Up to 20% off select tools
GoPro Hero3+ Silver Edition Camera Lens Replacement
Views: 2.9K
View statistics:
Past 24 Hours:
2
Past 7 Days:
16
Past 30 Days:
112
All Time:
2,920
Comments: 2
2 comments on steps.
Completed: 9
9 people have marked this guide "completed." Will you be next?
Favorites: 2
2 people have favorited (and subscribed to) this guide. Will you be next?
Time Required: 15 - 20 minutes
Difficulty: Moderate
Parts
Tools
Introduction
Go to step 1 ↓
You've had a terrible accident and realized that your GoPro has a crack right through the center of the lens! Use our guide to resurrect you GoPro back to life!
    1. GoPro Hero3+ Silver Edition Camera Lens Replacement, Battery: step 1, image 1 of 2 GoPro Hero3+ Silver Edition Camera Lens Replacement, Battery: step 1, image 2 of 2
      • Push the tab on the back of the device left to remove the plate covering the battery.
      Ask FixBot
    2. GoPro Hero3+ Silver Edition Camera Lens Replacement: step 2, image 1 of 1
      • Use the strip of tape on the battery to remove the battery from the housing.
      Ask FixBot
    1. GoPro Hero3+ Silver Edition Camera Lens Replacement, Front Panel: step 3, image 1 of 1
      • Insert a plastic opening tool in between the front face plate and the black housing.
      • Make sure you insert the plastic opening tool next to the microSD card slot. There is a small gap that will help separate the face plate.
      Ask FixBot
    2. GoPro Hero3+ Silver Edition Camera Lens Replacement: step 4, image 1 of 1
      • Continue to use the plastic opening tool and separate the front face plate from the rest of the device.
      • There is adhesive that helps attach the front face plate. Some extra prying may be required to separate the face plate, but do not use excessive force.
      Ask FixBot
    1. GoPro Hero3+ Silver Edition Camera Lens Replacement, Image Sensor: step 5, image 1 of 3 GoPro Hero3+ Silver Edition Camera Lens Replacement, Image Sensor: step 5, image 2 of 3 GoPro Hero3+ Silver Edition Camera Lens Replacement, Image Sensor: step 5, image 3 of 3
      • Locate the four 8.1mm PH00 screws on the corners of the GoPro and unscrew them using the phillips screwdriver.
      • Gently remove the motherboard by using a plastic opening tool to pry it out of the housing.
      • Be careful not to damage the ribbon cable connected to the GoPro housing and motherboard.
      Ask FixBot
    2. GoPro Hero3+ Silver Edition Camera Lens Replacement: step 6, image 1 of 2 GoPro Hero3+ Silver Edition Camera Lens Replacement: step 6, image 2 of 2
      • Remove the ribbon cable by carefully flipping the black clip up with the plastic opening tool and pulling the cable out.
      Ask FixBot
    3. GoPro Hero3+ Silver Edition Camera Lens Replacement: step 7, image 1 of 1
      • Remove the four 4mm PH00 screws attaching the image sensor to the motherboard with your screwdriver.
      Ask FixBot
    4. GoPro Hero3+ Silver Edition Camera Lens Replacement: step 8, image 1 of 2 GoPro Hero3+ Silver Edition Camera Lens Replacement: step 8, image 2 of 2
      • Pry off the last ribbon cable with a plastic opening tool.
      • Remove the image sensor from the motherboard.
      Ask FixBot
    1. GoPro Hero3+ Silver Edition Camera Lens Replacement, microSD/Expansion Port Assembly: step 9, image 1 of 1
      • Using your screwdriver, unscrew three 4mm PH00 screws that will free the metal plate.
      • A small plate will become separated when the rightmost screw is removed. Just place it to the side.
      Ask FixBot
    2. GoPro Hero3+ Silver Edition Camera Lens Replacement: step 10, image 1 of 2 GoPro Hero3+ Silver Edition Camera Lens Replacement: step 10, image 2 of 2
      • Use the plastic opening tool to pry off the referenced ribbon cable from the motherboard.
      • The microSD and Accessory Board is now ready for removal.
      Ask FixBot
    1. GoPro Hero3+ Silver Edition Camera Lens Replacement, Motherboard: step 11, image 1 of 1
      • Remove the single 3.2mm PH00 screw with your screwdriver to detach the motherboard from the mid frame.
      Ask FixBot
    2. GoPro Hero3+ Silver Edition Camera Lens Replacement: step 12, image 1 of 3 GoPro Hero3+ Silver Edition Camera Lens Replacement: step 12, image 2 of 3 GoPro Hero3+ Silver Edition Camera Lens Replacement: step 12, image 3 of 3
      Tool used on this step:
      Buy
      • Use a plastic opening tool to gently separate the LCD ribbon cable from the motherboard.
      • Gently remove the motherboard from the midframe using tweezers.
      • Remove motherboard by lifting from the edges. This will reduce the chance of damaging components on the motherboard.
      Ask FixBot
    1. GoPro Hero3+ Silver Edition Camera Lens Replacement, Camera Lens: step 13, image 1 of 1
      • Use your PH00 screwdriver to remove the last three screws from the mid frame. This will release the lens housing from the mid frame.
      Ask FixBot
    2. GoPro Hero3+ Silver Edition Camera Lens Replacement: step 14, image 1 of 1
      • Carefully remove the lens from the font housing.
      Ask FixBot
9 other people completed this guide.
Author
with
Patrick Cook
699 Reputation
3 Guides authored
Cal Poly, Team 5-8, Maness Fall 2015 Member of Cal Poly, Team 5-8, Maness Fall 2015
CPSU-MANESS-F15S5G8
4 Members
72 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 16
Past 30 Days: 112
All Time: 2,920
