Up to 20% off select tools
GoPro Hero 3+ Silver Edition Motherboard Replacement
Views: 4.6K
View statistics:
Past 24 Hours:
3
Past 7 Days:
22
Past 30 Days:
116
All Time:
4,591
Comments: 4
2 comments on steps, 2 guide comments.
Go to guide comments
Completed: 3
3 people have marked this guide "completed." Will you be next?
Favorites: 4
4 people have favorited (and subscribed to) this guide. Will you be next?
Time Required: 20 minutes
Difficulty: Easy
Featured Student Guide
This guide has been the hard work of our awesome students and is found to be exceptionally cool by the iFixit staff.
Parts
Tools
Introduction
Go to step 1 ↓
Are the circuits of your GoPro's motherboard fried from water damage? This guide provides steps on how to replace a GoPro Hero 3+ Silver Motherboard and get your camera back in working condition.
    1. GoPro Hero 3+ Silver Edition Motherboard Replacement, Battery: step 1, image 1 of 2 GoPro Hero 3+ Silver Edition Motherboard Replacement, Battery: step 1, image 2 of 2
      • Push the tab on the back of the device left to remove the plate covering the battery.
      Ask FixBot
    2. GoPro Hero 3+ Silver Edition Motherboard Replacement: step 2, image 1 of 1
      • Use the strip of tape on the battery to remove the battery from the housing.
      Ask FixBot
    1. GoPro Hero 3+ Silver Edition Motherboard Replacement, Front Panel: step 3, image 1 of 1
      • Insert a plastic opening tool in between the front face plate and the black housing.
      • Make sure you insert the plastic opening tool next to the microSD card slot. There is a small gap that will help separate the face plate.
      Ask FixBot
    2. GoPro Hero 3+ Silver Edition Motherboard Replacement: step 4, image 1 of 1
      • Continue to use the plastic opening tool and separate the front face plate from the rest of the device.
      • There is adhesive that helps attach the front face plate. Some extra prying may be required to separate the face plate, but do not use excessive force.
      Ask FixBot
    1. GoPro Hero 3+ Silver Edition Motherboard Replacement, Image Sensor: step 5, image 1 of 3 GoPro Hero 3+ Silver Edition Motherboard Replacement, Image Sensor: step 5, image 2 of 3 GoPro Hero 3+ Silver Edition Motherboard Replacement, Image Sensor: step 5, image 3 of 3
      • Locate the four 8.1mm PH00 screws on the corners of the GoPro and unscrew them using the phillips screwdriver.
      • Gently remove the motherboard by using a plastic opening tool to pry it out of the housing.
      • Be careful not to damage the ribbon cable connected to the GoPro housing and motherboard.
      Ask FixBot
    2. GoPro Hero 3+ Silver Edition Motherboard Replacement: step 6, image 1 of 2 GoPro Hero 3+ Silver Edition Motherboard Replacement: step 6, image 2 of 2
      • Remove the ribbon cable by carefully flipping the black clip up with the plastic opening tool and pulling the cable out.
      Ask FixBot
    3. GoPro Hero 3+ Silver Edition Motherboard Replacement: step 7, image 1 of 1
      • Remove the four 4mm PH00 screws attaching the image sensor to the motherboard with your screwdriver.
      Ask FixBot
    4. GoPro Hero 3+ Silver Edition Motherboard Replacement: step 8, image 1 of 2 GoPro Hero 3+ Silver Edition Motherboard Replacement: step 8, image 2 of 2
      • Pry off the last ribbon cable with a plastic opening tool.
      • Remove the image sensor from the motherboard.
      Ask FixBot
    1. GoPro Hero 3+ Silver Edition Motherboard Replacement, Motherboard: step 9, image 1 of 1
      • Remove the single 3.2mm PH00 screw with your screwdriver to detach the motherboard from the mid frame.
      Ask FixBot
    2. GoPro Hero 3+ Silver Edition Motherboard Replacement: step 10, image 1 of 3 GoPro Hero 3+ Silver Edition Motherboard Replacement: step 10, image 2 of 3 GoPro Hero 3+ Silver Edition Motherboard Replacement: step 10, image 3 of 3
      Tool used on this step:
      Buy
      • Use a plastic opening tool to gently separate the LCD ribbon cable from the motherboard.
      • Gently remove the motherboard from the midframe using tweezers.
      • Remove motherboard by lifting from the edges. This will reduce the chance of damaging components on the motherboard.
      Ask FixBot
3 other people completed this guide.
Author
with
Blake Ehlers
668 Reputation
3 Guides authored
Cal Poly, Team 5-8, Maness Fall 2015 Member of Cal Poly, Team 5-8, Maness Fall 2015
CPSU-MANESS-F15S5G8
4 Members
72 Guides authored
2 Guide Comments
hi, where i can find the matherboard for de hero 3+ silver?
Mauricio - Reply Share
Past 24 Hours: 3
Past 7 Days: 22
Past 30 Days: 116
All Time: 4,591
