Up to 20% off select tools
GoPro Hero4 Silver Front Panel Replacement
Views: 13K
View statistics:
Past 24 Hours:
4
Past 7 Days:
30
Past 30 Days:
155
All Time:
13,182
Comments: 4
2 comments on steps, 2 guide comments.
Go to guide comments
Completed: 15
15 people have marked this guide "completed." Will you be next?
Favorites: 1
1 person has favorited (and subscribed to) this guide. Will you be next?
Time Required: 5 minutes
Difficulty: Moderate
Parts
Tools
Introduction
Go to step 1 ↓
In this guide we will be showing you how to replace the front panel in your GoPro Hero4 Silver. Before you begin make sure the battery is removed from the device and that you have the necessary tools to preform this repair.
    1. GoPro Hero4 Silver Front Panel Replacement, Front Panel: step 1, image 1 of 3 GoPro Hero4 Silver Front Panel Replacement, Front Panel: step 1, image 2 of 3 GoPro Hero4 Silver Front Panel Replacement, Front Panel: step 1, image 3 of 3
      • Start by removing the silver plastic face from the camera using a plastic opening tool. Insert the plastic opening tool into the middle of each edge and lift up the tabs that keep the camera face on.
      • The seven plastic tab locations are marked in red.
      • Try using the plastic opening tool before switching to the metal spudger. We tried using the plastic opening tool to pry the camera face off, but found that it did not give us enough leverage.
      • There may be glue holding the camera face on to the housing. Be careful not to flex the camera face too much, or it will crack.
      Ask FixBot
15 other people completed this guide.
Author
with
Zack Hoover
1,109 Reputation
3 Guides authored
USF Tampa, Team 2-1, Blackwell Fall 2015 Member of USF Tampa, Team 2-1, Blackwell Fall 2015
USFT-BLACKWELL-F15S2G1
4 Members
72 Guides authored
2 Guide Comments
Am I mistaken, or are there missing steps in this guide?
Tom Fox - Reply Share
Looks like a simple remove/replace guide. Only one step needed.
justincarver - Reply Share
Past 24 Hours: 4
Past 7 Days: 30
Past 30 Days: 155
All Time: 13,182
