Up to 20% off select tools
GoPro HD Hero2 Battery Replacement
Views: 16K
View statistics:
Past 24 Hours:
5
Past 7 Days:
31
Past 30 Days:
121
All Time:
16,312
Comments: 0
Go to guide comments
Completed: 3
3 people have marked this guide "completed." Will you be next?
Favorites: 1
1 person has favorited (and subscribed to) this guide. Will you be next?
Time Required: No estimate
Difficulty: Easy
Parts
Tools
Introduction
Go to step 1 ↓
Replace your dying GoPro battery with a fresh one. If you're ready to jump off a mountain, your battery should be too!
    1. GoPro HD Hero2 Battery Replacement, Back Cover: step 1, image 1 of 2 GoPro HD Hero2 Battery Replacement, Back Cover: step 1, image 2 of 2
      • Place your thumb on the indentation in the back case on the side of the GoPro.
      • Gently press down with your thumb and lift the back cover away from the case to remove it.
      Ask FixBot
    1. GoPro HD Hero2 Battery Replacement, Battery: step 2, image 1 of 2 GoPro HD Hero2 Battery Replacement, Battery: step 2, image 2 of 2
      • Slide a plastic opening tool between the battery and the rear case.
      • Gently pry the battery up and out of the rear case.
      Ask FixBot
    2. GoPro HD Hero2 Battery Replacement: step 3, image 1 of 1
      • Remove the battery from the case.
      Ask FixBot
3 other people completed this guide.
Author
with
David Hodson
157,488 Reputation
127 Guides authored
0 Guide Comments
Past 24 Hours: 5
Past 7 Days: 31
Past 30 Days: 121
All Time: 16,312
