GoPro Hero 3 Silver Rear Housing Replacement
    1. GoPro Hero 3 Silver Rear Housing Replacement, Battery: step 1, image 1 of 2 GoPro Hero 3 Silver Rear Housing Replacement, Battery: step 1, image 2 of 2
      • Pull back on the tab on the back of GoPro to open the battery cover.
      Ask FixBot
    2. GoPro Hero 3 Silver Rear Housing Replacement: step 2, image 1 of 1
      • Pull the battery out using the tab.
      Ask FixBot
    1. GoPro Hero 3 Silver Rear Housing Replacement, Rear Housing: step 3, image 1 of 2 GoPro Hero 3 Silver Rear Housing Replacement, Rear Housing: step 3, image 2 of 2
      • Use the plastic opening tool to remove the faceplate.
      • There is some adhesive and clips so be careful and the faceplate should pop right off.
      Ask FixBot
    2. GoPro Hero 3 Silver Rear Housing Replacement: step 4, image 1 of 2 GoPro Hero 3 Silver Rear Housing Replacement: step 4, image 2 of 2
      • Now that the faceplate is off, it is time to remove the 4 screws on each corner.
      • Use the T4 tool bit from the iFixit toolkit in order to remove the 4 screws on each corner.
      Ask FixBot
    3. GoPro Hero 3 Silver Rear Housing Replacement: step 5, image 1 of 2 GoPro Hero 3 Silver Rear Housing Replacement: step 5, image 2 of 2
      • Note: Make sure you remove the door cover of the USB, mini HDMI, and SD port before. Separating the motherboard will be easier.
      • Using the plastic opening tool, slowly pry open the motherboard assembly.
      Ask FixBot
    4. GoPro Hero 3 Silver Rear Housing Replacement: step 6, image 1 of 2 GoPro Hero 3 Silver Rear Housing Replacement: step 6, image 2 of 2
      • Use the spudger to gently pry off the connector of the housing to the motherboard.
      • You should now have the motherboard assembly and the housing separated.
      Ask FixBot
    5. GoPro Hero 3 Silver Rear Housing Replacement: step 7, image 1 of 1
      • In order to replace the buttons. The entire housing has to be replaced.
      Ask FixBot
Brian Alvarez
1,439 Reputation
6 Guides authored
Cal Poly, Team 24-7, Lancaster Spring 2015 Member of Cal Poly, Team 24-7, Lancaster Spring 2015
CPSU-LANCASTER-S15S24G7
3 Members
84 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 8
Past 30 Days: 30
All Time: 2,888
