GoPro Hero 3 Silver Expansion Port Replacement
    1. GoPro Hero 3 Silver Expansion Port Replacement, Battery: step 1, image 1 of 2 GoPro Hero 3 Silver Expansion Port Replacement, Battery: step 1, image 2 of 2
      • Pull back on the tab on the back of GoPro to open the battery cover.
      Ask FixBot
    2. GoPro Hero 3 Silver Expansion Port Replacement: step 2, image 1 of 1
      • Pull the battery out using the tab.
      Ask FixBot
    1. GoPro Hero 3 Silver Expansion Port Replacement, Expansion Port: step 3, image 1 of 2 GoPro Hero 3 Silver Expansion Port Replacement, Expansion Port: step 3, image 2 of 2
      • Use the plastic opening tool to remove the faceplate.
      • There is some adhesive and clips so be careful and the faceplate should pop right off.
      Ask FixBot
    2. GoPro Hero 3 Silver Expansion Port Replacement: step 4, image 1 of 2 GoPro Hero 3 Silver Expansion Port Replacement: step 4, image 2 of 2
      • Now that the faceplate is off, it is time to remove the 4 screws on each corner.
      • Use the T4 tool bit from the iFixit toolkit in order to remove the 4 screws on each corner.
      Ask FixBot
    3. GoPro Hero 3 Silver Expansion Port Replacement: step 5, image 1 of 2 GoPro Hero 3 Silver Expansion Port Replacement: step 5, image 2 of 2
      • Note: Make sure you remove the door cover of the USB, mini HDMI, and SD port before. Separating the motherboard will be easier.
      • Using the plastic opening tool, slowly pry open the motherboard assembly.
      Ask FixBot
    4. GoPro Hero 3 Silver Expansion Port Replacement: step 6, image 1 of 2 GoPro Hero 3 Silver Expansion Port Replacement: step 6, image 2 of 2
      • Use the spudger to gently pry off the connector of the housing to the motherboard.
      • You should now have the motherboard assembly and the housing separated.
      Ask FixBot
    5. GoPro Hero 3 Silver Expansion Port Replacement: step 7, image 1 of 3 GoPro Hero 3 Silver Expansion Port Replacement: step 7, image 2 of 3 GoPro Hero 3 Silver Expansion Port Replacement: step 7, image 3 of 3
      • Use the spudger to remove the heat shield tape and detach the image sensor from the motherboard.
      • Using the T4 Torx toolbit, remove the 4 screws that connect the sensor to the lens.
      • Remove the silver connector of the image sensor from the motherboard using the spudger to pry it off.
      Ask FixBot
    6. GoPro Hero 3 Silver Expansion Port Replacement: step 8, image 1 of 2 GoPro Hero 3 Silver Expansion Port Replacement: step 8, image 2 of 2
      • The media adapter is attached to the motherboard via 3 screws:
      • x1 T4 Torx
      • x2 Phillips #00
      • There is a little silver bracket (in the yellow circle) that is held down by the Phillips #00 screw so be careful not to lose it.
      Ask FixBot
    7. GoPro Hero 3 Silver Expansion Port Replacement: step 9, image 1 of 2 GoPro Hero 3 Silver Expansion Port Replacement: step 9, image 2 of 2
      • With a little prying, use the spudger to detach the media adapter's connector from the motherboard.
      • Remove the media adapter from the motherboard.
      Ask FixBot
2 other people completed this guide.
Brian Alvarez
1,439 Reputation
6 Guides authored
Cal Poly, Team 24-7, Lancaster Spring 2015 Member of Cal Poly, Team 24-7, Lancaster Spring 2015
CPSU-LANCASTER-S15S24G7
3 Members
84 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 4
Past 30 Days: 19
All Time: 2,369
