GoPro Hero5 Black Back Housing Replacement
    1. GoPro Hero5 Black Back Housing Replacement, Battery: step 1, image 1 of 3 GoPro Hero5 Black Back Housing Replacement, Battery: step 1, image 2 of 3 GoPro Hero5 Black Back Housing Replacement, Battery: step 1, image 3 of 3
      • While pressing the button on the bottom of the GoPro, slide the battery door to the side to pop it open.
      Ask FixBot
    2. GoPro Hero5 Black Back Housing Replacement: step 2, image 1 of 3 GoPro Hero5 Black Back Housing Replacement: step 2, image 2 of 3 GoPro Hero5 Black Back Housing Replacement: step 2, image 3 of 3
      • Grab the plastic flap on the battery and pull the battery out.
      Ask FixBot
    1. GoPro Hero5 Black Back Housing Replacement, Back Housing: step 3, image 1 of 2 GoPro Hero5 Black Back Housing Replacement, Back Housing: step 3, image 2 of 2
      • Pull and twist the lens cover right or left until it pops off.
      • The lens cover is secured tightly and might be difficult to twist off.
      Ask FixBot
    2. GoPro Hero5 Black Back Housing Replacement: step 4, image 1 of 1
      • This step is not necessary but will make the process of removing the faceplate much easier.
      • Refer to the iOpener instructions for how to heat up and use the iOpener.
      • Apply the heated iOpener to the front of the GoPro for a few minutes to melt the adhesive under the faceplate.
      • The heated iOpener is very hot and can burn your hands. Avoid burns by using towels or gloves to hold the iOpener.
      Ask FixBot
    3. GoPro Hero5 Black Back Housing Replacement: step 5, image 1 of 3 GoPro Hero5 Black Back Housing Replacement: step 5, image 2 of 3 GoPro Hero5 Black Back Housing Replacement: step 5, image 3 of 3
      • Starting with the edges, use the spudger to pry off the faceplate.
      • The faceplate is held down with adhesive and may take a while to get off.
      Ask FixBot
    4. GoPro Hero5 Black Back Housing Replacement: step 6, image 1 of 2 GoPro Hero5 Black Back Housing Replacement: step 6, image 2 of 2
      • Remove the six T3 Torx screws.
      Ask FixBot
    5. GoPro Hero5 Black Back Housing Replacement: step 7, image 1 of 3 GoPro Hero5 Black Back Housing Replacement: step 7, image 2 of 3 GoPro Hero5 Black Back Housing Replacement: step 7, image 3 of 3
      • Be careful when pulling open the motherboard assembly as it is still connected to the back housing by four cables. The cables may break if stretched.
      • Using the spudger, slowly pry open the motherboard assembly from the LCD side of the GoPro.
      Ask FixBot
    6. GoPro Hero5 Black Back Housing Replacement: step 8, image 1 of 3 GoPro Hero5 Black Back Housing Replacement: step 8, image 2 of 3 GoPro Hero5 Black Back Housing Replacement: step 8, image 3 of 3
      • Use the flat end of a spudger to pry the three ribbon cables connected to the side of the motherboard.
      Ask FixBot
    7. GoPro Hero5 Black Back Housing Replacement: step 9, image 1 of 2 GoPro Hero5 Black Back Housing Replacement: step 9, image 2 of 2
      • Use the flat end of the spudger to pry the battery housing power cable straight up from its socket on the motherboard.
      Ask FixBot
16 other people completed this guide.
Christopher Adams
2,133 Reputation
5 Guides authored
Cal Poly, Team 18-6, Forte Fall 2016 Member of Cal Poly, Team 18-6, Forte Fall 2016
CPSU-FORTE-F16S18G6
4 Members
60 Guides authored
2 Guide Comments
Where can you get replacement rear screens for this
ociaravella - Reply Share
Hi, how i reset firmware in this gopro? I have a problem with a bucle starting and it dont turn on, always restarting.
ISU AREY - Reply Share
Past 24 Hours: 3
Past 7 Days: 26
Past 30 Days: 156
All Time: 26,972
