Glass Shelving Replacement
Views: 2.2K
View statistics:
Past 24 Hours:
4
Past 7 Days:
28
Past 30 Days:
146
All Time:
2,192
Comments: 1
1 comment on steps.
Completed: 2
2 people have marked this guide "completed." Will you be next?
Favorites: 1
1 person has favorited (and subscribed to) this guide. Will you be next?
Time Required: 30 minutes - 1 hour
Difficulty: Moderate
Missing Steps
Oops! This guide is currently missing one or more important steps.
Introduction
Go to step 1 ↓
All the steps to replace the glass panels in the repair of a bathroom glass shelf are relatively simple. Note, however, that there are steps regarding glass cutting. Therefore minors need to be supervised by an adult (it is recommended that minors do not perform the glass cutting step). After successfully replacing the glass panel you also need to pay attention to the site for any residual broken glass.
    1. Glass Shelving Replacement, Bathroom glass shelving: step 1, image 1 of 1
      • Prepare your work area.
      • You will need a relatively wide platform to place the glass and cutting tools.
      Ask FixBot
    2. Glass Shelving Replacement: step 2, image 1 of 1
      • Wipe the glass surface clean.
      Ask FixBot
    3. Glass Shelving Replacement: step 3, image 1 of 3 Glass Shelving Replacement: step 3, image 2 of 3 Glass Shelving Replacement: step 3, image 3 of 3
      • Mark and measure the area to be cut.
      • Decide the size of the cut according to the size of the old glass panel.
      • It is recommended to use colored pens or markers to mark the glass directly for the next step of cutting.
      Ask FixBot
    4. Glass Shelving Replacement: step 4, image 1 of 1
      • Use a glass cutter to cut the glass panel.
      • Here the angle between the glass cutter and the glass should be kept at 45 degrees. Try to keep the force consistent and draw a neat and smooth cutting line.
      • Pay attention to the sound. The less sound you make, the better the scribing effect will be. Too much force will easily lead to broken glass.
      Ask FixBot
    5. Glass Shelving Replacement: step 5, image 1 of 3 Glass Shelving Replacement: step 5, image 2 of 3 Glass Shelving Replacement: step 5, image 3 of 3
      • Split the glass plate.
      • Grasp the ends of the glass near the dividing line with your hands. Using your wrist, apply gentle pressure along the scratch line to split the glass in half. With just your wrist pressing on the glass, the elbow joint does not need to move.
      • If the glass panel is curved in shape, you need to lightly bounce the glass and then apply gentle pressure from the back of the glass against the middle point of the scratch line.
      Ask FixBot
    6. Glass Shelving Replacement: step 6, image 1 of 3 Glass Shelving Replacement: step 6, image 2 of 3 Glass Shelving Replacement: step 6, image 3 of 3
      • Sand the edges of the glass plate. Use sandpaper to clear off the sharp edges of the glass plate until the edges appear matte.
      • You can use various grains of sandpaper to reach the ideal state. If you have access to a glass polishing machine, the effect is even better.
      Ask FixBot
    7. Glass Shelving Replacement: step 7, image 1 of 3 Glass Shelving Replacement: step 7, image 2 of 3 Glass Shelving Replacement: step 7, image 3 of 3
      • Insert the glass plate into the slot on the wall. Finish the repair.
      • If the glass panel has small railings and other accessories, you can use a glue gun or strong glue to secure it.
      Ask FixBot
2 other people completed this guide.
T TERESA
169 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 4
Past 7 Days: 28
Past 30 Days: 146
All Time: 2,192
