Up to 20% off select tools
GoPro Hero+ LCD Lens Replacement
Views: 7.7K
View statistics:
Past 24 Hours:
3
Past 7 Days:
26
Past 30 Days:
117
All Time:
7,732
Comments: 6
4 comments on steps, 2 guide comments.
Go to guide comments
Completed: 2
2 people have marked this guide "completed." Will you be next?
Favorites: 1
1 person has favorited (and subscribed to) this guide. Will you be next?
Time Required: 5 - 10 minutes
Difficulty: Difficult
Parts
Tools
Introduction
Go to step 1 ↓
To remove the lens assembly, you must remove some internal parts first. Some of these screws are in tight places, so they will be tedious to access.
    1. GoPro Hero+ LCD Lens Replacement, Back Panel: step 1, image 1 of 2 GoPro Hero+ LCD Lens Replacement, Back Panel: step 1, image 2 of 2
      • Be sure to power off the GoPro before you start disassembly.
      • Pop up and pull back on the clip to remove the screen cover and expose the back panel with the touchscreen.
      Ask FixBot
    2. GoPro Hero+ LCD Lens Replacement: step 2, image 1 of 2 GoPro Hero+ LCD Lens Replacement: step 2, image 2 of 2
      • Use the metal spudger to pry around the perimeter of the panel.
      • Pry the panel upwards by inserting the metal spudger into the corner crease between the panel and camera shell.
      Ask FixBot
    3. GoPro Hero+ LCD Lens Replacement: step 3, image 1 of 2 GoPro Hero+ LCD Lens Replacement: step 3, image 2 of 2
      • Pry around the panel to ensure it is not attached to the device.
      • Move the panel to the side so you can access the internal components.
      • The panel is still attached to the rest of the device with a ribbon cable, so be sure to not tear or damage the cable.
      Ask FixBot
    1. GoPro Hero+ LCD Lens Replacement, Battery: step 4, image 1 of 1
      • Peel back the rear panel ribbon cable that is adhered to the battery until it is completely separated from the battery.
      • Be careful of metal contacts on strip; they can be sharp.
      Ask FixBot
    2. GoPro Hero+ LCD Lens Replacement: step 5, image 1 of 1
      Tool used on this step:
      Buy
      • Using tweezers, peel off the copper tape on the right side of the battery.
      Ask FixBot
    3. GoPro Hero+ LCD Lens Replacement: step 6, image 1 of 2 GoPro Hero+ LCD Lens Replacement: step 6, image 2 of 2
      • Place the plastic opening tool at one of the edges of the battery then pry until the battery is removed from the GoPro.
      Ask FixBot
    4. GoPro Hero+ LCD Lens Replacement: step 7, image 1 of 1
      • Use a pair of tweezers to disconnect the battery connector from the motherboard.
      • Gently pull the battery off the motherboard. Pulling vertically off the motherboard will give a clean release.
      Ask FixBot
    1. GoPro Hero+ LCD Lens Replacement, MicroSD/Micro USB Port Assembly: step 8, image 1 of 3 GoPro Hero+ LCD Lens Replacement, MicroSD/Micro USB Port Assembly: step 8, image 2 of 3 GoPro Hero+ LCD Lens Replacement, MicroSD/Micro USB Port Assembly: step 8, image 3 of 3
      • Remove the two 6 mm Phillips #00 screws.
      • Remove the single 4 mm Phillips #000 screws.
      Ask FixBot
    2. GoPro Hero+ LCD Lens Replacement: step 9, image 1 of 1
      • Remove the image sensor from the camera.
      • You do not have to unplug the black box to remove the USB/SD chip.
      Ask FixBot
    3. GoPro Hero+ LCD Lens Replacement: step 10, image 1 of 1
      Buy
      • Grab the edge of the ribbon cable with the tweezers and gently pull until the cable is disconnected from the motherboard.
      • Be careful when removing the ribbon cable. You must pull gently or you can rip the ribbon off of its contacts.
      Ask FixBot
    4. GoPro Hero+ LCD Lens Replacement: step 11, image 1 of 1
      • Gently lift the microSD/Micro USB assembly up and out of the device.
      Ask FixBot
    1. GoPro Hero+ LCD Lens Replacement, Image Sensor: step 12, image 1 of 1
      • Use your fingers and gently pull out the sensor from the motherboard by slowly and gradually pulling up on the image sensor box.
      • Do not yank on the image sensor, it can rip out the wiring or damage the motherboard.
      Ask FixBot
    1. GoPro Hero+ LCD Lens Replacement, Motherboard: step 13, image 1 of 3 GoPro Hero+ LCD Lens Replacement, Motherboard: step 13, image 2 of 3 GoPro Hero+ LCD Lens Replacement, Motherboard: step 13, image 3 of 3
      • Remove the three 4 mm Phillips #000 screws securing the motherboard.
      Ask FixBot
    2. GoPro Hero+ LCD Lens Replacement: step 14, image 1 of 1
      • Use your fingers to gently remove the ribbon connected to the lens.
      • Be careful when removing the ribbon cable. Pull off gently or you can separate the ribbon from the contacts.
      Ask FixBot
    3. GoPro Hero+ LCD Lens Replacement: step 15, image 1 of 3 GoPro Hero+ LCD Lens Replacement: step 15, image 2 of 3 GoPro Hero+ LCD Lens Replacement: step 15, image 3 of 3
      • Use your fingers and carefully pull out the motherboard from under the lens. It may take a little bit of adjusting to get it out.
      Ask FixBot
    1. GoPro Hero+ LCD Lens Replacement, Lens: step 16, image 1 of 3 GoPro Hero+ LCD Lens Replacement, Lens: step 16, image 2 of 3 GoPro Hero+ LCD Lens Replacement, Lens: step 16, image 3 of 3
      • Remove the two 4 mm Phillips #000 screws securing the top button.
      Ask FixBot
    2. GoPro Hero+ LCD Lens Replacement: step 17, image 1 of 2 GoPro Hero+ LCD Lens Replacement: step 17, image 2 of 2
      • Remove the four 4 mm Phillips #000 screws securing the lens to the case.
      Ask FixBot
    3. GoPro Hero+ LCD Lens Replacement: step 18, image 1 of 3 GoPro Hero+ LCD Lens Replacement: step 18, image 2 of 3 GoPro Hero+ LCD Lens Replacement: step 18, image 3 of 3
      • Gently lift the lens up and out of the device.
      Ask FixBot
2 other people completed this guide.
Author
with
Matthew Tinkey
937 Reputation
4 Guides authored
USF Tampa, Team 2-4, Blackwell Fall 2015 Member of USF Tampa, Team 2-4, Blackwell Fall 2015
USFT-BLACKWELL-F15S2G4
4 Members
72 Guides authored
2 Guide Comments
I'm curious if you have any suggestions for sourcing the replacement part.
Driftless Repair - Reply Share
My hing clip is broken, Can I remove the actual camera & replace the full waterproof case then reinstall my camera into the new replacement case ?
jimmac044 - Reply Share
Past 24 Hours: 3
Past 7 Days: 26
Past 30 Days: 117
All Time: 7,732
