Up to 20% off select tools
GoPro HD Hero2 Front Case Replacement
Views: 8K
View statistics:
Past 24 Hours:
6
Past 7 Days:
26
Past 30 Days:
120
All Time:
7,996
Comments: 4
4 comments on steps.
Completed: 5
5 people have marked this guide "completed." Will you be next?
Favorites: 1
1 person has favorited (and subscribed to) this guide. Will you be next?
Time Required: No estimate
Difficulty: Moderate
Tools
Introduction
Go to step 1 ↓
The front case of your GoPro is constantly being subjected to potentially dangerous obstacles: trees, bears, viking ships, and who knows what else. Should you happen to crack or break the front case, you can replace it with a brand new one.
    1. GoPro HD Hero2 Front Case Replacement, Back Cover: step 1, image 1 of 2 GoPro HD Hero2 Front Case Replacement, Back Cover: step 1, image 2 of 2
      • Place your thumb on the indentation in the back case on the side of the GoPro.
      • Gently press down with your thumb and lift the back cover away from the case to remove it.
      Ask FixBot
    1. GoPro HD Hero2 Front Case Replacement, Battery: step 2, image 1 of 2 GoPro HD Hero2 Front Case Replacement, Battery: step 2, image 2 of 2
      • Slide a plastic opening tool between the battery and the rear case.
      • Gently pry the battery up and out of the rear case.
      Ask FixBot
    2. GoPro HD Hero2 Front Case Replacement: step 3, image 1 of 1
      • Remove the battery from the case.
      Ask FixBot
    1. GoPro HD Hero2 Front Case Replacement, Rear Case: step 4, image 1 of 1
      • Remove the four Phillips #00 screws securing the rear case to the rest of the device:
      • Two 5.5 mm coarse thread screws.
      • Two 4.4 mm fine thread screws.
      Ask FixBot
    2. GoPro HD Hero2 Front Case Replacement: step 5, image 1 of 2 GoPro HD Hero2 Front Case Replacement: step 5, image 2 of 2
      • Slide the edge of a plastic opening tool underneath the sticker on the rear cover and gently peel the sticker up.
      • Once you have enough of the sticker peeled up with the plastic opening tool, grab an edge of it with your fingers and pull it off completely.
      Ask FixBot
    3. GoPro HD Hero2 Front Case Replacement: step 6, image 1 of 2 GoPro HD Hero2 Front Case Replacement: step 6, image 2 of 2
      • Grasp the rear case and lift it off of the front case.
      • Do not try to completely remove the rear case yet, as it is still attached by the display port ribbon cable.
      Ask FixBot
    4. GoPro HD Hero2 Front Case Replacement: step 7, image 1 of 2 GoPro HD Hero2 Front Case Replacement: step 7, image 2 of 2
      Tool used on this step:
      Buy
      • Using a plastic opening tool or your fingernail, flip up the locking tab on the SD board ribbon cable ZIF connector on the motherboard assembly.
      • Be careful that you are prying on the locking tab, and not the connector itself.
      • Use a pair of tweezers to remove the SD board ribbon cable from its connector on the motherboard.
      Ask FixBot
    5. GoPro HD Hero2 Front Case Replacement: step 8, image 1 of 3 GoPro HD Hero2 Front Case Replacement: step 8, image 2 of 3 GoPro HD Hero2 Front Case Replacement: step 8, image 3 of 3
      • Lift the speaker out of the rear case with the tip of a spudger.
      • Remove the rear case.
      Ask FixBot
    1. GoPro HD Hero2 Front Case Replacement, Motherboard Assembly: step 9, image 1 of 1
      • Remove the three screws securing the motherboard assembly to the front case:
      • Two 10.8 mm Phillips #00 screws.
      • One 4.8 mm Phillips #00 screw.
      Ask FixBot
    2. GoPro HD Hero2 Front Case Replacement: step 10, image 1 of 2 GoPro HD Hero2 Front Case Replacement: step 10, image 2 of 2
      • Gently grab the edges of the motherboard assembly and lift it out of the front case.
      Ask FixBot
    1. GoPro HD Hero2 Front Case Replacement, Front Case: step 11, image 1 of 1
      • The front case remains.
      Ask FixBot
5 other people completed this guide.
Author
with
David Hodson
157,488 Reputation
127 Guides authored
0 Guide Comments
Past 24 Hours: 6
Past 7 Days: 26
Past 30 Days: 120
All Time: 7,996
