Up to 20% off select tools
GoPro Hero+ LCD Battery Replacement
Views: 43K
View statistics:
Past 24 Hours:
18
Past 7 Days:
78
Past 30 Days:
248
All Time:
43,311
Comments: 17
4 comments on steps, 13 guide comments.
Go to guide comments
Completed: 20
20 people have marked this guide "completed." Will you be next?
Favorites: 3
3 people have favorited (and subscribed to) this guide. Will you be next?
Time Required: 5 minutes
Difficulty: Easy
Parts
Tools
Introduction
Go to step 1 ↓
The battery is connected to the motherboard with a few wires. Be sure to be careful when removing the battery to not damage the motherboard or the battery.
    1. GoPro Hero+ LCD Battery Replacement, Back Panel: step 1, image 1 of 2 GoPro Hero+ LCD Battery Replacement, Back Panel: step 1, image 2 of 2
      • Be sure to power off the GoPro before you start disassembly.
      • Pop up and pull back on the clip to remove the screen cover and expose the back panel with the touchscreen.
      Ask FixBot
    2. GoPro Hero+ LCD Battery Replacement: step 2, image 1 of 2 GoPro Hero+ LCD Battery Replacement: step 2, image 2 of 2
      • Use the metal spudger to pry around the perimeter of the panel.
      • Pry the panel upwards by inserting the metal spudger into the corner crease between the panel and camera shell.
      Ask FixBot
    3. GoPro Hero+ LCD Battery Replacement: step 3, image 1 of 2 GoPro Hero+ LCD Battery Replacement: step 3, image 2 of 2
      • Pry around the panel to ensure it is not attached to the device.
      • Move the panel to the side so you can access the internal components.
      • The panel is still attached to the rest of the device with a ribbon cable, so be sure to not tear or damage the cable.
      Ask FixBot
    1. GoPro Hero+ LCD Battery Replacement, Battery: step 4, image 1 of 1
      • Peel back the rear panel ribbon cable that is adhered to the battery until it is completely separated from the battery.
      • Be careful of metal contacts on strip; they can be sharp.
      Ask FixBot
    2. GoPro Hero+ LCD Battery Replacement: step 5, image 1 of 1
      Tool used on this step:
      Buy
      • Using tweezers, peel off the copper tape on the right side of the battery.
      Ask FixBot
    3. GoPro Hero+ LCD Battery Replacement: step 6, image 1 of 2 GoPro Hero+ LCD Battery Replacement: step 6, image 2 of 2
      • Place the plastic opening tool at one of the edges of the battery then pry until the battery is removed from the GoPro.
      Ask FixBot
    4. GoPro Hero+ LCD Battery Replacement: step 7, image 1 of 1
      • Use a pair of tweezers to disconnect the battery connector from the motherboard.
      • Gently pull the battery off the motherboard. Pulling vertically off the motherboard will give a clean release.
      Ask FixBot
20 other people completed this guide.
Author
with
Kyle
222 Reputation
1 Guide authored
USF Tampa, Team 2-4, Blackwell Fall 2015 Member of USF Tampa, Team 2-4, Blackwell Fall 2015
USFT-BLACKWELL-F15S2G4
4 Members
72 Guides authored
13 Guide Comments
This is a superb guide but where can one buy a replacement battery? I have looked on the web for the one in your photo but can't find a specific one.
I want to buy one of these cameras but would like to know I can replace the battery.
Thanks.
Andrew - Reply Share
I am also trying to find the replacement battery for a Hero+. Have found a lot of batteries for all other versions of Gopro cams, but not one single one for a Hero+.
I have also sent an email to Gopro to get help. I am not prepared for an answer but I really would like to get hold of a battery.
Does anyone know how to get one?
Please contact me: rhafsrhafs@gmail.com. Rikard from Sweden.
Thanks
Rikard
Rikard Hård - Reply Share
hi, do you know where i can get the housing for the gopro hero+ lcd. mine is broken and need a new one but can't find it anywhere...........
chris
christianrisan - Reply Share
not even amazon?
Mary D'Alesandro - Reply Share
this is awesome thanks a lot! , i dont want to be rude, but the title says battery replacementnt , why isnt anyone preparing a battery and putting it back in?, All everyone is doing is taking th battery out
John misquita - Reply Share
Past 24 Hours: 18
Past 7 Days: 78
Past 30 Days: 248
All Time: 43,311
