherboard.
      Ask FixBot
    2. GoPro Hero5 Black Lens Assembly Replacement: step 11, image 1 of 1
      Tool used on this step:
      Buy
      • Use the tweezers to pull the ribbon cable connector out of its white socket on the charging assembly board.
      Ask FixBot
    3. GoPro Hero5 Black Lens Assembly Replacement: step 12, image 1 of 2 GoPro Hero5 Black Lens Assembly Replacement: step 12, image 2 of 2
      • Remove the two #000 Phillips screw.
      Ask FixBot
    4. GoPro Hero5 Black Lens Assembly Replacement: step 13, image 1 of 2 GoPro Hero5 Black Lens Assembly Replacement: step 13, image 2 of 2
      • Use the flat end of the spudger to pry the charging port ribbon cable connector straight up from its socket on the motherboard.
      • Once the ribbon cable is disconnected from the motherboard. The charging port assembly should come right off.
      Ask FixBot
    5. GoPro Hero5 Black Lens Assembly Replacement: step 14, image 1 of 2 GoPro Hero5 Black Lens Assembly Replacement: step 14, image 2 of 2
      • Remove the 10mm #000 Phillips screw.
      Ask FixBot
    6. GoPro Hero5 Black Lens Assembly Replacement: step 15, image 1 of 1
      • Remove the charging assembly housing by pulling it straight up off the motherboard.
      Ask FixBot
    7. GoPro Hero5 Black Lens Assembly Replacement: step 16, image 1 of 2 GoPro Hero5 Black Lens Assembly Replacement: step 16, image 2 of 2
      • Remove the two 6mm #000 Phillips screws.
      • Remove the two 2mm #000 Phillips screws.
      Ask FixBot
    8. GoPro Hero5 Black Lens Assembly Replacement: step 17, image 1 of 1
      • Use the flat end of the spudger to pry the lens assembly ribbon cable connector straight up from its socket on the motherboard.
      Ask FixBot
    9. GoPro Hero5 Black Lens Assembly Replacement: step 18, image 1 of 1
      • Use the flat end of the spudger to pry the LCD screen ribbon cable connector straight up from its socket on the motherboard.
      Ask FixBot
    10. GoPro Hero5 Black Lens Assembly Replacement: step 19, image 1 of 3 GoPro Hero5 Black Lens Assembly Replacement: step 19, image 2 of 3 GoPro Hero5 Black Lens Assembly Replacement: step 19, image 3 of 3
      • Use the flat end of the spudger to pry the motherboard off the midframe.
      • The motherboard is held onto the midframe with light adhesive and should come right off with a little force.
      Ask FixBot
    1. GoPro Hero5 Black Lens Assembly Replacement, Lens Assembly: step 20, image 1 of 2 GoPro Hero5 Black Lens Assembly Replacement, Lens Assembly: step 20, image 2 of 2
      • Remove the 2mm #000 Phillips screws using a #000 Phillips head screwdriver or tool bit.
      Ask FixBot
    2. GoPro Hero5 Black Lens Assembly Replacement: step 21, image 1 of 2 GoPro Hero5 Black Lens Assembly Replacement: step 21, image 2 of 2
      • Pull the lens assembly straight out from the Midframe.
      Ask FixBot
16 other people completed this guide.
Author
with
Christopher Adams
2,157 Reputation
5 Guides authored
Cal Poly, Team 18-6, Forte Fall 2016 Member of Cal Poly, Team 18-6, Forte Fall 2016
CPSU-FORTE-F16S18G6
4 Members
60 Guides authored
7 Guide Comments
RageCams has interchangeable lens mod for hero5
http://ragecams.com/shop/modified-gopro-...
dennis - Reply Share
why can't You show how the lens is mount to that assembly? That's the point of it... can we change lenses that way or not?
Polina Luzenco - Reply Share
Exactly. Can the actual lens be unscrewed from the mount or it glued / fixed?
contact - Reply Share
The lens is heavily glued onto the assembly. It would be far easier to replace the entire assembly than trying to remove that glue.
Christopher Adams - Reply Share
the guy who wrote the guide apparently has never heard of pliers. it comes right out, but no idea what the threading is.
mattatron4 - Reply Share
Past 24 Hours: 3
Past 7 Days: 30
Past 30 Days: 148
All Time: 18,428
