Up to 20% off select tools
GoPro Hero+ LCD Image Sensor Replacement
Views: 2.5K
View statistics:
Past 24 Hours:
2
Past 7 Days:
18
Past 30 Days:
92
All Time:
2,521
Comments: 4
4 comments on steps.
Completed: 0
Favorites: 0
Time Required: 5 minutes
Difficulty: Moderate
Tools
Introduction
Go to step 1 ↓
The image sensor is located behind the lens and is attached to the motherboard. Be careful in removing wiring from the motherboard, they are thin and small contacts and must be handled with care.
    1. GoPro Hero+ LCD Image Sensor Replacement, Back Panel: step 1, image 1 of 2 GoPro Hero+ LCD Image Sensor Replacement, Back Panel: step 1, image 2 of 2
      • Be sure to power off the GoPro before you start disassembly.
      • Pop up and pull back on the clip to remove the screen cover and expose the back panel with the touchscreen.
      Ask FixBot
    2. GoPro Hero+ LCD Image Sensor Replacement: step 2, image 1 of 2 GoPro Hero+ LCD Image Sensor Replacement: step 2, image 2 of 2
      • Use the metal spudger to pry around the perimeter of the panel.
      • Pry the panel upwards by inserting the metal spudger into the corner crease between the panel and camera shell.
      Ask FixBot
    3. GoPro Hero+ LCD Image Sensor Replacement: step 3, image 1 of 2 GoPro Hero+ LCD Image Sensor Replacement: step 3, image 2 of 2
      • Pry around the panel to ensure it is not attached to the device.
      • Move the panel to the side so you can access the internal components.
      • The panel is still attached to the rest of the device with a ribbon cable, so be sure to not tear or damage the cable.
      Ask FixBot
    1. GoPro Hero+ LCD Image Sensor Replacement, Battery: step 4, image 1 of 1
      • Peel back the rear panel ribbon cable that is adhered to the battery until it is completely separated from the battery.
      • Be careful of metal contacts on strip; they can be sharp.
      Ask FixBot
    2. GoPro Hero+ LCD Image Sensor Replacement: step 5, image 1 of 1
      Tool used on this step:
      Buy
      • Using tweezers, peel off the copper tape on the right side of the battery.
      Ask FixBot
    3. GoPro Hero+ LCD Image Sensor Replacement: step 6, image 1 of 2 GoPro Hero+ LCD Image Sensor Replacement: step 6, image 2 of 2
      • Place the plastic opening tool at one of the edges of the battery then pry until the battery is removed from the GoPro.
      Ask FixBot
    4. GoPro Hero+ LCD Image Sensor Replacement: step 7, image 1 of 1
      • Use a pair of tweezers to disconnect the battery connector from the motherboard.
      • Gently pull the battery off the motherboard. Pulling vertically off the motherboard will give a clean release.
      Ask FixBot
    1. GoPro Hero+ LCD Image Sensor Replacement, MicroSD/Micro USB Port Assembly: step 8, image 1 of 3 GoPro Hero+ LCD Image Sensor Replacement, MicroSD/Micro USB Port Assembly: step 8, image 2 of 3 GoPro Hero+ LCD Image Sensor Replacement, MicroSD/Micro USB Port Assembly: step 8, image 3 of 3
      • Remove the two 6 mm Phillips #00 screws.
      • Remove the single 4 mm Phillips #000 screws.
      Ask FixBot
    2. GoPro Hero+ LCD Image Sensor Replacement: step 9, image 1 of 1
      • Remove the image sensor from the camera.
      • You do not have to unplug the black box to remove the USB/SD chip.
      Ask FixBot
    3. GoPro Hero+ LCD Image Sensor Replacement: step 10, image 1 of 1
      Buy
      • Grab the edge of the ribbon cable with the tweezers and gently pull until the cable is disconnected from the motherboard.
      • Be careful when removing the ribbon cable. You must pull gently or you can rip the ribbon off of its contacts.
      Ask FixBot
    4. GoPro Hero+ LCD Image Sensor Replacement: step 11, image 1 of 1
      • Gently lift the microSD/Micro USB assembly up and out of the device.
      Ask FixBot
    1. GoPro Hero+ LCD Image Sensor Replacement, Image Sensor: step 12, image 1 of 1
      • Use your fingers and gently pull out the sensor from the motherboard by slowly and gradually pulling up on the image sensor box.
      • Do not yank on the image sensor, it can rip out the wiring or damage the motherboard.
      Ask FixBot
Author
with
Matthew Tinkey
937 Reputation
4 Guides authored
USF Tampa, Team 2-4, Blackwell Fall 2015 Member of USF Tampa, Team 2-4, Blackwell Fall 2015
USFT-BLACKWELL-F15S2G4
4 Members
72 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 18
Past 30 Days: 92
All Time: 2,521
