Gipo H369e Keypad Replacement
View statistics:
Past 24 Hours:
2
Past 7 Days:
16
Past 30 Days:
90
All Time:
846
Comments: 0
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 20 minutes
Difficulty: Moderate
Needs Better Images
Better photos will improve this guide. Help out by taking, editing, or uploading new ones!
Needs More Images
A few more images would make this guide's procedures crystal clear.
Introduction
Go to step 1 ↓
This guide demonstrates:
1. How to disassemble the Gipo H369e.
2. What tools to use in the disassembly.
  • Phillips head 000 screwdriver
  • Small prying tool (ex: puddy knife)
  • Needle nose tweezers
3. How to replace the keypad.
Tools
    1. Gipo H369e Keypad Replacement, Keypad: step 1, image 1 of 2 Gipo H369e Keypad Replacement, Keypad: step 1, image 2 of 2
      • Insert thumb into the groove on the back lefthand corner of the phone to unsnap the back cover.
      Ask FixBot
    2. Gipo H369e Keypad Replacement: step 2, image 1 of 1
      • Remove the battery from the back of the phone.
      Ask FixBot
    3. Gipo H369e Keypad Replacement: step 3, image 1 of 2 Gipo H369e Keypad Replacement: step 3, image 2 of 2
      • Unscrew the 5 screws on the back of the phone using the Philips Head 000 screwdriver.
      Ask FixBot
    4. Gipo H369e Keypad Replacement: step 4, image 1 of 3 Gipo H369e Keypad Replacement: step 4, image 2 of 3 Gipo H369e Keypad Replacement: step 4, image 3 of 3
      • Use the plastic opening tool to pry the front of the phone away from the back of the phone.
      Ask FixBot
    5. Gipo H369e Keypad Replacement: step 5, image 1 of 2 Gipo H369e Keypad Replacement: step 5, image 2 of 2
      • Once the front and back of the phone are separated, the keypad will fall out. You can now replace your old keypad.
      Ask FixBot
      • Use the needle nose pliers to peel the plastic screen away from the front of the disassembled phone. You can now replace the plastic screen.
      Ask FixBot
Janelle Norris
185 Reputation
2 Guides authored
Ohio State, Team 1-4, Garvin Fall 2015 Member of Ohio State, Team 1-4, Garvin Fall 2015
OSU-GARVIN-F15S1G4
3 Members
24 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 16
Past 30 Days: 90
All Time: 846
