Up to 20% off select tools
GoPro Hero 3 Silver Image Sensor Replacement
Views: 2.7K
View statistics:
Past 24 Hours:
4
Past 7 Days:
19
Past 30 Days:
103
All Time:
2,716
Comments: 3
1 comment on steps, 2 guide comments.
Go to guide comments
Completed: 2
2 people have marked this guide "completed." Will you be next?
Favorites: 1
1 person has favorited (and subscribed to) this guide. Will you be next?
Time Required: No estimate
Difficulty: Easy
Better Introduction
Improve this guide by completing or revising its introduction.
Parts
Tools
    1. GoPro Hero 3 Silver Image Sensor Replacement, Battery: step 1, image 1 of 2 GoPro Hero 3 Silver Image Sensor Replacement, Battery: step 1, image 2 of 2
      • Pull back on the tab on the back of GoPro to open the battery cover.
      Ask FixBot
    2. GoPro Hero 3 Silver Image Sensor Replacement: step 2, image 1 of 1
      • Pull the battery out using the tab.
      Ask FixBot
    1. GoPro Hero 3 Silver Image Sensor Replacement, Image Sensor: step 3, image 1 of 2 GoPro Hero 3 Silver Image Sensor Replacement, Image Sensor: step 3, image 2 of 2
      • Use the plastic opening tool to remove the faceplate.
      • There is some adhesive and clips so be careful and the faceplate should pop right off.
      Ask FixBot
    2. GoPro Hero 3 Silver Image Sensor Replacement: step 4, image 1 of 2 GoPro Hero 3 Silver Image Sensor Replacement: step 4, image 2 of 2
      • Now that the faceplate is off, it is time to remove the 4 screws on each corner.
      • Use the T4 tool bit from the iFixit toolkit in order to remove the 4 screws on each corner.
      Ask FixBot
    3. GoPro Hero 3 Silver Image Sensor Replacement: step 5, image 1 of 2 GoPro Hero 3 Silver Image Sensor Replacement: step 5, image 2 of 2
      • Note: Make sure you remove the door cover of the USB, mini HDMI, and SD port before. Separating the motherboard will be easier.
      • Using the plastic opening tool, slowly pry open the motherboard assembly.
      Ask FixBot
    4. GoPro Hero 3 Silver Image Sensor Replacement: step 6, image 1 of 2 GoPro Hero 3 Silver Image Sensor Replacement: step 6, image 2 of 2
      • Use the spudger to gently pry off the connector of the housing to the motherboard.
      • You should now have the motherboard assembly and the housing separated.
      Ask FixBot
    5. GoPro Hero 3 Silver Image Sensor Replacement: step 7, image 1 of 2 GoPro Hero 3 Silver Image Sensor Replacement: step 7, image 2 of 2
      • Use the spudger to remove the heat shield tape and detach the image sensor from the motherboard.
      • Using the T4 Torx toolbit, remove the 4 screws that connect the sensor to the lens.
      Ask FixBot
    6. GoPro Hero 3 Silver Image Sensor Replacement: step 8, image 1 of 2 GoPro Hero 3 Silver Image Sensor Replacement: step 8, image 2 of 2
      • Remove the silver connector of the image sensor from the motherboard using the spudger to pry it off.
      • You should now be able to remove the image sensor by simply pulling it.
      Ask FixBot
2 other people completed this guide.
Author
with
Jose Villa
297 Reputation
1 Guide authored
Cal Poly, Team 24-7, Lancaster Spring 2015 Member of Cal Poly, Team 24-7, Lancaster Spring 2015
CPSU-LANCASTER-S15S24G7
3 Members
84 Guides authored
2 Guide Comments
After the sensor has been replaced, does the camera need any catibration?
enrilazaro - Reply Share
Your pictures are really dark.
Nick Ruiz - Reply Share
Past 24 Hours: 4
Past 7 Days: 19
Past 30 Days: 103
All Time: 2,716
