Up to 20% off select tools
Globe Light Bulb Replacement
Views: 12K
View statistics:
Past 24 Hours:
17
Past 7 Days:
85
Past 30 Days:
338
All Time:
12,274
Comments: 1
1 comment on steps.
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 5 minutes
Difficulty: Easy
Community-Contributed Guide
Introduction
Go to step 1 ↓
This guide shows you how to change the light bulb in a globe.
    1. Globe Light Bulb Replacement, light bulb: step 1, image 1 of 2 Globe Light Bulb Replacement, light bulb: step 1, image 2 of 2
      • With a plastic meridian like this one, you need to raise the meridian slightly from the North Pole. Use the plastic ring on the north pole to gently press the globe down and pull up the meridian so you lift the little pin,which holdes the globe.
      Ask FixBot
    2. Globe Light Bulb Replacement: step 2, image 1 of 1
      • Now you can slowly turn the globe to the side and lift it from the socket at the south pole.
      • Be careful not to scratch the globe with the meridian.
      Ask FixBot
    3. Globe Light Bulb Replacement: step 3, image 1 of 1
      • You can replace the bulb now. Screw the new bulb into the socket.
      • Please make sure that you are using an equivalent bulb.
      Ask FixBot
    4. Globe Light Bulb Replacement: step 4, image 1 of 1
      • Finally install the globe again by placing it back on the south pole and fixing the meridian on to the north pole.
      Ask FixBot
    5. Globe Light Bulb Replacement: step 5, image 1 of 1
      • Your globe is now glowing bright again.
      Ask FixBot
Finish Line
Author
with
Athina Pilitsidou
171 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 17
Past 7 Days: 85
Past 30 Days: 338
All Time: 12,274
