Up to 20% off select tools
GoPro Hero4 Black Lens Replacement
Views: 5.5K
View statistics:
Past 24 Hours:
2
Past 7 Days:
24
Past 30 Days:
178
All Time:
5,524
Comments: 14
13 comments on steps, 1 guide comment.
Go to guide comments
Completed: 5
5 people have marked this guide "completed." Will you be next?
Favorites: 2
2 people have favorited (and subscribed to) this guide. Will you be next?
Time Required: 15 - 30 minutes
Difficulty: Moderate
Parts
Tools
Introduction
Go to step 1 ↓
If the pictures or video are fuzzy or unable to focus, the lens may need replacement. Follow this guide to do so.
    1. GoPro Hero4 Black Lens Replacement, Midframe Housing: step 1, image 1 of 3 GoPro Hero4 Black Lens Replacement, Midframe Housing: step 1, image 2 of 3 GoPro Hero4 Black Lens Replacement, Midframe Housing: step 1, image 3 of 3
      Tool used on this step:
      Buy
      • Remove the faceplate by carefully prying around the edge using a plastic opening tool. Loosen the clips on the edge, then pull the faceplate off.
      • Use the tweezers to lift the faceplate from the rest of the device.
      • The power button on the front of the GoPro may pop off. Ensure to align it properly during reassembly.
      Ask FixBot
    2. GoPro Hero4 Black Lens Replacement: step 2, image 1 of 2 GoPro Hero4 Black Lens Replacement: step 2, image 2 of 2
      • Using a #00 Phillips head screwdriver, remove the following screws:
      • One 4.6 mm screw
      • Three 8.2 mm screws
      • Two 6.1 mm screws
      Ask FixBot
    3. GoPro Hero4 Black Lens Replacement: step 3, image 1 of 2 GoPro Hero4 Black Lens Replacement: step 3, image 2 of 2
      • Insert a metal spudger between the back plastic housing and the camera board assembly. Working around the edge to be careful of the inner components, carefully remove the camera.
      Ask FixBot
    4. GoPro Hero4 Black Lens Replacement: step 4, image 1 of 3 GoPro Hero4 Black Lens Replacement: step 4, image 2 of 3 GoPro Hero4 Black Lens Replacement: step 4, image 3 of 3
      • Using tweezers, remove the ribbon strip by pulling on it. This will remove the connection.
      • Push down on the three wires with the metal spudger and the clip will disconnect from the motherboard.
      • The clip must be pulled up and away from the motherboard. Attempting to slide it out will damage the clip.
      • During reassembly, remove the black tape on the ribbon cable, turn the camera upside down so you can see the port, and reinsert the cable with tweezers. It's a lot easier!
      Ask FixBot
    1. GoPro Hero4 Black Lens Replacement, Camera Sensor: step 5, image 1 of 3 GoPro Hero4 Black Lens Replacement, Camera Sensor: step 5, image 2 of 3 GoPro Hero4 Black Lens Replacement, Camera Sensor: step 5, image 3 of 3
      • Using a plastic opening tool, separate the camera sensor's connector from the motherboard.
      Ask FixBot
    2. GoPro Hero4 Black Lens Replacement: step 6, image 1 of 3 GoPro Hero4 Black Lens Replacement: step 6, image 2 of 3 GoPro Hero4 Black Lens Replacement: step 6, image 3 of 3
      • Using a #00 Phillips head screwdriver, remove the four 3.0mm screws holding the camera sensor.
      Ask FixBot
    1. GoPro Hero4 Black Lens Replacement, Lens: step 7, image 1 of 2 GoPro Hero4 Black Lens Replacement, Lens: step 7, image 2 of 2
      • Three 2 mm screw
      Ask FixBot
    2. GoPro Hero4 Black Lens Replacement: step 8, image 1 of 1
      • Lift the lens from the front housing.
      Ask FixBot
5 other people completed this guide.
Author
with
Thomas Sullivan
595 Reputation
3 Guides authored
USF Tampa, Team S2-G1, Sullivan Spring 2017 Member of USF Tampa, Team S2-G1, Sullivan Spring 2017
USFT-SULLIVAN-S17S2G1
4 Members
72 Guides authored
1 Guide Comment
Between step 6 and step 7, you skipped a really important step…
Matthew Mulholland - Reply Share
Past 24 Hours: 2
Past 7 Days: 24
Past 30 Days: 178
All Time: 5,524
