GoPro Hero4 Black Expansion Port/Motherboard Replacement
  1. GoPro Hero4 Black Expansion Port/Motherboard Replacement, Midframe Housing: step 1, image 1 of 3 GoPro Hero4 Black Expansion Port/Motherboard Replacement, Midframe Housing: step 1, image 2 of 3 GoPro Hero4 Black Expansion Port/Motherboard Replacement, Midframe Housing: step 1, image 3 of 3
    Tool used on this step:
    Buy
    • Remove the faceplate by carefully prying around the edge using a plastic opening tool. Loosen the clips on the edge, then pull the faceplate off.
    • Use the tweezers to lift the faceplate from the rest of the device.
    • The power button on the front of the GoPro may pop off. Ensure to align it properly during reassembly.
    Ask FixBot
  2. GoPro Hero4 Black Expansion Port/Motherboard Replacement: step 2, image 1 of 2 GoPro Hero4 Black Expansion Port/Motherboard Replacement: step 2, image 2 of 2
    • Using a #00 Phillips head screwdriver, remove the following screws:
    • One 4.6 mm screw
    • Three 8.2 mm screws
    • Two 6.1 mm screws
    Ask FixBot
  3. GoPro Hero4 Black Expansion Port/Motherboard Replacement: step 3, image 1 of 2 GoPro Hero4 Black Expansion Port/Motherboard Replacement: step 3, image 2 of 2
    • Insert a metal spudger between the back plastic housing and the camera board assembly. Working around the edge to be careful of the inner components, carefully remove the camera.
    Ask FixBot
  4. GoPro Hero4 Black Expansion Port/Motherboard Replacement: step 4, image 1 of 3 GoPro Hero4 Black Expansion Port/Motherboard Replacement: step 4, image 2 of 3 GoPro Hero4 Black Expansion Port/Motherboard Replacement: step 4, image 3 of 3
    • Using tweezers, remove the ribbon strip by pulling on it. This will remove the connection.
    • Push down on the three wires with the metal spudger and the clip will disconnect from the motherboard.
    • The clip must be pulled up and away from the motherboard. Attempting to slide it out will damage the clip.
    • During reassembly, remove the black tape on the ribbon cable, turn the camera upside down so you can see the port, and reinsert the cable with tweezers. It's a lot easier!
    Ask FixBot
  5. GoPro Hero4 Black Expansion Port/Motherboard Replacement, Camera Sensor: step 5, image 1 of 3 GoPro Hero4 Black Expansion Port/Motherboard Replacement, Camera Sensor: step 5, image 2 of 3 GoPro Hero4 Black Expansion Port/Motherboard Replacement, Camera Sensor: step 5, image 3 of 3
    • Using a plastic opening tool, separate the camera sensor's connector from the motherboard.
    Ask FixBot
  6. GoPro Hero4 Black Expansion Port/Motherboard Replacement: step 6, image 1 of 3 GoPro Hero4 Black Expansion Port/Motherboard Replacement: step 6, image 2 of 3 GoPro Hero4 Black Expansion Port/Motherboard Replacement: step 6, image 3 of 3
    • Using a #00 Phillips head screwdriver, remove the four 3.0mm screws holding the camera sensor.
    Ask FixBot
  7. GoPro Hero4 Black Expansion Port/Motherboard Replacement, Expansion Port: step 7, image 1 of 3 GoPro Hero4 Black Expansion Port/Motherboard Replacement, Expansion Port: step 7, image 2 of 3 GoPro Hero4 Black Expansion Port/Motherboard Replacement, Expansion Port: step 7, image 3 of 3
    • Using #00 phillips head screwdriver, remove the 3.0mm screw.
    • Using the plastic opening tool, unclip the LCD ribbon from the motherboard.
    Ask FixBot
  8. GoPro Hero4 Black Expansion Port/Motherboard Replacement: step 8, image 1 of 2 GoPro Hero4 Black Expansion Port/Motherboard Replacement: step 8, image 2 of 2
    Buy
    • Using tweezers, lift the motherboard from the midframe housing
    • It may feel like the board is still attached with a screw or two. Gentle, but firm wiggling will free the board.
    Ask FixBot
  9. GoPro Hero4 Black Expansion Port/Motherboard Replacement: step 9, image 1 of 3 GoPro Hero4 Black Expansion Port/Motherboard Replacement: step 9, image 2 of 3 GoPro Hero4 Black Expansion Port/Motherboard Replacement: step 9, image 3 of 3
    • Using #00 phillips head screwdriver, remove the three 4.0mm screws.
    • Using plastic opening tool, unclip Expansion Port chip from motherboard
    • A metal piece of the frame sits underneath the bottom screw, which will detach upon removing the screw.
    Ask FixBot
  10. GoPro Hero4 Black Expansion Port/Motherboard Replacement: step 10, image 1 of 2 GoPro Hero4 Black Expansion Port/Motherboard Replacement: step 10, image 2 of 2
    • Lift the expansion port chip from the motherboard.
    • It is now possible to replace the expansion port and/or motherboard.
    Ask FixBot
9 other people completed this guide.
Jeffrey Goethe
674 Reputation
3 Guides authored
USF Tampa, Team S2-G1, Sullivan Spring 2017 Member of USF Tampa, Team S2-G1, Sullivan Spring 2017
USFT-SULLIVAN-S17S2G1
4 Members
12 Guides authored
1 Guide Comment
step 2 is wrong, short screw belongs on the battery door edge... destroyed my new housing... :(
Menno Middelkoop - Reply Share
Past 24 Hours: 2
Past 7 Days: 18
Past 30 Days: 111
All Time: 7,030
